Show Your HTPC Setup - Page 27 - AVS Forum | Home Theater Discussions And Reviews
 31Likes
Old 11-28-2011, 02:53 PM
DemBums's Avatar
Originally Posted by Soulforger View Post
Hi all!
First off: Very nice setups here!
Just got my humble setup running... for the time being
TV is a 32" cheap Phillips... Upgrade coming some time in the future.
Audio is cheap 2.1 Logitech... Upgrade coming some time in the future.
Controlled by Logitech numpad, but next week I'm upgrading to Harmony 700.
Inside the HTPC I have Zacate platform with 2 x 1 tb hard drives and a 2 tb WD external hard drive sits on top of it.
I built the HTPC inside an old radio... It came out reasonably nice
Dig the setup and your style. I'm going to have to do something like this.
DemBums is offline
Old 12-03-2011, 08:26 AM
omgitswes's Avatar
This thread is inspiration....too bad I wont be able to start a main HTPC setup until after I graduate and get my own spot.
omgitswes is offline
Old 12-12-2011, 05:08 AM
diytoolcity's Avatar
home theater @ my condo
diytoolcity is offline
Old 12-12-2011, 11:00 AM
scoyne88's Avatar
Can't see your photo
Before you criticize someone, you should walk a mile in their shoes.That way, when you criticize them, you're a mile away and you have their shoes.
DIY Speaker Cables
http://www.seancoyne.org
scoyne88 is offline
Old 12-21-2011, 02:29 PM
ajcast5201's Avatar
Here's an update to my previously posted setup:
TV: Vizio 47" 1080p 60hz LCD TV
AVR: Onkyo HT-S6300 7.1 System (Only using 5.1 since room is too small)
HTPC:
Case - nMedia 5000b HTPC Case
Ram - 4GB DDR2
CPU - AMD Phenom 9750 Quad Core
Motherboard - Gigabyte GA-MA785GM-US2H
Video Card - Sapphire Radeon 6670 Ultimate (fanless)
Remotes:
Logitech Harmony One
Lenovo N5902
Front-end Software - XBMC (Aeon Nox Skin)
The major upgrades I've made are the video card and the surround setup. With the new video card, I can play most games at high settings, and with the receiver, I can get surround sound when playing games over HDMI. Movies sound better as well (compared to the Logitech Z-5500).
Happy HTPC'ing!
ajcast5201 is offline
Old 12-21-2011, 05:31 PM
clubwerks's Avatar
Quoted: 78 Post(s)
Liked: 45
Here's my setup:
Epson 6500UB w/ 115" homemade AT screen:
DirecTV HD DVR, HTPC, Pioneer Elite VSX-94TXH
HTPC w/ Latest XBMC nightly using MPC HC/madVR/LAV Filters for HD playback
AMD Phenom II X4 3.2
Gigabyte GA-990FXA-UD3 Motherboard
16GB G.Skill Ripjaws DDR3 RAM
XFX HD-667X-ZWF4 Radeon HD 6670 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready Video Card
LG Black 12X BD-R 2X BD-RE 16X DVD+R
SilverStone LC20-B Aluminum HTPC Case
SeaSonic M12II 620 Bronze 620W ATX12V V2.3 / EPS 12V V2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
22TB of storage shared through 1 gigabit ethernet to 3 other HTPCs in the house.
clubwerks is offline
Old 12-21-2011, 05:38 PM
clubwerks's Avatar
Quoted: 78 Post(s)
Liked: 45
Holy cow my camera lens is dirty.
Old 12-21-2011, 06:02 PM
ajcast5201's Avatar
You're able to get HD audio bitstreaming with XBMC? IS there a tutorial on how to do it, or could you briefly explain the settings needed to decode HD audio. Amazing setup by the way! Definitely what I want to have when I own a home. Keep up the great work.
Old 12-21-2011, 06:29 PM
clubwerks's Avatar
Quoted: 78 Post(s)
Liked: 45
I've read about a lot of people having problems, but it really couldn't be easier. I have it working on two different machines that are hooked to AVRs. Here's my steps, both machines have AMD 6xxx video cards.
Download the latest versions of 32 bit MPC HC, LAV Filters, madVR (optional).
I also use ReClock, but I believe it's completely unnecessary and it works 100% fine without it.
If you have ffdshow audio, shark's, etc, delete it.
Now, I'm going totally by memory, but there's a ton of tutorials and a lot of help out there.
1. Install LAV filters. Install MPC HC. If you use madVR, extract it into it's own folder and run the install.bat.
2. Open MPC HC and pick your renderer under options>output. I click madVR.
3. Under fullscreen I turn off autochange. The main reason I use madVR is because I think it does a better job of switching my projector to the proper format than autochange.
4. Under Internal Filter, I deselect EVERYTHING.
5. Under External Filters, I add LAV Splitter Source, LAV Splitter, LAV Video Decoder and LAV Audio Decoder.
6. Double click LAV Audio and under bitstreaming select every format that your AVR supports. I select DD, DD Plus, DTS, TrueHD and DTS-HD.
That's pretty much it. There's a ton of PQ tweaks you can make to madVR and I'm sure my settings would be much different than yours. But for bitstreaming audio, that's pretty much it. Works perfectly with all formats from LPCM to DTSHD to TrueHD.
If you using XBMC, you'd just need to set up the config files to use an external player, which again is very easy and there are a million tutorials on how to do that too.
Old 12-21-2011, 08:19 PM
ajcast5201's Avatar
Worked like a charm on MPC HC! Thanks!
Old 12-21-2011, 08:41 PM
clubwerks's Avatar
Quoted: 78 Post(s)
Liked: 45
FWIW, now that it's working on MPC HC with LAV filters, you could download the XBMC DS Player version that's floating around and configure it to using LAV filters for your HD files. That works well too and there's no need to reconfig the filters you already have setup.
Old 12-21-2011, 08:53 PM
ajcast5201's Avatar
Found the link for the latest DSPlayer build, but it seems like you still have to deal with XML (not my forte) in order to set the filter.
Not to be a mooch, but do you know how to set the filters on the DSPlayer build? Thanks.
Old 12-22-2011, 11:14 PM
GreenEyez's Avatar
See my posts here for 2 combos, LAV Splitter + LAV Audio + LAV Video Decoder with CUVID or LAV Splitter + LAV Audio + MPC decoder for not Nvidia cards.
http://www.avsforum.com/avs-vb/showp...postcount=1347
http://www.avsforum.com/avs-vb/showp...postcount=1348
GreenEyez is offline
Old 12-23-2011, 02:30 AM
stevethebrain's Avatar
Quoted: 97 Post(s)
Liked: 25
Originally Posted by MarkTX View Post
Hi guys, after a lot of RMA's with the speakers going through different brands, this is my final working build:
TV: Samsung UN60D6400
PC: build by me self, AMD Phenom II X4 905e 65 watts onboard HD4200 video
AVR: Onkyo TX-NR609
Speakers: 7.1 setup: Energy CF30 system ($999 5.0 energy + free premier acoustic sub) plus 2 front height polk OWM3($80)
On its way: Sapphire Radeon HD 6570 1 GB DDR3 HDMI/DVI-D/VGA PCI-Express Graphics Card 100323L black friday deal at $49.99 plus $10MIR just to get some True HD audio and frame packing 3d.
My onboard video works flawlessly even with blu ray rips...it just lacks the True HD audio and 3d frame packing.
cool looking AVR & CC shelf, how did you run the wires?
bet it sounds good.
?why do you have 2 sets of front speakers?
how do you like the OWM3s I'm concidering these as surrounds?
HTPC:
Ram - 4GB DDR2
Remotes:
Lenovo N5902
Happy HTPC'ing!
nice setup.
I'm concidering a nMedia 6000b HTPC Case. is the blue on light disstracting?
Here's my setup:
nice setup. one day I'd like to have a large projecter. how do you like the Epson and how is the PQ compared to a regular 1080TV?
since projectors don't have TV tuners is the HTPC w/ TV tuner all thats required to use the projector as a regular TV?
also the 2 small pieces ontop of HTPC is that a wireless part of the projector?
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS biggest POS I've ever had Remote: Harmony 700
stevethebrain is offline
Old 12-23-2011, 06:44 AM
GreenEyez's Avatar
The small one (piece) looks like you average IR receiver for the remote plugged into and extension cable.
Old 12-23-2011, 08:10 AM
ajcast5201's Avatar
Originally Posted by stevethebrain View Post
nice setup.
Not really, since the HTPC is off to the side and tucked behind the couch. But if you were going to place it front and center, I'm sure there's a way you could disable it.
Old 12-23-2011, 10:14 AM
clubwerks's Avatar
Quoted: 78 Post(s)
Liked: 45
The small one is the receiver for my Rii keyboard in an extension USB plug and the big one is the RC6 receiver for my Harmony remote.
Old 12-24-2011, 07:08 PM
digital desire's Avatar
The business end of the man cave. HTPC is lower left on the rack. The 70" sharp was my xmas present to myself. All the speakers are DIY, and the amps are in another room.
Lot's of low rent stuff stacked up into a medium rent pile.
digital desire is offline
Old 12-25-2011, 05:45 AM
thewarm's Avatar
Very nice!
2 subs? (one down-facing and one front facing?)
thewarm is offline
Old 12-25-2011, 03:45 PM
The one whose face you don't see is an 18" maelstrom pointed towards the wall. Now no longer made, and thus irreplaceable. Both subs powered by their own 2 kilowatt amp.
Old 12-26-2011, 09:11 AM
ajcast5201's Avatar
Thanks! I got it to look like it does in your screenshot. However, the FPS is down to about 18 or 19. Any idea why? Is there a fix for this? Thanks for the help.
Old 12-26-2011, 09:41 AM
GreenEyez's Avatar
Is actual playback smooth? Because the FPS on DSPlayer also goes haywire on my sistem, but playback is normal. I think it`s a bug.
Old 12-26-2011, 12:00 PM
ajcast5201's Avatar
Ahh I see...it was pretty good..I'll play around with it some more.
Old 12-27-2011, 02:27 AM
cdrsteve's Avatar
Very nice setup. How do you like the 70" Sharp? I am considering the 70" or 80" to replace my aging Samsung DLP. What stand are you using for the Sharp? Thanks.
cdrsteve is offline
Old 12-27-2011, 09:28 AM
lovswr's Avatar
Quoted: 36 Post(s)
Liked: 24
Send a message via AIM to lovswr
DD, I love that woodworking on those cabinets. Someday I hope to have the space, tools, & inclination to do something like that myself.
carry on with your HD-Lite Directv loving banter! <--Comedy Gold
Don't fall for the HDMI 1.3 Hype!
PSN = lovswr
XBOX Live = lovswr
lovswr is offline
Old 12-27-2011, 01:04 PM
Thanks on the woodworking, but I have to confess: I have a Brother in Law who is a very close approximation to Norm Abrams (PBS New Yankee Workshop), shop and all. No way could I output anything like that left to my own devices! The MDF work on the towers/center was done by a professional, I just printed out the plans (LONG thread on HT guide missions acomplished section wwmt's) and had the cabinets made. I veneered them in solid oak, and made the crossovers ($$!) wiring, etc. MY BIL and myself made the subs, they each weigh in over 150 lbs, not including the amps in the other room.
I *LOVE* the sharp 733! For a long time Sharp seemed to be a lagger on the LCD front, and now it seems they took the lead. I also have a 52" sammy 750 which this replaced (the 52" now resides in family room) The sammy was/is a quality display also, with CFL back lighting. I consider the Sharp at least as good.
The stand is a Bello, but I can not find the exact model anymore. Might be discontinued. Since that center speaker weighs close to 100lbs, I needed something stout, and even then, I put in a re-enforcement in the middle to support the weight. I think it is similar to this:
http://www.bello.com/index.php?parti...80&categ_id=39
I also modified it by mounting a sheet of 3/4" plywood for the tv mount, and then mounted a conventional wall mount to that to support the 70" sharp. The TV mount that the stand came with did not have the spacing big enough to mount the 70". However, it speced being able to support the weight. Seems to work great, I have no worries about it.
EDIT: Actual pic of the HTPC. Love the silverstone case, has the perfect HT look. Also a pic of the maelstrom sub. We went with the same round over on all the cabinets for an integrated look. The subs are powered with sound re-enforcement amps that have fans, so they (and the emotiva XPA-5) live in a different room. The piece above the HTPC is an equalizer kit that I put together, designed expressly for sealed subs.
Old 12-29-2011, 11:07 AM
snef's Avatar
only a little update
someone told me, now need a new bigger screen
done!
change my Home theater receiver from a onkyo 608 to a new Yamaha RV-A2010
add a belkin power surge protector
jeffkro likes this.
snef is offline
Old 12-30-2011, 06:41 AM
ff.fahimi's Avatar
done!
Why the receiver change?
What tv is that?
What's at the tip of the picture on the shelf?
What speakers are those?
Sorry so many questions haha
ff.fahimi is offline
Old 01-01-2012, 04:45 PM
scoyne88's Avatar
2011 left me with some new toys
  • Ikea Tobo Tv stand, with Ikea Capita legs
  • 32" Sanyo LCD TV (Next up for replacement)
  • Polk Audio Monitor 70's Bi-Amped
  • Polk CS2 Center
  • Polk RM8 surrounds
  • Polk PSW10
  • Aura Bass Shakers
  • Onkyo TX-SR608
  • Onkyo M-282 Stereo Amp (For Shakers)
  • HTPC in Nmedia 2000b Case (Soon to be a Wesena e7 case)
  • APC H10 Power Conditioner
  • Harmony 1100 remote
  • Wii
DIY Speaker Cables
scoyne88 is offline
Old 01-01-2012, 08:03 PM
FantaXP7's Avatar
Quoted: 43 Post(s)
Liked: 36
  • Polk CS2 Center
  • Polk PSW10
  • Aura Bass Shakers
  • Onkyo TX-SR608
  • Wii
Very nice, I wonder though, why didn't you try and put the center channel above the drawer?
FantaXP7 is offline
