Guide to Building a HTPC, Workstation and Server - Page 643 - AVS Forum
 12Likes
post #19261 of 19281 Old 09-08-2014, 04:49 PM
Postmoderndesign's Avatar
Quoted: 23 Post(s)
Liked: 32
Originally Posted by gsr View Post
You'd probably be able to get one dirt cheap on ebay. Alternatively, pretty much any current AMD PCIe card from with a HDMI port should work for your needs. I wouldn't go with the cheapest option, but something around $50 should be plenty adequate.
Make sure the computer's power supply is adequate for whatever GPU you add.
Postmoderndesign is offline
post #19262 of 19281 Old 09-08-2014, 05:25 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 96 Post(s)
Liked: 171
That's a good point and a reason to stick with lower end cards.
gsr is offline
post #19263 of 19281 Old 09-08-2014, 05:41 PM
Liked: 0
How do I find out whichever one I choose will work with the power supply?
dschroed is offline
post #19264 of 19281 Old 09-08-2014, 09:07 PM
Quoted: 23 Post(s)
Liked: 32
The specs for the GPU will state the power requirements. The specs for the computer should state the amount of the power supply.
But, I do suggest you try to confirm the GPU will work in the computer before purchasing the GPU. I always have purchased current motherboards, CPUs and GPUs and memory at the same time. On the last update I did retain the power supply.
So, adding a GPU to an older computer is outside my experience.
post #19265 of 19281 Old 09-08-2014, 10:17 PM
Liked: 0
That is why I was originally asking for advice on parts to build an HTPC
dschroed is offline
post #19266 of 19281 Old 09-09-2014, 04:33 AM
Marc_G's Avatar
Liked: 34
Always good to check specs but most lower end cards won't strain a tower power supply. Check back a few pages in this thread for some recent builds. Focus more on quiet fans (or no fans) in the GPU.
Sent from my SGH-M919 using Tapatalk
Sometimes, I see dead pixels...
Marc_G is offline
post #19267 of 19281 Old 09-09-2014, 07:01 AM
Mike Walsh's Avatar
renethx or others:
I also want to upgrade my Flexraid server as I am doing more with it these days such as SABNZB, Plex Media Server etc..
I have older H77 MB and Intel G860 CPU and it's a bit slow on occasions.
I was thinking just change CPU to Intel I5 3570K but thats a lot of extra watts that will sit unused for much of the day.
Any significantly lower wattage used but still powerful CPU options?
Why can't we buy the "T" versions of Intel CPUs?
Could I buy I5 3570K and do something like under voltage to drop power usage?
Does upgrading to H97 board give me better options?
Mike Walsh is offline
post #19268 of 19281 Old 09-09-2014, 08:01 AM - Thread Starter
AVS Club Gold
renethx's Avatar
Quoted: 200 Post(s)
Liked: 369
Originally Posted by Mike Walsh View Post
renethx or others:
Actually i5-3570 is a good choice. ('K' version is pointless because your mb is H77.) The chart from this post may be helpful:
Core i5-3470 3.2GHz-3.6GHz is $20 cheaper and is another choice. You can downclock these processors to turn them into T/S processor easily.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
renethx is offline
post #19269 of 19281 Old 09-10-2014, 02:19 AM
Joe Daring's Avatar
Hi Rene, hellò everybody,
Thank you AVSForum for hosting so many clever people and interesting information!
It's nice to see this thread go full speed again and I'm looking forward to the new guide myself...
Placed some questions to Rene lately and got his competent advices, so I'm able to narrow-down my choices for a new HTPC, which is going to be actually my first one, since my Dvico TViX has given-up the ghost!
But I think it's just better to go public for my last (Hope so...) questions both to let other readers share Rene's advices on my build and to gather any other people's advice...
Focussing in an Intel NUC or a Mid-Level Intel miniITX system for now, rigged to run OpenELEC/XBMC...
So, what I'm looking for is a way to watch my medium to high quality MKVs and, to a lesser extent, old AVIs that are mostly cartoons... also,maybe, some Live TV (Free to Air) and perhaps some Internet Browsing (But I can easily rule out this for now... I learnt that OpenELEC/XBMC is not really thought for Internet Browsing)... Games are not contemplated... Files are already on my QNAP NAS and I won't need storage on the HTPC, apart the SSD for OS storage...
For Movies' watching I'm sensible to PQ, but not overly picky about that so, maybe, this may save me the hassle to go the Windows way... at least for a while...
As I said, I'm narrowing-down my options to (Taken from Rene's advices):
Intel NUC, based on Intel Haswell (mobile) processor
CPU: Core i3-4010U (Haswell) 2C/4T 1.7GHz 3MB Cache 15W FCBGA1168/DDR3L-1600/Intel HD Graphics 4400,
Cooler: Stock Stock cooler,
MB: Intel Next Unit of Computing Board D34010WYB UCFF, included,
Mem: G.SKILL F3-1600C9S-4GRSL SO-DIMM DDR3L-1600 CL9 4GB,
GPU: Intel HD Graphics 4400 20EUs (integrated in the CPU),
SSD: Crucial M500 120GB CT120M500SSD1 120GB SATA 6.0Gb/s SSD,
(BTW, what's the difference between this SSD drive and the Crucial MX100 128GB SSD drive?)
Barebone: Intel NUC Kit D34010WYKH with Core i3-4010U / Intel HD Graphics 4400 / 2.5" Drive Support,
WiFi: INTEL N7260 board
IR System: Included in the Barebone Kit
And this is pretty finalized as a set-up, as the NUC inherently does not allow further expansions...
But I may decide for more future flexibility (Changing a faulty/obsolete MoBo or CPU, adding a Discrete GPU later if needed, having the ability to add an Optical (BR) Disk Reader to replace an aging Samsung BR Stand Alone Player... you name the possibilities)...
So, I may go for this (Again, mostly taken from Rene's advices, my questions, doubts etc. put in blue and in brackets):
Mid-Range - Intel, based on Intel Haswell (Desktop) processor and AMD Radeon R7 graphics card
CPU: Core i3-4130 (Haswell) 2C/4T 3.4GHz 3MB Cache 54W LGA 1150/DDR3-1600/Intel HD Graphics 4400
(Going higher than this is an overkill at this moment...)
Cooler: Stock cooler,
MB: GIGABYTE GA-H97N-WIFI or ASUS H97I-PLUS
(Which one is better suited for the task? Reasons to prefer one over the other, GPU-Wise or something else?)
Mem: G.SKILL F3-1600C9D-8GAB Ares DDR3-1600 CL9 2 x 4GB Kit,
GPU: ASUS R7260X-DC2OC-2GD5 R7 260X 2GB GDDR5,
(This is to be added at later time and if needed, I'll be using the integrated GPU to begin with...)
(Again, which one is better, this SSD drive or the Crucial MX100 128GB SSD drive?)
PSU: SilverStone ST30SF SST-ST30SF 300W 80 PLUS Bronze SFX,
(Or will change accordingly to the Case I'll chose to go with...)
Case: SilverStone Sugo SG06-LITE SST-SG06BB-LITE Mini-ITX/Mini-DTX,
(This case has both the ability to host the Discrete GPU and the BR Reader, if I decide to add these two options... what I don't like is its shape and dimensions... What's the users experience and suggestions here with not too big, HT-like, horizontally developped cases that maintain the ability to eventually host the Discrete GPU and the BR Reader???)
IR System: NONE INCLUDED
(What's best option under the initial openELEC/XBMC build? I believe that switching to Windows system later would pose few troubles... BTW, any chance to have it INTERNALLY integrated with the suggested Case/Cases? I have an Harmony Ultimate Hub-Based Remote doing most of the HT command tsks here, and it would be nice to have it working with the new HTPC too. So I won't actually need a remote... just the receiver...)
Uhmmmm... Enough questions already... I'll switch to "Listening Mode" now... ;-)
Thank you in advance, Rene and everybody willing to share some advices with me...
Best regards and happy viewing/listening!
Joe
Joe Daring is offline
post #19270 of 19281 Old 09-10-2014, 02:30 AM - Thread Starter
AVS Club Gold
renethx's Avatar
Quoted: 200 Post(s)
Liked: 369
Another system, that's more like a AV device:
CPU: Core i3-4130
CPU Cooler: Stock
MB: H97M-G43
Mem: F3-1600C9D-8GAB
GPU: R7 260X ASUS
SSD: Crucial M550 128GB
PSU: SSR-450RM
Case: Fractal Design Node 605
or
CPU: Core i3-4130
CPU Cooler: Stock
MB: Z97 Pro4
GPU: R7 260X ASUS
PSU: SSR-450RM
Case: GD08 (deeper, supports up to 9 x 3.5" HDD, 2 x 2.5" HDD, 1 x ODD)
As for SSD, get any of the lowest price, there won't be any difference in normal HTPC usage.
renethx is offline
post #19271 of 19281 Old 09-15-2014, 04:16 AM
Joe Daring's Avatar
Hi Renethx and all,
Thank you so much for such outstanding advices I got...
After more thoughts and reading, I think I narrowed down my choices to the following components:
CPU: Core i3-4130
CPU Cooler: Stock
(Initially at least... I'll eventually go to a third party cooler if the stock one is too noisy or whatever...)
MB: MSI H97M-G43
(Actually seems a good MB... Several high-end options (M.2, more PCIe Slots, albeit two of them 1x... Only doubt is that I just read somewhere that it has just 4 SATA ports, but this info seems to be wrong to me as I see it's 6 (And more than that using the M.2 to Sata option) on MSI site... Hope I'm not wrong... 4 would sufice anyway, but having a few more may be useful in the future...)
GPU: Embedded Intel HD 4400 (May go for an R7 260X ASUS in the future or whatever is out in a few months from now...)
SSD: Crucial 128GB MX100
PSU: SSR-450RM
Case: Silverstone Grandia GD04 Case (Fits best my HT System...)
IR System: Still have to gather info on this, but I'll do that soon...
I realize this took a different twist from what I initially planned (Intel i3 NUC or miniITX system...) but that's the way it usually goes when I start investigating something new, and while I' still considering the i3 Intel NUC an option if I decide to keep it simple, it will be either the NUC or, in the sake of future mods/improvements/longevity, the microATX system that Rene helped to define...
I know, initial overkill, but may grant a bit more logevity keeping some components from one build to another, if necessary...
Thanks a lot again, guys... great Forum!
Joe
post #19272 of 19281 Old 09-15-2014, 04:27 AM - Thread Starter
AVS Club Gold
renethx's Avatar
Quoted: 200 Post(s)
Liked: 369
MSI H97M-G43 has six SATA ports and all of them work unless you use an M.2 card that will disable two of them.
Just a note, you can't use a graphics card with taller heatpipes such as ASUS R7 260X DirectCU II with GD04.
renethx is offline
post #19273 of 19281 Old 09-15-2014, 08:01 AM
Joe Daring's Avatar
Oh! I knew there was still something to consider carefully...
BTW, what's your suggestion for a comparable GPU that fits the GD04?
Would one of the other R7 260X incarnations out there with no protruding pipes be ok? 1GB or 2GB versions?
This is case I need to add one....
And thanks for the confirmation that, when no M.2 option is used, the MSI H93M-G43 has 6 SATA Ports...
Ciao!
Joe
post #19274 of 19281 Old 09-15-2014, 08:13 AM - Thread Starter
AVS Club Gold
renethx's Avatar
Quoted: 200 Post(s)
Liked: 369
XFX should be good inside GD04.
renethx is offline
post #19275 of 19281 Old 09-15-2014, 10:44 AM
Elpee's Avatar
Rene, I saw you many times recommened people to buy R7 260X card for their HTPCs. What is the most benefit of it? How to compare to things like HD-7770 or GeForce GT 730/740? (price/performance)
Elpee is offline
post #19276 of 19281 Old 09-15-2014, 12:04 PM - Thread Starter
AVS Club Gold
renethx's Avatar
Quoted: 200 Post(s)
Liked: 369
R7 260X is a rework of HD 7790. The basic performance is the same, with a couple of improvements (e.g. support for up to three HDMI displays).
GT 740 GDDR5 = GT 650, roughly equivalent to HD 7750, half the performance of R7 260X.
renethx is offline
post #19277 of 19281 Old 09-15-2014, 12:24 PM
Elpee's Avatar
When 4K contents far away to come, do you think R7 260X and/or HD 7790 are overkill ones for current HTPCs? (save money to buy, save money to pay power bills)
Elpee is offline
post #19278 of 19281 Old 09-15-2014, 12:45 PM - Thread Starter
AVS Club Gold
renethx's Avatar
Quoted: 200 Post(s)
Liked: 369
The answer depends on the contents you play. For FHD contents, it's overkill. For SD and HD contents, it's not overkill but just a good choice.
renethx is offline
post #19279 of 19281 Old Yesterday, 01:50 PM
Ruiner's Avatar
rene,
Could madVR performance/capability be most simply broken down to # of graphics cores, at least on the AMD side, given all the model name/number sharing between HDxxxx and Rx yy0?
i.e. 256 cores enough for up to (x) level madVR at (x resolutions)
How integral is the VRAM interface? (ddr3 vs ddr5 for dgpus, system ddr speed for APUs)
Aside,
Opinions on the Kaveri A6 7400K? (dual steamroller core, 256 shader cores)?
Ruiner is offline
post #19280 of 19281 Old Yesterday, 08:06 PM
cu_shane's Avatar
Quoted: 33 Post(s)
Rene,
I am helping someone who is new to the world of HTPCs put together their first system. Here is what I plan on recommending. Please let me know if I should make any changes.
processor $47: Intel Celeron G1840 Haswell Dual-Core 2.8GHz
motherboard $135: ASRock Z97E-ITX/ac (this is the most affordable option I could find with integrated wifi and an M.2 slot, which should offer a lot of boot time and speed advantages)
memory $45: G.SKILL 2 x 2GB
Internal Blu-ray drive $40: LG UH12S30
Case including PSU (power supply unit) $55: APEX MI-008
M.2 drive for the OS $45: MyDigitalSSD 64GB
3.5" Hard drive $110: Western Digital WD Green 3TB
Remote Control (really just need it for the IR receiver, he will be using a Harmony) $9: USB PC WMC Remote
TOTAL: $486
This will be used exclusively for streaming video and for local blu-ray rips (1080p). He will be using Windows 8.1 and XBMC.
cu_shane is offline
post #19281 of 19281 Old Yesterday, 09:20 PM
Aryn Ravenlocke's Avatar
Quoted: 128 Post(s)
Liked: 60
Originally Posted by cu_shane View Post
Rene,
TOTAL: $486
Pretty solid. Nothing in there is overkill, and that processor can take care of the 1080 content. I tend to prefer 8 GB of RAM as a minimum, but there is no reason in this case to really go that high. Both Windows 8.1 and Kodi/XBMC can run just fine off of 2 GB.
As a simple, entry-level HTPC that will give your friend a good idea of what else could be possible, or to work as a simple streaming appliance, this should be fine.
Aryn Ravenlocke is online now
Reply Home Theater Computers
Computers
User Tag List
