Show Your HTPC Setup - Page 35 - AVS Forum
 2Likes
post #1021 of 1046 Old 11-25-2013, 02:02 PM
laverdure's Avatar
@krisz8ball:
Nice build indeed! Would also be curious to know your components and what temps you are getting while gaming...
Also, are you using the bottom 3 fans slots at all? For intake maybe? I have the same case and since Silverstone designed this case for positive pressure, I have 3 bottom and 2 side 120mm as intake, and the two 80mm at the back for exhaust. But my CPU idle temps are more like 40-45oC...Your setup seems to be better temperature-wise. Thanks in advance for more details you can share!smile.gif
laverdure is offline
post #1022 of 1046 Old 11-25-2013, 02:49 PM
Djoel's Avatar
Quoted: 46 Post(s)
Liked: 162
Originally Posted by laverdure View Post
@krisz8ball:
Are you using yours for gaming, or just server, movies, and such? I've been reading some Amazon reviews and there's this one guy who happen to use all the bays, 8. 3.5 Hdd and the 2 optical as well, how about yourself did you get use all the bays?
That sounds like it might get hotter than in most situation.
Djoel
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Djoel is online now
post #1023 of 1046 Old 11-26-2013, 12:29 AM
nexxest's Avatar
Liked: 26
Meet Monster, my 132 lb HTPC:
This is an ATX motherboard (not a joke):
More pics here: http://www.avsforum.com/t/1495291/silent-htpc-gaming-rig-build-many-pics
Silent
3-way
nexxest is offline
post #1024 of 1046 Old 11-26-2013, 06:29 AM
laverdure's Avatar
Djoel
No no, not using 8 HDD, not that much media. Yet. Though i use it as TV/Movies/Game/Server, I only have 3 x 3.5"HDD, 1 x 2.5" HDD, 1 SSD and one OD. So it's not that cramped and I feel there should be enough airflow for the CPU to idle in the 30s instead of the 40s...Have a noctua NH-C14 as CPU cooler, does not get bigger than that for this case! wink.gif Might try to re-seat the cooler or change the side fan to exhaust during the holidays... It's okay though, it's not like it's out of control, I remain in the mid-70s under full load.
Djoel likes this.
post #1025 of 1046 Old 11-26-2013, 08:07 AM
Djoel's Avatar
Quoted: 46 Post(s)
Liked: 162
Sounds an awesome machine, have some pics on this thread?
Dan
Djoel is online now
post #1026 of 1046 Old 11-26-2013, 05:44 PM
colo1's Avatar
Love youre build and love the chocolate wall and and everything goes well together enjoy
colo1 is offline
post #1027 of 1046 Old 11-27-2013, 03:45 AM
krisz8ball's Avatar
Thank you for all the recognitions
My components:
Case: Silverstone DG08
Power Supply: Enermax Liberty Eco 500w
Motherboard: MSI ZH77A-G43
CPU: Intel i5-2310 @3200mhz (Cooler: Scythe Mini Ninja)
RAM: Kingston 2x4gb ddr3 1600mhz hyperx T1
VGA: ASUS GTX650TI-DC2O
Soundcard: Asus Xonar DX
Fans: Coolink Swif2-1200, Swif2-800, Swif2-80p (Y fan cables)
The CPU is dynamic so for example when I'm on the Internet the CPU clock is runing 1.57ghz (average), and same with any compontet when you see a specification of a VGA thats says 150W means it's eating 150W when 100% load. So my electricity bills is not high at all :)
@laverdure
I'm not using the bottom fans, If I do I'l get a 2-3°C better overall temps. The reason I don't use it is because of the Dust, it has filter of course but it's a pain in the @ss to take them off every month.
I'l put up the Gaming temps shortly.
@Djoel
I only have one Hard Drive but I'm plaing to replace it next month, the temp will be different. 8 HDD generating massive heat, probably because they are too close together, but the bottom fans would help greatly and the number of exhaust fans. If you would use for example: 4 HDD and instaling them every 2 slots you will have spece between them and that would make differenc as well. The most heat generating in my system is the CPU and the VGA.
My build is mainly for Gaming and Movies, it's silent so its good for anything.
Djoel likes this.
krisz8ball is offline
post #1028 of 1046 Old 11-27-2013, 04:08 AM
krisz8ball's Avatar
@laverdure
My temperatures when I play Far Cry 3, room temp. 22°C.
Ignore the RPM it's showing unreal values beccause my AIDA64 is to old for my motherboard.
post #1029 of 1046 Old 11-27-2013, 04:33 AM
krisz8ball's Avatar
The next time I put up images of my setup will hopefully be when I finished the floating wall project.
Recently taken photo:
post #1030 of 1046 Old 11-27-2013, 05:00 AM
Djoel's Avatar
Quoted: 46 Post(s)
Liked: 162
My components:
The CPU is dynamik so for example when I'm on the Internet the CPU clock is runing 1.57ghz (average), and same with any compontet when you see a specification of a VGA thats says 150W means it's eating 150W when 100% load. So my electricity bills is not high at all smile.gif
@laverdure
@Djoel
Thanks for info, I love it...I also plan on adding more HHD one day, so I plan on changing both bottom fans. How do you like your sound card, any reason why you did use the Intel i5?
Thanks very cool build.
Djoel
Djoel is online now
post #1031 of 1046 Old 11-27-2013, 05:55 AM
krisz8ball's Avatar
@Djoel
 "any reason why you did use the Intel i5?" - for Counter-Strike: Global Offensive :D and I play a lot of Strategy games and to my knowledge a good CPU is impoartant to games like those.
For my Soundcard, I love it, love the sound quality it brings to my 5.1, no problem with drivers (unlike like with Creative) and the PCI 1x plug -> I can plug it to a VGA slot (PCI 16x) if I want to, for some motherboards it a good thing because it's further away from the VGA.
Thanks again
8ball
post #1032 of 1046 Old 11-27-2013, 06:06 PM
ikkuranus's Avatar
Quoted: 14 Post(s)
Liked: 24
@Krisz8ball which logitech speaker set is that? Please tell me it's not the Z-5300e.
ikkuranus is online now
post #1033 of 1046 Old 11-27-2013, 11:15 PM
krisz8ball's Avatar
@ikkuranus
Logitech Z-5300, the simple, á la natur version, without the "e"
post #1034 of 1046 Old 11-28-2013, 12:32 AM
ikkuranus's Avatar
Quoted: 14 Post(s)
Liked: 24
@ikkuranus
Does the non e version sound as terrible as the e? ie all bass and not much for mids and highs?
I only ask because I used to have them and ended up selling because of that.
post #1035 of 1046 Old 11-28-2013, 04:28 AM
krisz8ball's Avatar
Not at all, as far as I know the difference between them is the Color. Could it be that your soundcard had problems ?
I had a Creative X-Fi back in the days and now I have the Asus Xonar DX and it a blesing compared to the Creative and what your saying thats "all bass" I had that problem with Creative !!
post #1036 of 1046 Old 11-28-2013, 04:37 AM
krisz8ball's Avatar
@ikkuranus
I looked into it and The difference is only the Color, nothing more !!!
post #1037 of 1046 Old 11-30-2013, 05:27 PM
wraslor's Avatar
Here's a few shots of my setup that's finally coming to completion.
rikardo1979 likes this.
wraslor is offline
post #1038 of 1046 Old 12-02-2013, 06:26 AM
sdolen's Avatar
Very nice! I couldn't sleep at night knowing that Freddy was in there though! eek.gif
sdolen is offline
post #1039 of 1046 Old 12-03-2013, 05:13 PM
wraslor's Avatar
At my old place it was outside my bedroom door, one night about 4 am i went to get a drink, opened the door and about gave myself a heart attack lol.
There's also 2 predators, an alien, and an iron man over on the side that aren't all set up yet so not pictured.
wraslor is offline
post #1040 of 1046 Old 12-03-2013, 11:34 PM
lovekeiiy's Avatar
Liked: 29
Originally Posted by wraslor View Post
At my old place it was outside my bedroom door, one night about 4 am i went to get a drink, opened the door and about gave myself a heart attack lol. ..
Be glad you were awake. I've heard and seen you don't won't be dreaming about him.
lovekeiiy is offline
post #1041 of 1046 Old 04-22-2014, 07:07 PM
Afroteddy's Avatar
4 months and no new pics. This thread was my inspiration.
Afroteddy is offline
post #1042 of 1046 Old 04-27-2014, 07:36 AM
JamesVG81's Avatar
Here is my new setup and new rack. Server is just 7tb right now. Has 12 hot swaps for drives, it's a i5 750. The HTPC is a x79, 3930k @ 4.5ghz with a amd 290 at the moment, looking to add a second one. HTPC is on top and server is on bottom. I'll be adding water cooling to the rack here soon for the HTPC.
JamesVG81 is offline
post #1043 of 1046 Old 04-28-2014, 11:30 AM
krisz8ball's Avatar
I finally built my own "Floating Wall" and I replaced my Z-5300 to a Z906, here are some pictures of the construction:
Final construction
post #1044 of 1046 Old 04-29-2014, 07:22 AM
sdolen's Avatar
Wow! Very cool! I might have to do something like that for my bedroom and now I have the inspiration, thanks!
sdolen is offline
post #1045 of 1046 Old 04-29-2014, 02:48 PM
Charles R's Avatar
Liked: 188
Here's a shot of my dedicated room's NUC. I was using OpenELEC via a USB flash drive (very nicely) but recently switched to Windows 7 (since I had a license sitting around). I appreciate the internal support for a 2.5" HD or SSD but the DisplayPort and mini HDMI outputs I could do without. Requires converter cables... one goes directly to the projector and the other to a AV receiver. The internal IR sensor works although I'm using a USB one as the NUC is tucked away in the closet. Only the receiver and 1080p monitor located in front of the NUC is exposed to the room. I use the monitor (and remote access) in lieu of the projector when possible.
Charles R is offline
post #1046 of 1046 Old 09-14-2014, 08:20 AM
krisz8ball's Avatar
A little update on my HTPC setup: I bought a new VGA – Asus R9 270x Directcu II (super quiet). Fixed the cable management, and the biggest change is I repainted the Floating wall. Heres some images, please enjoy!
Reply Home Theater Computers
User Tag List
