Off the Shelf HTPC? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-29-2007, 01:38 PM - Thread Starter
Jellyman's Avatar
Would it be reasonable to assume that I could walk into any Best Buy or Lets say Circuit City and purchase a perfectly functional HTPC that would be used to record OTA HD programs using Windows Media Center with an Xbox 360 as my extender.
Ben
Jellyman is offline
post #2 of 5 Old 09-29-2007, 01:41 PM
valkyrie's Avatar
As long as it has an ATSC tuner, yes.
http://http://www.bestbuy.com/site/o...=1179877267931
For example.
valkyrie is offline
post #3 of 5 Old 09-29-2007, 02:04 PM
umdivx's Avatar
Ben
As long as its running windows MCE 2005, or Vista home premium or vista ultimate, and as already said has an ATSC tuner.
But even then if you bought a bran new pc with say vista home premium but it didn't have a tuner card you can easily add on after the fact.
- Josh
umdivx is offline
post #4 of 5 Old 09-29-2007, 02:09 PM - Thread Starter
Jellyman's Avatar
Thanks for the reply.
I'm ready to bite the bullet and cut the Satellite cord. Just wanted to be assured I would have a pleasant experience and not be dealing with choppy video and the such.
Jellyman is offline
post #5 of 5 Old 09-29-2007, 02:11 PM
umdivx's Avatar
well choppy video can be caused by several things, weak signal, multipath signal, under powered video card, ect...
so its not going to be 100% out of the box, but with the help on the fourm here you can be assured you can find the help you need to get it working.
- Josh
umdivx is offline
Reply Home Theater Computers
