Guide to Building a HTPC, Workstation and Server - Page 613 - AVS Forum | Home Theater Discussions And Reviews
 30Likes
post #18361 of 19513 Old 02-13-2012, 07:00 PM
Ferrino's Avatar
Originally Posted by renethx View Post
- 23Hz for film
- 59Hz for video
Can I please ask how well the Llano APUs you tested handled the 23hz setting with 23.976 fps film? I see a lot of debate on which chips can handle 23.976 fps files and am hoping that it's straightforward with Llano and the Catalyst drivers. Is it as simple as switching to the "23Hz" mode in Catalyst to get 23.976 output? Thankyou!
Ferrino is offline
post #18362 of 19513 Old 02-13-2012, 08:30 PM
investmentcar's Avatar
Originally Posted by Kenshiro 26 View Post
Just got this deal alert in an e-mail from TigerDirect.
Don't know how it is performance-wise, a good way to get into SSD maybe.
120Gb OCZ Vertex Plus SSD $99 After Rebate.
Performance and reliability are the specs to look at in SSDs imo. I don't know the answer for either of these on the Vertex but potential buyers check the forums for the specific drives they like: http://www.ocztechnologyforum.com/fo...ort&order=desc
"Vertex" sounds like it must be an older generation of SSDs. OCZ is up to Vertex 3 now among others.
(burned by my Vertex 2 after 5 months)
investmentcar is offline
post #18363 of 19513 Old 02-13-2012, 09:45 PM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
The clock depends on each individual chip. The worst and best I have seen in Llano chips are:
- 23.97555Hz, a frame drop every 37m
- 23.97585Hz, a frame drop every 1h51m
They are much better than Intel and NVIDIA (only NVIDIA custom resolution can be better). madVR can change refresh rate based on the contents automatically.
renethx is offline
post #18364 of 19513 Old 02-13-2012, 10:48 PM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
  Codename Radeon cores/CUs Clock Memory TUs ROPs Power Price
HD 7770 Cape Verde XT 640/10 1000MHz GDDR5-4500 1GB 128 bit 40 16 80W $129?
HD 7750 Cape Verde Pro 512/8 800MHz GDDR5-4500 1GB 128 bit 36 16 55W $110?
Source. If you are not satisfied with Llano, just go with HD 7750 or 7700.
Update
There are now lots of reviews on 7770/7750 on the Internet. Notably, AnandTech.
renethx is offline
post #18365 of 19513 Old 02-13-2012, 11:06 PM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
renethx is offline
post #18366 of 19513 Old 02-14-2012, 05:19 PM
jrolmstd's Avatar
Originally Posted by jrolmstd View Post
tried the netsh disabled, uninstalled drivers, installed new drivers from realeck, and flipped it to a work network. No change
Last post on this. I set up shared directory on the server that was not in the RAID array. Transfer speeds for the same file tested with in the past hovered around 80 MB/sec where as when the target was a directory inside the RAID array it would bottom out at 15 MB/sec. Would seem to eliminate any networking issue being the cause of this. Looks to be more of an issue with the software RAID being used than anything else...
jrolmstd is offline
post #18367 of 19513 Old 02-15-2012, 02:02 PM
goetzc's Avatar
FWIW-
I'm using a 3ware 9500s-4lp I purchased on eBay(seller=belmonttr) for $10+s/h. Works great!
goetzc is offline
post #18368 of 19513 Old 02-16-2012, 10:45 AM
Ferrino's Avatar
Wow, had no idea it varied within the Llano series! Thanks.
Another Llano setup question - is there a "sweet-spot" of how much system memory to assign to the on-chip graphics? I have an 8GB DDR3-1600 setup, so maybe 1GB?
Ferrino is offline
post #18369 of 19513 Old 02-16-2012, 10:58 AM
ozer19's Avatar
You guys are way over my head
What would a noob like me choose for a HTPC in order stream his MKV files (3D as well)?
Instead of putting together one, I think I'll be better off buying something off the shelf. Any recommendations? I have a BD Player already.
ozer19 is offline
post #18370 of 19513 Old 02-16-2012, 11:23 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
The max you can assign in Llano is 500MB and it's the one you should set "Frame Buffer" to in UEFI BIOS.
renethx is offline
post #18371 of 19513 Old 02-16-2012, 07:32 PM
FishLaw's Avatar
please post a new version of your guide!
FishLaw is offline
post #18372 of 19513 Old 02-16-2012, 11:55 PM
danbez's Avatar
Quoted: 33 Post(s)
Rene,
I am facing an issue with my 5670 card - I want to use both the DP and HDMI outputs (one for the Tv, one for the Receiver/projector) but no matter what I do, I can only get the sound from one of the digital outputs (the one activated first). The only way to switch between them is to reboot with either the receiver or the TV turned off, so the sound is assigned to the active port.
After browse different posts it seems to me that NVidia card offer the ability to output sound to 2 different digital outputs. Is that correct? Which model would you recommend for HTPC exclusive use (Live TV, DVD, Blu-Ray)? Any model with DP and HDMI outputs or would I need a DVI-HDMI adapter?
danbez is offline
post #18373 of 19513 Old 02-17-2012, 12:10 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Sure, soon.
renethx is offline
post #18374 of 19513 Old 02-17-2012, 12:14 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Yes, NVIDIA supports dual audio stream (over HDMI and DVI [with a generic DVI-HDMI adapter]). GeForce GT 430, ASUS fanless or PNY 1-slot low-profile. The card also supports dual 1080p video stream. But dual 1080i is difficult (there are not enough shaders for dual deinterlacing).
renethx is offline
post #18375 of 19513 Old 02-17-2012, 09:41 AM
danbez's Avatar
Quoted: 33 Post(s)
Thanks Rene. Looks like I have some shopping to do today.
Any reason to choose the PNY over the Asus w/fan model below?
http://www.newegg.com/Product/Produc...b=true&Page=10
danbez is offline
post #18376 of 19513 Old 02-17-2012, 09:56 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
PNY in case you need a 1-slot (and low-profile) card. If there is enough room for a 2-slot card, ASUS is another option (don't buy this ASUS model, DDR3-1200 is too slow). If the case supports full-height cards, go with ASUS fanless.
renethx is offline
post #18377 of 19513 Old 02-17-2012, 10:03 AM
danbez's Avatar
Quoted: 33 Post(s)
In terms of fan noise, are both Asus and PNY similar? That's my main concern.
Ideally I should get the fanless one, but it won't fit my case.
danbez is offline
post #18378 of 19513 Old 02-17-2012, 10:51 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
renethx is offline
post #18379 of 19513 Old 02-17-2012, 11:24 AM
HTPCat's Avatar
Quoted: 502 Post(s)
Liked: 297
We are here because we build them, so you probably won't get much help on recommendations on pre-built HTPCs although nowadays many of the PCs on the shelf will work fine streaming mkv files with the addition of some freeware. With the guides here it really isn't too difficult to build a simple, cheap, nice looking HTPC.
HTPCat
"I have a need to feed the hole with more Audio & Video toys"
HTPCat is offline
post #18380 of 19513 Old 02-17-2012, 03:16 PM
BLOCKMONSTER's Avatar
Llano APU dethroned the golden combination of Core i3-2105+Z68+DDR3-2133. (DDR3-2133 is only available as 2 x 4GB or higher kit, that is pretty expensive compared with DDR3-1600 2 x 2GB, no need of overclocking, DXVA2 compatible AMD GPUs was implemented in LAV Video Decoder etc.) This will be reflected in the next issue (available very soon). I apologize for the long delay (as usual lately).
Can I add a HD 6570 to my Intel G850 setup and get the same perf with DXVA2 as the A6-3500 does by itself?
BLOCKMONSTER is offline
post #18381 of 19513 Old 02-17-2012, 03:45 PM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Yes.
renethx is offline
post #18382 of 19513 Old 02-17-2012, 06:21 PM
jasjw's Avatar
Quoted: 42 Post(s)
Hi,
My head is gone reading through all this. Just woundered if someone could advise me on a system that will play 3D ISO, 3D Blu Rays flawlessly through my 3D TV with full HD audio. Thats all it will be used for, Not fussed about gaming.
My main problem would be, the case needs to be no more than around 250cm in depth and it would have to have a remote to make it family friendly. It doesnt really matter on the height and width.
I dont need a Blu Ray drive as I will run it all from the HDD, Also I dont need a HDD as I have a 2tb.
My budget is £250-£350.
Thanks very much.
LG 65C6 OLED
Onkyo HT-R390
Dune Solo 4K
SKY Q
Xbox One
jasjw is offline
post #18383 of 19513 Old 02-17-2012, 11:28 PM
jrolmstd's Avatar
When I read about how many physical drives a RAID or HBA card will support, I see numbers reaching up to 256 for a 8 port card but when I check out the break out cables for these cards (sas --> sata) I see a cable with 1 connector on one end and 4 connectors on the other end. The 8 port cards only have 2 physical connectors. This would seem to support a maximum of 8 physical drives.
What am I missing here? I am setting up a system with 15 drives. What would the configuration of Raid and HBA cards & cables look like?
thanks
jrolmstd is offline
post #18384 of 19513 Old 02-17-2012, 11:34 PM
tomandbeth's Avatar
Originally Posted by jasjw View Post
Hi,
Thanks very much.
I3-2105. Z68 Motherboard, 4 gigs of 2133 Ram. A basic case and a power supply. Rene's guides will give you further details.
tomandbeth is offline
post #18385 of 19513 Old 02-18-2012, 12:02 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Hi,
Thanks very much.
There are several mini-ITX cases with depth < 250mm. Check my guide. If you have a HDMI 1.4a AVR, AMD Llano is another choice.
renethx is offline
post #18386 of 19513 Old 02-18-2012, 12:07 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
thanks
256 can achieved by using multiple SAS expanders such as HP 468406-B21 SAS Expander, $289.
renethx is offline
post #18387 of 19513 Old 02-18-2012, 12:16 AM
jrolmstd's Avatar
So a SAS expander is used in conjunction with the RAID card? Is it physically connected to the raid card through a cable or is it internal through the PCI slot? Looking to run this under win 7 so maybe not this specific card but something similar?
jrolmstd is offline
post #18388 of 19513 Old 02-18-2012, 12:40 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
RAID card + SAS expanders connected with SAS cables. *Official* HP SAS Expander Thread
renethx is offline
post #18389 of 19513 Old 02-18-2012, 12:50 AM
jrolmstd's Avatar
Got it. Thanks for clarification and link.
jrolmstd is offline
post #18390 of 19513 Old 02-18-2012, 10:23 AM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Hi, does anyone have issues or fix for overscan/underscan from ATI card to HDTV/Pojector?
I am using ATI Radeon 5670 via HDMI to AVR to Epson 8100 projector and HTPC image is about 20% smaller. thanks
smokarz is offline
Reply Home Theater Computers
Computers
