Guide to Building a HTPC, Workstation and Server - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 30Likes
post #991 of 19508 Old 02-02-2008, 12:52 PM
crashdumy's Avatar
Originally Posted by renethx View Post
crashdumy
None of them supports H.264 hardware decode, meaning high CPU usage. Among them G35 is the best, but overpriced (~$135) imo.
- GIGABYTE GA-G31M-S2L + Radeon HD 3450 (total ~$117)
- eVGA GeForce 7100 + GeForce 8500 GT (total ~$142)
is a better choice. You need to buy the ATI proprietary DVI-HDMI dongle for the first choice.
thanks for the advice
crashdumy is offline
post #992 of 19508 Old 02-02-2008, 12:58 PM
tate16t's Avatar
Vista 32-Bit Ultimate for System - OEM (but do you need Ultimate?)
I thought I did for the Media Center but I see the 32-bit Home Premium will do?
tate16t is offline
post #993 of 19508 Old 02-02-2008, 01:13 PM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Home Premium is for HTPC. Ultimate includes Home Premium and Business.
renethx is offline
post #994 of 19508 Old 02-02-2008, 01:57 PM
audionewer's Avatar
i was wondering does it matter which motherboard i buy ?
for example like : nividia 7150 board or G33 motherboard for HTPc because i usually use it for HTPc? what about Dual memory channel or not? because 7150 doesnot have dual channel but G33 has dual channel?
audionewer is offline
post #995 of 19508 Old 02-02-2008, 02:32 PM
ChrisMorley's Avatar
I recommend waiting the 4 weeks until AMD 780G boards are available. Around the same time Phenom 9100e chips should be out too. Then make a decision.
ChrisMorley is offline
post #996 of 19508 Old 02-02-2008, 04:39 PM
tate16t's Avatar
Can you forward links to info on the 780G boards or Phenom 9100e chips?
tate16t is offline
post #997 of 19508 Old 02-02-2008, 09:55 PM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
for example like : nividia 7150 board or G33 motherboard for HTPc because i usually use it for HTPc? what about Dual memory channel or not? because 7150 does not have dual channel but G33 has dual channel?
There is no noticeable video playback performance difference between 7150 and G33 when you use a discrete graphics card.
renethx is offline
post #998 of 19508 Old 02-03-2008, 06:42 AM
jerome8283's Avatar
Never mind. I got it.
jerome8283 is offline
post #999 of 19508 Old 02-03-2008, 06:52 AM
jerome8283's Avatar
renethx,
Do you have any inside information on the new 780G boards? Do you think the performance between it and having a discrete graphic card solution will be significant? As you know, I’m close to making a decision on the configuration below but I’m contemplating waiting. What is your thought?
Near Ready to buy config:
•CPU: Core 2 Duo E4600 2.4GHz Socket 775 $143.99
•CPU Cooler: ZEROtherm BTF90 $30.99 after $10.00 Mail-In Rebate ($40.99)
•Motherboard: GIGABYTE GA-EP35-DS4 Intel P35 chipset ATX $ 179.99
•Memory: Crucial Ballistix BL2KIT12864AA804 DDR2-800 2 x 1GB Kit $49.99 after $25.00 Mail-In Rebate ($74.99)
•Graphics Card: SAPPHIRE 100237L Radeon HD 3650 512MB 128-bit GDDR3 $104.99
•HDD: Samsung SpinPoint T166 500GB HD501LJ 500GB SATA $109.99
•PSU: Antec NeoHE 430 $69.99
•Case: SilverStone Lascala SST-LC10B-M $139.99 (not totally decided)
•Optical Drive: LG GGC-H20L Super Multi Blue Blu-ray Disc & HD DVD-ROM Drive $299.99
•Windows Vista 32-bit Home Premium $ 109.99
•Power DVD - $89
•Logitech EX110 Wireless KB + Mouse or 1 x Media Centre Keyboard/Mouse combo (not totally decided)
post #1000 of 19508 Old 02-03-2008, 07:49 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
jerome8283
If you go with AMD 780G with integrated Radeon HD 3200, you can save some money ($200-$250):
- CPU: Athlon 64 X2 5600+ Black Edition, $100
- Motherboard: GIGABYTE GA-MA78GM-S2H, $80? (there will be several ATX mbs too.)
- Radeon HD 3200 IGP, $0
- mATX case such as Antec Fusion (Black) 430
Radeon HD 3200 will be just enough for the HTPC tasks. But you have to wait until March. Of course HD 3470 / HD 3650 is better in several respects (see bit-tech.net - First Look: ATI Radeon HD 3450, 3470 & 3650). Your original component selection is very nice and you will be satisfied. It's up to you.
renethx is offline
post #1001 of 19508 Old 02-03-2008, 08:02 AM
jerome8283's Avatar
jerome8283
Thanks as always for your quick (always informative) response!
post #1002 of 19508 Old 02-03-2008, 10:49 AM
Speqtre's Avatar
What do we know about Nvidia's upcoming 8200 IGP solution for AMD procs? Any good advance word?
Speqtre is offline
post #1003 of 19508 Old 02-03-2008, 10:59 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
The only latest news is BIOSTAR (and J&W) launched a 8200 mb:
GF8200 M2+
Picture is here. (But it's not yet available, at least in US.)
renethx is offline
post #1004 of 19508 Old 02-03-2008, 12:36 PM
Smitty2k1's Avatar
GF8200 M2+
I'm pretty excited for this mortherboard. However, I do not know if I feel good about the 6 channel audio.
Smitty2k1 is offline
post #1005 of 19508 Old 02-03-2008, 06:46 PM
David O's Avatar
May be a misquote - it says 8 channels in the text (just above the table that says 6 channels).
David O is offline
post #1006 of 19508 Old 02-03-2008, 11:25 PM
*canister*'s Avatar
I have an ATI 2600 Pro card that I just installed. Now when I open Winows Media Center I get a black screen w/ audio and my mouse. I know this is a driver issue. If I uninstall the driver Media Center will open OK. As soon as I load the driver again my problem starts. Is there a driver or a patch for this problem? Is anyone else having a problem w/ the 2xxx series cards and Media Center?
If I can't get this working what NVidia cards (silent) would you recommend?
*canister* is offline
post #1007 of 19508 Old 02-03-2008, 11:50 PM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
*canister*
Please explain more. Can you start Media Center normally? When does the black screen appear?
renethx is offline
post #1008 of 19508 Old 02-04-2008, 12:20 AM
*canister*'s Avatar
Media Center does not start normally, everthing else on my compter works fine. When I open it I can hear the audio and see my mouse. The menu is just a black screen though. The bottons (My Videos, My Music, ect.) are still there eventhough I can't see them. The only thing I can see is the Help screen when I hit F1, but in the help menu when a dialoge box appears in the bottom right corner its solid blue so I can't see that either. When I uninstall the ATI driver I can open Media Center and see the menu like normal (in low res). When I reinstall the drivers its back to the black screen. I've tried every driver from June until now and nothing works.
Now just to make sure that it wasn't a problem with Media Center I put an old NVidia card in and everything worked fine.
post #1009 of 19508 Old 02-04-2008, 12:53 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Perhaps there is no definitive fix for it unfortunately.
renethx is offline
post #1010 of 19508 Old 02-04-2008, 01:13 AM
*canister*'s Avatar
Maybe I'll just put it on the shelf until some driver fix comes out.
Could you suggest a good NVidia card? I do no gaming. Only really used for DVDs on HDD and recorded TV (SD & HD)
Looking for something around $100 or less
Silent cooling or very quite fan
Whats the best value right now?
Thanks for your help!
post #1011 of 19508 Old 02-04-2008, 01:27 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
- XFS GeForce 8500 GT GT PV-T86J-UAHG, $60 AR
- ASUS ASUS EN8500GT SILENT MAGIC/HTP/512M, $64 AR
renethx is offline
post #1012 of 19508 Old 02-04-2008, 01:58 AM
*canister*'s Avatar
Thanks. I was thinking of a 8500 card but but didn't know if it was enough.
This card also caught my eye.
XFX PVT84JUSD4 GeForce 8600GT 256MB 128-bit GDDR3 - $80AR
Not exactly silent but has a a pretty quite ZALMAN fan. Are there any real advantages of the 8600gt over a 8500gt as far as video playback goes?
I was also wondering do most HTPCs use ATI or Nvidia cards, what do most people perfer? I just got into HTPCs over the past few month and I'm trying to switch some parts out in a recent build I did to make it into a HTPC. So sorry for all the questions but I like to hear the opinion of people who have knowledge on the subject.
post #1013 of 19508 Old 02-04-2008, 02:44 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Some say 8600 GT is better for 1080i HDTV because deinterlacing is done in more powerful stream processors (I haven't seen difference). If you want to be sure, this is your choice.
renethx is offline
post #1014 of 19508 Old 02-04-2008, 09:09 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
renethx is offline
post #1015 of 19508 Old 02-04-2008, 11:51 AM
crashdumy's Avatar
renethx
how much gain will i see from running dual channel ram? I have already purchased some but if there is no real performance gain for htpc then it won't bind me up too bad not to run that way.
I only ask because the NVidia micro-atx boards don't support dual channel. But other than that I kind of like the sound of this one:
http://www.tigerdirect.com/applicati...184&CatId=2541
post #1016 of 19508 Old 02-04-2008, 01:18 PM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
None at all as far as video playback is concerned.
renethx is offline
post #1017 of 19508 Old 02-04-2008, 02:47 PM
crashdumy's Avatar
http://www.tomshardware.com/2007/10/...ing/index.html
Yeah I think your right. Thanks again!
CD
post #1018 of 19508 Old 02-04-2008, 04:16 PM
audionewer's Avatar
do i need to have 1:1 ratio if i am building HTPC? i am getting E8400 and maybe getting this board: gigabyte G33 matx board or Asus P5k-VM. i am thinking to get Evga 71xx board but this is not manual for the bios?
post #1019 of 19508 Old 02-04-2008, 05:11 PM
*canister*'s Avatar
Thanks for all the help. I finally found a solution. In the post about getting the same black screen in Vista after coming out of sleep mode someone mentioned upping the PCIe voltage, well that did it.
So, if anyone else is getting a black screen when opening Media Center w/ an ATI 2xxx series card (I know I'm not the only one) try turning up the voltage to your PCIe.
post #1020 of 19508 Old 02-04-2008, 06:39 PM
leftheaded's Avatar
NVIDIA uploaded the GeForce 8200 mGPU page.
interesting.. so, is this going to be the "the motherboard" for dedicated HTPC use... well, for those not wanting a discrete graphics card anyway?
leftheaded is offline
Reply Home Theater Computers
Computers
