Show Your HTPC Setup - Page 36 - AVS Forum | Home Theater Discussions And Reviews
 19Likes
post #1051 of 1062 Old 01-01-2015, 01:13 PM
w1retap's Avatar
Quoted: 52 Post(s)
Liked: 51
Thank you. After moving into a new house, I figured it was time to do all the computers in one central location and just run HDMI/USB over ethernet extenders while the house was empty and before everything was painted. I'm pleased with the way everything works. People were skeptical with the HDMI over ethernet dropping out, but I have had zero problems.
If anyone wants to know the parts I used, here's the links from Monoprice. I used 24awg CAT6 for the runs. Tested with 1080p 3D SBS and that works as well.
HDMI over CAT5e/CAT6
Product Number: 6532 http://www.monoprice.com/Product?c_i...seq=1&format=2
USB over CAT5e/CAT6
Product Number: 6042 http://www.monoprice.com/Product?c_i...seq=1&format=2
w1retap is offline
post #1052 of 1062 Old 02-24-2015, 03:08 AM
sbowers2's Avatar
This is my current HTPC build:
MB: GIGABYTE GA-F2A75M-HD2 (rev. 3.0) FM2+ AMD A75 uATX
APU: AMD A10-7700K
Cooler: Thermalright AXP-100 (silent, and able to shift for tight fit)
RAM: G.SKILL Ares 16GB (2 x 8GB) DDR3 2133 C10
GPU: XFX R-250 (best 1/2 height for A10-7700K at the time)
Boot Drive: Crucial M500 120GB SSD
Storage Drive: Western Digital Caviar Green 3TB
Optical Drive: ASUS Blu-ray Drive BC-12B1ST (short depth)
Power Supply: CORSAIR CX430M 80 Plus Bronze
Case: Moncaso 312S – uATX (chosen for stereo component style appearance)
Keyboard: Logitech Wireless Touch Keyboard K400
OS: Windows 8.1 Pro
I have XBMC, but I'm finding Windows does everything faster and easier. I have it set to boot directly into XBMC, but I'm thinking about changing it back.
Name:	HTPC smoke test.jpg
ID:	564865   Click image for larger version
Name:	HTPC completed.jpg
ID:	564873   Click image for larger version
Name:	HTPC in console.jpg
jhughy2010 and southak like this.
sbowers2 is offline
post #1053 of 1062 Old 02-24-2015, 02:22 PM
rikardo1979's Avatar
APU: AMD A10-7700K
OS: Windows 8.1 Pro
you should try OpenELEC if you like Kodi(XBMC), and believe me, you will throw windoze out of window
rikardo1979 is offline
post #1054 of 1062 Old 02-24-2015, 02:30 PM
TornadoTJ's Avatar
Quoted: 853 Post(s)
Liked: 292
Unless you record Copy Once live TV.
I like that case. I have almost that same PSU showing up tomorrow for my new server build, except I got the "Gold" certified 450M.
TornadoTJ is offline
post #1055 of 1062 Old 02-24-2015, 03:14 PM
badgerpilot's Avatar
Quoted: 67 Post(s)
Liked: 40
I have all of my videos on a windows PC and stream to my various windows PC's which run Media Browser. If I went to OpenELEC, will that see my central PC with the videos, or do I have to modify that too? My set up has worked well for the last several years but I would like to see more appliance like reliability.
badgerpilot is offline
post #1056 of 1062 Old 02-24-2015, 03:16 PM
w1retap's Avatar
Quoted: 52 Post(s)
Liked: 51
w1retap is offline
post #1057 of 1062 Old 02-24-2015, 04:17 PM
sure, Kodi can import all your media libraries from what ever share on your network if is SMB, NFS, etc...
so where ever your media are you would be able to play it no changes needed.
post #1058 of 1062 Old 02-24-2015, 04:39 PM
Quoted: 67 Post(s)
Liked: 40
I am just sharing via windows home group via my network. So it looks like I could install OpenELEC and then media browser and skip windows all together? I have a NUC on the way, should be here tomorrow. I want a simple system to replace an older HTPC in the bedroom. Windows sleep function has always frustrated me along with constant updates, etc. I would love to get away from that.
post #1059 of 1062 Old 02-24-2015, 05:13 PM
yes, surely you would be able to do this
simple like never
you install OpenELEC, than browse and add your network shares, it will automatically add all media to libraries, download all media informations etc..
few minutes and you all done
post #1060 of 1062 Old 02-24-2015, 05:34 PM
Quoted: 67 Post(s)
Liked: 40
simple like never
Excellent! Thank you, I'll give it a try over the next few days.
post #1061 of 1062 Old 01-10-2016, 10:00 AM
robertw11's Avatar
Quoted: 69 Post(s)
Liked: 27
CPU: i5 3570k
GPU: EVGA GTX 970 SSC w/ ACX 2.0
Mobo: Asus Z77-A
Ram: 8GB Corsair Vengeance Low Profile DDR3 1600
PSU: Seasonic M12 520w
Storage: Samsung 840 EVO 250GB
Storage: Western Digital Caviar Blue 1TB
Case: Coolermaster Elite 361
CPU Cooler: Corsair H55
Benchmarks by superkamikazee, on Flickr
Not bad given the tight quarters on max setting Assetto Corsa
kevin g., Djoel and jhughy2010 like this.
Kuro'd
robertw11 is offline
post #1062 of 1062 Old 01-12-2016, 06:52 AM
robertw11's Avatar
Quoted: 69 Post(s)
Liked: 27
This is the space the HTPC is in
My other gaming pc, I guess I'd call this the desktop
jhughy2010 likes this.
Kuro'd
Reply Home Theater Computers
