Arcsoft- alternative to Powerdvd for Hddvd and Bluray? - Page 28 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #811 of 828 Old 01-22-2008, 12:17 AM
edfowler's Avatar
Quoted: 152 Post(s)
Liked: 83
am i going to have to do another fresh install?
edfowler is offline
post #812 of 828 Old 01-22-2008, 12:18 AM
edfowler's Avatar
Quoted: 152 Post(s)
Liked: 83
btw, my htpc was playing fine with two monitors configured seperately with my 3720 radeon video card.
edfowler is offline
post #813 of 828 Old 01-22-2008, 01:36 AM
Mark Pitchford's Avatar
Originally Posted by talon95 View Post
Thanks for the info. I see the same thing here. Interestingly, I unregistered the Arcsoft Audio Decoder HD filter which fixed my MP3 playback problem. TMT seems to still work also despite the filter being unregistered, so this is a temporary fix at least.
I'm going to guess that TMT is locked to the Arcsoft filters, hence it continuing to work with one of the filters unregistered. PowerDVD works this way as I recall.
Hi Talon95,
...sorry for the newbie qustion but how exactly did you go about unregistering the arcsoft audio decoder?
Mark
Mark Pitchford is offline
post #814 of 828 Old 01-22-2008, 01:48 AM
vairulez's Avatar
did anyone try to build a graph with the filters from TMT ? sarah99 ?
sorry for my poor english but I'm french !!!!
vairulez is offline
post #815 of 828 Old 01-22-2008, 01:51 AM
720p's Avatar
Originally Posted by Mark Pitchford View Post
Hi Talon95,
Mark
download gspot, view all installed filters, right click unregister
you can re-register it anytime & also set a merit (priority) for filters/codecs
720p is offline
post #816 of 828 Old 01-22-2008, 02:16 AM
sarah99's Avatar
Yes, it works
Arcsoft mpeg demux + Arcsoft Audio Decoder HD + Arcsoft Video Decoder
If you try this on a crashed XP machine it can't connect the pins
It won't mix and match with other filters, you have to use these 3
sarah99 is offline
post #817 of 828 Old 01-22-2008, 02:32 AM
sarah99's Avatar
Originally Posted by Tristanets View Post
Sarah99, I had the same issue with audio - stereo output instead of surround, right and center speakers mismatch... I have fixed it...
You just select 'HEADPHONE' instead of '5.1 channels' (or 7.1) in the audio menu, and it will display perfect surround. LOL! ENJOY!
All this means is you have your amp in some "fake" surround sound mode. Headphones mutes and downmixes everything for FL and FR. The question is ..... have you ever listened to anything in real 5:1 or have you always used the fake setting on your amp.
sarah99 is offline
post #818 of 828 Old 01-22-2008, 04:47 AM
jespermart's Avatar
Quoted: 57 Post(s)
Powerdvd works just fine on a secondary monitor in my case using Ultramon. The connection to the secondary monitor a Panasonic plasma goes via a 3870 through HDMI.
It's seems totally stupid to release a piece of software that can only function if there is only one display connected. Every grafikcard has two outputs, how can it be so hard to allow using both.
Jesper
jespermart is offline
post #819 of 828 Old 01-22-2008, 05:16 AM
sarah99's Avatar
Jesper
This is a HDCP/DRM requirement, nothing to do with PDVD or Arcsoft
sarah99 is offline
post #820 of 828 Old 01-22-2008, 05:41 AM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
Jesper
I don't know what your specific setup is, but multiple monitors certainly work with the Arcsoft player. My main desktop has three 20" monitors and I can certainly drag the player to any of the monitors and it plays perfectly fine. My family room HT has a 7" touchscreen as well as a projector and I can certainly drag the player to any of those as well and it plays perfectly fine.
kapone is offline
post #821 of 828 Old 01-22-2008, 06:53 AM
PatrickB101's Avatar
i have a pansonic plasma as well as a my primary monitor and i get nothing but a black screen on the trail. running a 7900gt which i wasn't sure if it was hdcp compliant did a quick search in google a few days ago and says the 7900s are. running a dvi-hdmi cable
PatrickB101 is offline
post #822 of 828 Old 01-22-2008, 07:03 AM
mabrown's Avatar
Not all are, they are compatible but not compliant. The difference is compatible means the OEM can add the chip to make it compliant, not all versions are compliant.
mabrown is offline
post #823 of 828 Old 01-22-2008, 07:58 AM
jespermart's Avatar
Quoted: 57 Post(s)
As I stated earlier I'm able to get PowerDVD to play via HD 3870 and HDMI to my Panasonic plasma PX70 and through Vista VMC & My Movies.
The Arcsoft TMT also opens on the Panasonic, plays the soundtrack but shows only black screen
post #824 of 828 Old 01-22-2008, 08:02 AM
WERA689's Avatar
Quoted: 85 Post(s)
Liked: 46
I downloaded the demo the other day, and last night I tried to play "Resident Evil-Extinction" on BR. ArcSoft played all the audio commentary tracks, whether or not they were selected in the menu. I could not find a way to disable the commentaries, and gave up playing the movie.
BTW, I played it using PowerDVD, and it played fine until 32 mins, where it blue-screen crashed the computer and rebooted. No luck there either!
Anyone else encountered this issue?
WERA689 is offline
post #825 of 828 Old 01-22-2008, 08:13 AM
jojoxl's Avatar
Originally Posted by 8:13 View Post
The problems in the English Arcsoft Totalmedia Theater software in the arcsoft thread your active on. I made a list of them and posted them here.
http://www.avsforum.com/avs-vb/showt...6#post12891806
It's a comprehensive list current as of today.
Uh... It's probably gonna get confusing to have two threads going, so I'll see if the mods can close this one with a link to the new one as the last post.
jojoxl is offline
post #826 of 828 Old 01-22-2008, 08:23 AM
huskerpat's Avatar
Originally Posted by vidabox View Post
Hello all,
I wanted to give you an update on some things.
  1. VidaBox will be offering a 15 trial of their version of the Arcsoft player.
This is much appreciated. I've held off on the current trial, but am looking forward to demo of the release.
Life is tough, but it's tougher when you're stupid. - John Wayne
huskerpat is offline
post #827 of 828 Old 01-22-2008, 08:26 AM
jespermart's Avatar
Quoted: 57 Post(s)
About secondary display.
My Panasonic manual states the following: These HDMI connectors are compatible with HDCP copyright protection.
If anyone have found a solution please post it
post #828 of 828 Old 01-22-2008, 08:54 AM
David Bott's Avatar
Liked: 45
NEW THREAD STARTED BASE ON IT'S RELEASE.
http://www.avsforum.com/avs-vb/showthread.php?t=981683
David Bott
Founder - AVSForum
DISCLAIMER: All spelling and grammatical errors done on purpose for the proofreadingly challenged...:)
David Bott is offline
Closed Thread Home Theater Computers
