Show Your HTPC Setup - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 37Likes
post #181 of 1085 Old 02-17-2008, 02:34 PM
Jaytradertee's Avatar
Here is my setup.
Jaytradertee is offline
post #182 of 1085 Old 02-17-2008, 08:38 PM
ps-aux's Avatar
The Setup;
Sony Bravia KDL-46XBR4
Denon AVR-4308Ci
Definitive Tech Mythos 8 x3 (Front & Center)
Definitive Tech SuperCube I (Sub)
Definitive Tech RSS II in ceiling (Surround & Rear) not installed yet
Scientific Atlanta 4240HDC
Sony PlayStation 3
Logitech Harmony 890
Media PC;
Case: Antec Fusion Black 430
MB: ASUS P5E-VM HDMI
CPU: Intel E6750 Core2Duo 2.66GHz
RAM: Corsair XMS2 TWIN2X4096-6400C5DHX Dual-Channel
Graphics: eVGA eNForce 8800 GTS 640MB
Audio: HT Omega Claro Plus+
Capture: Hauppauge WinTV-HVR 1800 PCIe
HD: Seagate Barracuda ES ST3750640NS 750GB
DVD: LG GGC-H20L Blu-Ray/HD-DVD Combo
OS: Vista Ultimate x64
APPS: WMC / Power DVD
The pics are sort of old. I had a WIFI card in the media PC before I ran Ehternet to the closet all the components are sitting in now. The WIFI was replaced by the HT Omega after the drop was complete.
TV / Front Surround / Sub
Media Component Storage
Can see the temporary wires for surround and rear speakers until I get back up in the attic to run the permanent wiring for in ceiling surrounds.
Media PC Front
Media PC Front Open
Media PC CPU Bay
Media PC custom hack job on Memory Heat Spreader
ps-aux is offline
post #183 of 1085 Old 02-21-2008, 07:37 AM
Marbles_00's Avatar
Originally Posted by danxmanly View Post
Ok, although I do have a full blown set up in my living room... thought there may be some interest in this smaller version in my bedroom. Of special note is I built this setup within a server chassis I obtained for $79.00. I find pricing ridiculous on the off the shelf HTPC cases when most of them are simply towers thrown on their sides with minor mods. And of course they double / triple the price. I don't recommend a newb tackling their first HTPC using a server chasis, as there was a lot of blood, sweat, and beers.. I mean tears to tackle the metal mods. But for those that don't mind the extra work, it can be quite rewarding... and you'll save a buck or two.
First pic is the original case...
Second shot is the mod'd front with the IMON Media Bay. ( luv it! ) There's a P4 3G oc'd to 3.4 in there, top right is a trayless - removable Hard drive setup I use to back up and transfer movies when my main server in the other room isn't on. I have one removable tray in each of my PC's which is great for transferring 20G + files.
Third is the overall system view. I have a little 100 Watt 5.1 setup which does justice in the confines of the bedroom.
Since I just got engaged I have to pay off the ring before I spend any more $$ on my addictive electronical fixes.. but I will probably rebuild the HTPC in the main room with a server chassis and throw a touch screen in it. Have to time it once the ring's paid off and before the actual marriage! LOL
Keep the systems coming.. hopefully in my dream house I'll have a complete room full of pics to throw up for my home theater!
danxmanly,
Good to see how your using the case. I'm in the midst of building a HTPC, and was able to pick up one of these cases that was collecting dust here at work. The one big mod I was going to do was that it has a hole for an old AT style keyboard connector. I was going to modify it by installing a USB-UIRT in its place, with the receiver in-line with the hole. I was also able to locate some nice feet for it to help make it look more like a peice of audio equipment for cheap. Here's the thread I started on that subject: http://www.avsforum.com/avs-vb/showthread.php?t=993739
Gotta say...these suckers are heavy.
Good to see other's thinking out of the norm.
*EDIT*
Close-up pics or your IMON mod would be great to see.
My web-o-information:
http://sites.google.com/site/maycreates/
Where I discuss the following projects
-DIY multi-zoning music distribution
-HTPC
-MediaPVR
-UnRAID Server
-and other projects
Marbles_00 is offline
post #184 of 1085 Old 03-16-2008, 01:33 AM - Thread Starter
dig8tal's Avatar
bump
dig8tal is offline
post #185 of 1085 Old 03-16-2008, 11:02 PM
yamahaSHO's Avatar
Updated my NSK-2480...
Specs are:
- Antec NSK2480
- GIGABYTE GA-945GCM-S2C
- Core2Duo E4500 w/ Scythe Ninja Mini
- Mushkin 2 x 1GB DDR2 RAM (PC5300)
- EVGA 9600GT SC
- Hauppauge WinTV-HVR-1600 MCE
- LG GGC-H20L
- Seagate Scorpio 2.5" 160GB HDD
- Enermax Liberty 500w
- 2x Noctua NF-P12
- Samsung 32" 720P LCD HDTV
- Vista Home Premium
The LG drive looks out of place, so I ordered a stealth bay from the P160 that should completely hide the bay. It didn't fit as well as I hoped, so now my next step is to dye the front panel black.
Believe it or not, but the Noctua fans are the loudest things in my case, regardless of fan speed.
-Jason
The "Z" Family Theater - Almost "complete".
-Not your average sub build
-Klipsch Sonosub Build
SONY quality and customer service FTMFL
yamahaSHO is offline
post #186 of 1085 Old 07-23-2008, 05:45 AM
Rathbone's Avatar
Quoted: 53 Post(s)
Liked: 25
My new HTPC build:
Rathbone is offline
post #187 of 1085 Old 07-23-2008, 01:39 PM
snuffy1pro's Avatar
Just moved so need to update pics, but here are my old ones.
LW
Buy now before you have kids... I did... Now I have kids... and my toys are now their toys...
snuffy1pro is offline
post #188 of 1085 Old 09-28-2008, 12:02 AM - Thread Starter
dig8tal's Avatar
bump
dig8tal is offline
post #189 of 1085 Old 09-28-2008, 02:48 PM
mr007's Avatar
thanks for the bump,first time i seen this thread.
mr007 is offline
post #190 of 1085 Old 09-28-2008, 09:02 PM
Latinoheat's Avatar
Quoted: 1111 Post(s)
Liked: 877
HTPC- EVO Media center
O.S.- Vista Home Premium
Software -Arcsoft Total Media Theater, Any DVD,Limewire
Tuner- Avermedia combo pci-e hd/quam digital tuner
Processor- Intel Duo-core
Internal HD- 500gb
External HD- Freeagent 500gb
Windows wireless keyboard, vista media center remote
DVD Writer- Pioneer
[IMG][IMG][IMG][IMG][IMG][IMG][IMG][/IMG][/IMG][/IMG][/IMG][/IMG][/IMG][/IMG]
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #191 of 1085 Old 09-28-2008, 09:05 PM
Latinoheat's Avatar
Liked: 877
post #192 of 1085 Old 09-28-2008, 09:10 PM
Latinoheat's Avatar
Liked: 877
LCD- 1080p Sharp Aquos d92
Receiver- Denon AVR 487 w/i pod dock
5.1 surround sound- Denon
HTPC- Evo media center
High definition- Shaw Motorolla
FTA satellite- CNX Duo pvr
1080i DVD player- Denon
Bluray/Gaming- PS3 60gb system
post #193 of 1085 Old 09-28-2008, 09:12 PM
Latinoheat's Avatar
Liked: 877
Showing my Music in Media Center.
post #194 of 1085 Old 09-28-2008, 09:13 PM
Latinoheat's Avatar
Liked: 877
My Movies in media center.
post #195 of 1085 Old 09-28-2008, 09:15 PM
Latinoheat's Avatar
Liked: 877
Adult viewing.
post #196 of 1085 Old 09-28-2008, 09:15 PM
Latinoheat's Avatar
Liked: 877
Vista Home Premium
post #197 of 1085 Old 09-28-2008, 09:17 PM
Latinoheat's Avatar
Liked: 877
Displaying PS3
post #198 of 1085 Old 09-28-2008, 09:17 PM
Latinoheat's Avatar
Liked: 877
Arcsoft Total Media Theater plug in for media center.
post #199 of 1085 Old 09-29-2008, 05:31 AM
yamahaSHO's Avatar
Latinoheat - You know you can put all those pictures in ONE post, right?
-Jason
post #200 of 1085 Old 09-29-2008, 06:32 PM
Latinoheat's Avatar
Liked: 877
Yeah I know, but it didn't work when I did it. That's why it shows IMG,IMG....
post #201 of 1085 Old 09-29-2008, 08:30 PM
Fragster's Avatar
Quoted: 27 Post(s)
Marantz VP4001 720p DLP PJ
120" WilsonArt DIY screen
Polk Speakers
12" Dayton Sub
Onkyo 504 AV
PS3
Gigabyte 780G+AMD 4850e combo....HTPC racked at the very top of my rack in the corner.
Logitech Wireless k+m
"There are 1 0 kinds of people in this world...one that can read binary while the other that can't!!"
My small HT setup:
http://www.flickr.com/photos/27565515@N04/
Fragster is offline
post #202 of 1085 Old 10-06-2008, 07:32 PM
mr007's Avatar
Originally Posted by latinoheat View Post
adult viewing.
fta ftw
mr007 is offline
post #203 of 1085 Old 10-07-2008, 11:58 PM
Speakerlab's Avatar
Picture #2, another shot of the theater to show the HTPC's location, off to the left of main seating:
ND
Quick question, what shelving or ? is holding the monster guys up top?
Tyler
Speakerlab is offline
post #204 of 1085 Old 10-08-2008, 12:59 AM
nitesky's Avatar
Does, anyone know the name/model of the case Rathbone is using in his pics a few posts up? Looking for a case just like that one and haven't seen it before.
thanks
nitesky is offline
post #205 of 1085 Old 10-10-2008, 10:04 AM
MrMaNz's Avatar
This is a great thread. I love seeing all the different equipment and HTPC's being put to good use. Keep posting guys! I wanna see what you guys are doing with some of the newer hardware out there now.
MrMaNz is offline
post #206 of 1085 Old 10-19-2008, 06:30 PM
Celx's Avatar
Just finished my built. I am happy with it.
nMedia HTPC 1000B with PRO-LCD.
Thermaltake Purepower W0100RU 500W
Gigabyte GA-MA-78GPM-DS2H Mobo
AMD BE-2400 Dual Core CPU
2x1 GB DDR2 800 OCZ Memory
LG Bluray Drive
Vista Home Premium
nMedia HTPCKB-B Wireless combo
Avermedia TV Tuner
Celx is offline
post #207 of 1085 Old 10-19-2008, 10:50 PM
Celx's Avatar
Open and close images of the nMedia HTPC 1000B case.
Celx is offline
post #208 of 1085 Old 10-20-2008, 09:15 AM
JiffOrange's Avatar
A lazer disc player too, thought I was the only one ...don't think mine will last too much longer ...oh well out with the old, I guess. Nice looking HTPC.
Cheers,
Jiff.
JiffOrange is offline
post #209 of 1085 Old 10-20-2008, 10:32 AM
Celx's Avatar
Cheers,
Jiff.
Mine still working great, Karaoke with VCD still generates a lot of funs. Laser discs are gone.
With this set up, I can play Wii, Karaoke, Music, Movie, browsing the web, TV. This becomes the party room in the economic crisis. Cheers
Celx is offline
post #210 of 1085 Old 11-05-2008, 07:22 PM
ND23's Avatar
Quoted: 21 Post(s)
Liked: 114
Tyler
Custom-made half-movie reel display shelves, decorated with a faux countdown filmstrip.
See more here.
ND
ND23 is offline
Reply Home Theater Computers
