Progressive Scan and Upscaling on HTPC - possible? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-25-2007, 03:52 PM - Thread Starter
Healey3000's Avatar
Hi,
Is it possible to have the HTPC play standard DVDs and upscale to the TV's native resolution? If so, this would allow me to ride out the HD and Blu-Ray format struggle. I know that Oppo makes a player that can do this but I'd rather just wait for the high def player.
Assuming that the hardware is capable, is there software that makes this possible?
Adnan
Healey3000 is offline
post #2 of 4 Old 09-25-2007, 04:01 PM
bulls's Avatar
Quoted: 155 Post(s)
Liked: 92
todays computer screens are "HD" (in a bestbuy definition)... 1280x1024... uh.. 1024p
so dvd video gets scaled up to the displays resolution by whatever software/codec/vidcard used in playback. ffdshow does a good job, mpc's internal codec does a good job, cyberlink's codec does a good job. i cant see a detail difference, just the way they play with colors, brightness, contrast. and cpu cycles.
display - vizio p65
AVR x4300h +lepai 2ch amp = 7.2.4
L/C/R - Chane 2.4, SURROUND - dayton 3in cubes *temporary
BASS - 2x Seaton F18, MBM - 2x Behringer 1200
2100 ft^3
bulls is offline
post #3 of 4 Old 09-25-2007, 04:29 PM
nm88's Avatar
All players/video cards will do that.
How so? Resizing the image doesn't add any new detail. You're still stuck with DVD resolution, it's just that pixels are duplicated and averaged to make it fit on your screen.
nm88 is offline
post #4 of 4 Old 09-25-2007, 04:40 PM
Ian Fleet's Avatar
I think the Nvidia Pure video codec with ffdshow and zoomplayer or Theatertek does an excellent job, provided the source dvd is a good transfer.
I thought The Lord of the Rings extended version looked fantastic.
There is however no comparison to an upscaled dvd and a HD-DVD using a 360 addon.
Even a mediocre HD-DVD transfer looks better than a upscaled dvd. I'm playing films on a 110" diagonal screen so artifacts stand out with dvd's.
Ian Fleet is offline
Reply Home Theater Computers
