Can anyone help me figure the best way to display my PC to my HDTV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-02-2007, 07:45 PM - Thread Starter
Nitrosoxide's Avatar
Anyways I was wondering if anyone could help me out with suggestions
My PC has
Video card: Mobile Intel 945GM Express Chipset Family
which includes
Intel® Graphics Media Accelerator 950
The following plugs are available
* 4 USB 2.0 ports
* 1 FireWire
* 1 VGA monitor port
* 1 S-Video port for connecting to a TV
* 1 PCMCIA (or PC Card) slot (Type I/II, 32-bit)
* 1 ExpressCard/54 Slot (also supports ExpressCard/34)
* 1 headphone jack
* 1 microphone jack
* 1 Expansion Port 2 connector
* 1 IR receiver
My TV is a Toshiba 32HL57
& has the following
2 Colorstream HD
2 HDMI
1 Regular A/V Cable input (Red, White, Yellow + S-video)
1 VGA PC IN (With Red-White audio inputs)
However, VGA doesn't look so great and its now used for my DC
Currently My TV has all cable inputs used up except for
1 Colorstream HD
and the 1 Regular A/V Cable input (Red, White, Yellow + S-video)
So I'd perfer to make use of those.
Of course any suggestions would be great.
What is my best solution to get the best picture possible.
Nitrosoxide is offline
post #2 of 3 Old 10-03-2007, 04:42 AM
4Dthinker's Avatar
You can find VGA to component convertors out there. That may be your only shot for high resolution. I've got a component to VGA convertor, so I can watch my DirecTV on a computer monitor. Should be doable in reverse.
4Dthinker is offline
post #3 of 3 Old 10-03-2007, 06:47 AM
umdivx's Avatar
you'd be better off getting a video card that supports component video out than finding and using a vga to component converter box.
- Josh
umdivx is offline
Reply Home Theater Computers
