Guide to Building a HTPC, Workstation and Server - Page 604 - AVS Forum | Home Theater Discussions And Reviews
 30Likes
post #18091 of 19513 Old 11-28-2011, 11:44 PM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Originally Posted by guppy1 View Post
So when you say "higher" than GT430 are you reffering to a GT440 or is there something even higher than that?
Yes, GT 440. GTS 450, GTX 550, GTX 460, GTX 560, .... It's the last two digits that matter.
renethx is offline
post #18092 of 19513 Old 11-29-2011, 01:22 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
ASRock Smart Remote is available at SuperBiiz.com for $25, that enables a PC with any recent ASRock mb to be powered on by remote. (A normal MCE IR receiver/remote supports only wake up from sleep.)
Actually what you need is the receiver (may be purchased from ASRock support for $8). It works with any MCE remote.
renethx is offline
post #18093 of 19513 Old 11-29-2011, 06:05 AM
guppy1's Avatar
What motherboard do you recommend for a mid-range AMD? The Motherboard: GIGABYTE GA-890GPA-UD3H AM3 AMD 890GX/SB850 chipsets ATX, is no longer available from newegg. I will be using the 95Watt Phenom II X4 840. Thanks.
guppy1 is offline
post #18094 of 19513 Old 11-29-2011, 06:18 AM
guppy1's Avatar
Graphics card
You recommend
SPARKLE SXT440512D5NM GeForce GT 440 GDDR5 512MB, $75.
But I found
SPARKLE SXT4401024S3NM GeForce GT 440 (Fermi) 1GB 128-bit DDR3, $75
It has more memory, but it has DDR3 memory, does that make any difference?
guppy1 is offline
post #18095 of 19513 Old 11-29-2011, 07:06 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
GIGABYTE GA-990FXA-UD3, $110 AR.
renethx is offline
post #18096 of 19513 Old 11-29-2011, 07:10 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Graphics card
You recommend
But I found
There are a couple of GDDR5 1GB cards.
renethx is offline
post #18097 of 19513 Old 11-29-2011, 07:39 AM
Dem Bums's Avatar
Just came across this deal on memory, looks great...
G.SKILL Ripjaws Series 8GB (2 x 4GB) DDR3 DDR3 1333 DESKTOP for 24.99, No rebates
http://www.newegg.com/Product/Produc...82E16820231311
Dem Bums is offline
post #18098 of 19513 Old 11-29-2011, 09:57 AM
Tyfoon2's Avatar
I've been using a WMC 7 setup with a Nvidia 9500 GT in combination with audio passtrough for about two years now. For this I connected my HDA Explosion 7.1 via spdif out to spdif in on the 9500 GT. Then only HDMI to my TV. This works fine.
I now have upgraded my TV to a Samsung 55'' D8000 and a Onkyo NX609 receiver and finding that the card (probably in combination with the CPU) has some limitations in playing back 3D etc.
I'm thinking of buying the asus GT430 passive cooled from the latest HTPC guide.
Now my questions:
  • Do I still need the Auzentech Xplosion (to loop the SPDIF to the graphics card) or can I remove it and just use the GT430??
  • Is this card good enough in combination with an Intel Core 2Duo 6400 or would another card be recommended (pref passive)?
Tyfoon2 is offline
post #18099 of 19513 Old 11-29-2011, 10:14 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Originally Posted by Tyfoon2 View Post
Now my questions:
No. GT 430 has its own HD audio controller.
Good enough, except for 2D->3D conversion, where GPU is irrelevant, only CPU is used, and C2D is not enough.
renethx is offline
post #18100 of 19513 Old 11-29-2011, 01:27 PM
guppy1's Avatar
The details on the motherboard show compatible memory as:
DDR3 2000(O.C.)/1866/1600/1333/1066
I guess we want the fastest memory without overclocking?
If so that would be the 1866
When I go to Newegg the 1866 comes in two flavors;
PC3-14900 and PC3-15000. What is the difference?
Do I want 4gb or 8gb, the price difference is only $10
guppy1 is offline
post #18101 of 19513 Old 11-29-2011, 01:42 PM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
DDR3-1866 2 x 2GB is $45, 2 x 4GB is $50. So the choice is obvious (the latter).
renethx is offline
post #18102 of 19513 Old 11-29-2011, 03:54 PM
guppy1's Avatar
guppy1 is offline
post #18103 of 19513 Old 11-29-2011, 05:22 PM
Ducati 1098's Avatar
A read on memory for Sandy Bridge Platform
http://www.anandtech.com/show/4503/s...-the-best-ddr3
Ducati 1098 is offline
post #18104 of 19513 Old 11-29-2011, 08:09 PM
ghatothkach's Avatar
hi
What are the current best options for 4 port and 8 port SATAII HBA's...
the best 8 port option seems to be...
HBA: Supermicro AOC-SASLP-MV8 8-port SATA 2.0 Controller PCI Express x4 Card, $104.
what would be a good 4 port option...
G
ghatothkach is offline
post #18105 of 19513 Old 11-29-2011, 09:08 PM
tomandbeth's Avatar
Looks like the 1600 came out as best bang for the buck.
Appreciate the link, Amigo.
tomandbeth is offline
post #18106 of 19513 Old 11-29-2011, 09:34 PM
blackblaze's Avatar
Essentially, I have three set top boxes in the house. Im looking to replace them all. My initial goal with my first HTPC, use it as a DVR, hub for Live TV, and be able to store photos/music on it to so to be able to view that content on other TVs. It will not be a media storage of ripped dvds/blu rays (not this build). I'll also have two xboxs as extenders.
Below is just a me doing my own learning, picking items based on price and my needs.
SILVERSTONE ML03B
http://www.newegg.com/Product/Produc...82E16811163174
Antec NEO ECO 620C 620W Continuous Power (able to get it for $35 AR)
http://www.newegg.com/Product/Produc...82E16817371031
ASUS M4A88T-M AM3 AMD 880G
http://www.newegg.com/Product/Produc...82E16813131657
AMD Athlon II X3 445 (will try to unlock the 4th core)
http://www.newegg.com/Product/Produc...82E16819103872
SiliconDust HDHomeRun PRIME
http://www.newegg.com/Product/Produc...82E16815345006
Windows 7 64-bit (OEM)
Im still deciding on memory, a low profile dvd player (probably just get a lite-on) and the storage. I also know depending on the current hardware and usage will dictate if a video card is needed or not. I also haven't looked into the remote option yet as well for this setup.
The power supply, may be overkill for my needs, based on what I've learned so far of PSUs for HTPCs.
Any advice, comments or suggestions would be great for this newb
blackblaze is offline
post #18107 of 19513 Old 11-29-2011, 10:25 PM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
BTW for iGPU, the memory speed may make a big difference, in particular for madVR. Moreover DDR3 will be the mainstream memory standards until 2015. That's why I recommend faster memory. (Unfortunately DDR3-2133 2 x 2GB, $50, is deactivated.)
If you never use iGPU, DDR3-1600 is a good choice of course.
renethx is offline
post #18108 of 19513 Old 11-29-2011, 10:42 PM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
@blackblaze
You'd better add a discrete GPU. Under DXVA/EVR framework, AMD A6-3500 (3 core) + A75 chipset is excellent without a discrete GPU.
renethx is offline
post #18109 of 19513 Old 11-29-2011, 11:40 PM
skeeterfood's Avatar
How does this GIGABYTE GA-Z68M-D2H motherboard compare to the suggested Mid-Range ASRock Z68 PRO3-M motherboard?
Here's what I see:
ASRock Pros:
USB 3.0 ports
eSata port, but one less internal SATA 3Gb/s port
Displayport port
More analog audio ports
FDD Connector (Really?)
Gigabyte Pros:
2x PCI Express 2.0 slots (x16, x4) instead of PCI slot
Cheaper base price + Rebate
skeeterfood is offline
post #18110 of 19513 Old 11-30-2011, 12:29 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
I don't own GA-Z68M-D2H. So just my guess:
- The first PCI Express x16 2.0 slot supports only a graphics card.
- No audio over DVI
- No UEFI BIOS (this is sure)
BTW ASRock Z68 PRO3-M has LPT/COM/FDD internal connectors.
renethx is offline
post #18111 of 19513 Old 11-30-2011, 02:27 AM
Tony_Montana's Avatar
Quoted: 45 Post(s)
hello renethx!
how you do?
did you make any tests on llano boards using DXVA2/MAdVr de-interlacing?
are you going to release an october/november buyer`s guide soon?
thank in advance
Tony_Montana is offline
post #18112 of 19513 Old 11-30-2011, 04:19 PM
whiteboy714's Avatar
Rene another question if you will. I got my 6570 installed, everything is great with madvr and lav. Only issue is when I set madvr to change the refresh rate to 1080p23 when watching blu ray. The movie is letterboxed with black bars on the sides and top and bottom. And the picture is very jumpy.
I did not have this issue in the past with nvidia but I would set it manually back then.
I am using an Onkyo AVR and the tv is a Panny TC-P50ST30. The tv is in 60hz mode but it looked better then this in the past when sending it 24p. Do I need to adjust something in catalyst? I added 1080p23 in the custom resolutions but it didn't seem to do anything.
Also I got the same behavior when I set xbmc to change the refresh rate automatically.
whiteboy714 is offline
post #18113 of 19513 Old 12-01-2011, 06:46 AM
Greg Smalter's Avatar
How do you get LAV with AMD? I thought it was nVidia only.
Greg Smalter is offline
post #18114 of 19513 Old 12-01-2011, 06:50 AM
Yes. If madVR does down/upscaling (e.g. 1080->720, 480->1080), it may use lots of GPU processing power, depending on madVR's algorithm.
If you don't see dropped frames, leave as it is. High GPU usage is normal in your configuration.
The problem is my computer is melting with the GPU maxed out for 3+ hours. Or, it's really loud; the choice is mine.
I tried setting my desktop resolution to 1920x1080 and it had no impact on performance. I did notice when watching 720p stations that it only requires 35% GPU whereas on 1080i stations it uses 90%.
I did not see any options in MadVR as far as whether to upscale/downscale or anything about resolutions. Am I missing something?
Also, I noticed that MadVR reports de-interlacing as off (because upstream says so). It's possible that is what's taking the power. Is LAV CUVID the one doing this?
post #18115 of 19513 Old 12-01-2011, 07:03 AM
Postmoderndesign's Avatar
Quoted: 221 Post(s)
Liked: 85
Only LAV CUVID is Nvidia only.
Anál nathrach, orth’ bháis’s bethad, do chél dénmha
Postmoderndesign is online now
post #18116 of 19513 Old 12-01-2011, 12:43 PM
pman555's Avatar
Quoted: 42 Post(s)
renethx, I think I've been persuaded to go with a micro ATX mobo as it seems to have more expandability for the future.
I've also learned that Z68's are pretty good mobos, so I think I'll concentrate on that for now.
What do you think of this budget build?
My main question is regarding the RAM. The mobo has 4 slots, but do I need to fill them all, or fill 2? Or is just 1 sufficient?
http://secure.newegg.com/WishList/Pu...umber=15656531
Also, keep in mind that I will likely be buying the processor and motherboard from microcenter, since they're cheaper.
pman555 is offline
post #18117 of 19513 Old 12-01-2011, 02:57 PM
Shameless bump Rene any thoughts? I need to donate to this thread. (went ahead and bought the recent guide.)
EDIT** Nevermind I got it figured out in the MPC-HC thread. I hadn't set the overscan for 1080p23.
post #18118 of 19513 Old 12-02-2011, 07:48 PM
rsmclay's Avatar
Everyone,
I did the mid ATX option with the following pieces:
CPU: Core i3-2105 3.1GHz 2C/4T 65W LGA 1155 / Intel HD Graphics 3000
Motherboard: ASRock Z68 Pro3-M LGA 1155 Intel Z68 chipset microATX
The problem I have is when I connect it to my TV, the desktop is so large I can't see the task bar, nor the top left or right of the desktop.
I am assuming the computer is overscanning, but I can't figure out where to change it. Any ideas?
rsmclay is offline
post #18119 of 19513 Old 12-02-2011, 08:50 PM
Originally Posted by rsmclay View Post
Everyone,
There is a scaling option in the intel driver. You should have an icon in your system tray to adjust the graphics settings for the intel driver. It's in there.
Also you need to be sure your tv is set to 1:1 pixel mapping for the input of your htpc.
post #18120 of 19513 Old 12-03-2011, 07:41 AM
Mike in Virginia's Avatar
Everyone,
[snip]
How are you connecting to the TV? VGA? HDMI?
Mike Leavitt, Lansdowne, VA
Mike in Virginia is offline
Reply Home Theater Computers
Computers
