Opposite of the Slingbox??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-11-2007, 10:24 PM - Thread Starter
dpslusser's Avatar
I have a tone of media on my computer. Music, pictures, and 500 gigs of backed-up dvds (Ifo/Vob format). I would love to have some type of device connected to my TV, through network or some other means, to the computer and be able to watch them effortlessly. Something for my parents to use without any complaints. SageTV is out of the question. I don't want something that evolved. Radioshack used to sell a device that connected through a network and to your TV and it would access your computers media to display on the TV. It was clearenced out and I can't find it any more.
dpslusser is offline
post #2 of 5 Old 11-11-2007, 11:05 PM
heartlesslova's Avatar
There are what are called "media extenders." I think that's what you're referring to. Something like...
http://reviews.cnet.com/digital-medi...ag=prod.txt.10
http://reviews.cnet.com/digital-medi...1.html?tag=pop
http://reviews.cnet.com/digital-medi...4.html?tag=pop
http://reviews.cnet.com/digital-medi...2.html?tag=pop
I just went with an HTPC, I found the price difference to be minimal. Even with our bloated Canadian pricing, for $450 with tax, I built myself an E2160, 2 GB, P5K-VM in an Antec Fuzion. So, whatever floats your boat really.
heartlesslova is offline
post #3 of 5 Old 11-12-2007, 06:31 AM
PGPFan's Avatar
The device you are referring to that RadioShack had was the Hauppauge MVP (which is still available from Hauppauge) which just happens to be the very same 'hardware' that SageTV uses for their 'extender'. The difference is that Sage runs their own software on the Hauppauge device.
The deal breaker for you is that when using the Hauppauge software, it will NOT playback DVD files (the .ifo and .vob) files due to licensing issues (DVD's can't legally be streamed over a network).
-PGPfan
PGPFan is offline
post #4 of 5 Old 12-26-2007, 06:57 PM
Lattice's Avatar
This is cool, do you know of anything that hooks to the TV and allows you remote access to the PC?
Lattice is offline
post #5 of 5 Old 12-26-2007, 08:29 PM
nightowl2k2's Avatar
You could take a look at buying an old Xbox and install XBMC to play the files. It should work pretty well as long as you are not playing HD content.
nightowl2k2 is offline
Reply Home Theater Computers
