HTPC tuners not getting the same channels as my HDTV's. Recommendations? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-02-2007, 07:30 PM - Thread Starter
RebuL's Avatar
I have 2 Hauppauge 1600 hybrid tuners in my HTPC....and currently am getting 7 digital over the air channels from the nearest broadcast towers (about 19miles away). Only 1 of those are actually an HD broadcast. So, I put a larger antenna on my roof recently in hopes to pick up more channels from Richmond, VA (about 70miles away). I can now get Fox HD out of Richmond...but only on a clear day. Bummer.
BUT...If I hook up my antenna directly to my Panasonic Plasma's ATSC tuner (bypassing my HTPC), I get ABC, CBS, FOX, PBS, and NBC all in amazing HD. Fantastic!! They come in perfectly, even on a cloudy day.
I use my HTPC, as my DVR...and REALLY want to get these channels.
So it seems, that my Hauppauge 1600's are just not good at picking up the signals as my HDTV's tuner.
Is there anything I can do to improve my Hauppauge 1600's reception?...or can anyone recommend another card that I switch too?
I am switching soon from my Geforce 7900GT to a 8500 in my HTPC. Is there a chance that will improve my issue since the 8500 handles HD better?
RebuL is offline
post #2 of 7 Old 10-02-2007, 10:18 PM
Healey3000's Avatar
Hi,
I have no experience with the 1600 but I am using a Cats Eye 150 and it pulls in all the area channels. That doesn't mean that it's a better card but if you are looking for an alternative, this Vbox product is worth trying.
I believe Vbox was the original reference standard chosen by Microsoft when it was looking at this area, or so I've read and is probably excellent hardware. The down side is that it comes with no multimedia software so you'll need something. I use BeyondTV with mine.
Adnan
Healey3000 is offline
post #3 of 7 Old 10-02-2007, 10:21 PM
Healey3000's Avatar
You aren't by any chance using a splitter on your antenna cable are you? If the 1600 didn't do too well, it may be the fact that you have split the signal. Your statement of hooking the TV directly prompts the question. A direct feed to the TV may indeed be better. Compare the 1600 with the TV simultaneously while both are on a splitter.
Hope that helps,
Adnan
post #4 of 7 Old 10-03-2007, 01:23 AM - Thread Starter
RebuL's Avatar
I am using a splitter in order to divide the line to the 2 seperate 1600's....but...I'm still using a splitter when I plugged the antenna directly to my TV (I just unplugged one of the coax wires directly out of the 1600 and then plugged it into the TV.)
RebuL is offline
post #5 of 7 Old 10-03-2007, 06:53 AM
umdivx's Avatar
If your looking for alternative tuners, Vbox, Avermedia A180 or the M780, or the newer VistaView Saber DA-1N1-I
The vista view and the M780 have a better LG demodulator where as the HVR-1600 uses a slightly less than stellar conextant demodulator.
But before you go down the route of a different tuner card try taking the the splitter off and doing a single coax straight into one tuner card and see if that makes a difference at all.
also no a video card change won't help make the reception better.
- Josh
umdivx is offline
post #6 of 7 Old 10-03-2007, 07:15 AM
jhhoffma's Avatar
From what I remember reading on MissingRemote (and on here as well),
The Hauppauge 1600 uses an older chip that is not as sensitive as the one in newer cards (and HDTVs?).
For your PC silencing needs...check out www.silentpcreview.com
For your WHS needs...check out www.wegotserved.co.uk
jhhoffma is offline
post #7 of 7 Old 10-03-2007, 07:19 AM
umdivx's Avatar
umdivx is offline
Reply Home Theater Computers
