MPC HC won't disable subtitle in mkv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-09-2007, 11:04 AM - Thread Starter
Spider2k7's Avatar
Hi Everybody,
i have a problem with my media player classic home cinema version under windows vista, when i select evr custom pres under output and activate direct 3d fullscreen (for removing tearing) and pixelshader 2.0, i can't disable any subtitle. everytime when i load a mkv-movie, i always see the subtitles, but i don't need them. what can do, to disable them?
i always looked for playback options and disabled auto-load subtitles, but nothing happend.
Spider2k7 is offline
post #2 of 11 Old 10-09-2007, 11:20 AM
Wicked Klown's Avatar
If the subtitles are hardcoded you will not be able to get rid of them. Seeing as you didn't say if they were I'm guessing they are.
Wicked Klown is offline
post #3 of 11 Old 10-09-2007, 11:26 AM - Thread Starter
Spider2k7's Avatar
they aren't hardcoded, because in the normal mpc i can disable them.
post #4 of 11 Old 10-09-2007, 11:37 AM
blingo's Avatar
In haali Media Splitter tray icon you can disable them in there. I had the same problem, and you dont need to use the direct 3d, if you use that it wont let you right click while the movie is playing. It doesn't effect the PQ. I was told this on doom9 forum.
blingo is offline
post #5 of 11 Old 10-09-2007, 11:39 AM
herm4n's Avatar
maybe report your problem in this thread....
greets, riding herm4n
herm4n is offline
post #6 of 11 Old 10-09-2007, 12:29 PM - Thread Starter
Spider2k7's Avatar
well, i am not using haali, i use coreavc, is there an option to disable subtitles, too?
when i disable direct 3d, is the anti tearing option off too?
post #7 of 11 Old 10-09-2007, 01:42 PM
trevisthomas's Avatar
I'd bet that you're using haali. CoraAVC wont split the video out of an mkv container. Haali does that and then coreAVC decompresses the x264 stream.
To see, just play an mkv and look at your task bar near the clock. If haali is running you''ll see the icon appear. Also, i'd bet that you're using DirectVobSub (vsfilter.dll) for the subtitles. It probably also appears near the clock. (it's a weird green arrow looking icon.)
You probably have the autoloading version of vsfilter registered on your box so whenever it sees subtitle content in the mkv it shows it. You should be able to configure it to come on when you want to use it but if not you can also unregister the vsfilter.dll component and then you'll never see subtitles.
the command to unregister it is something like
regsvr32 -u vsfilter.dll
trevisthomas is offline
post #8 of 11 Old 10-09-2007, 02:52 PM - Thread Starter
Spider2k7's Avatar
merci, i will test it tomorrow and report here, if it works or not.^^
post #9 of 11 Old 10-10-2007, 09:43 AM - Thread Starter
Spider2k7's Avatar
well i looked for an icon in the task bar near the clock, during playing an mkv video, but there wasn't an icon from haali or else.
but i fixed the problem on my own way, i disabled direct3d to get into menu of mpc and than disabled the subtitles, after that i go back to direct3d with no subtitle in any movie.
so thank you all for helping me! :-)
post #10 of 11 Old 10-10-2007, 09:50 AM
arfster's Avatar
MPC has an internal mkv splitter, it'll use that by default.
arfster is offline
post #11 of 11 Old 03-18-2009, 08:19 PM
jb_alphamale's Avatar
i disabled from Haali. It worked for me.Thank you blingo.
jb_alphamale is offline
Reply Home Theater Computers
