Guide to Building a HTPC, Workstation and Server - Page 644 - AVS Forum
 13Likes
post #19291 of 19293 Old Today, 01:52 AM
MrPictureman's Avatar
Originally Posted by renethx View Post
- Motherboard: ASRock Z97 Extreme6 (that supports up to 10 SATA drives)
- Memory: F3-12800CL9D-4GBNQ (2x2GB) or F3-1600C9D-8GAB (2x4GB)
- SSD: Crucial MX100 Series 128GB/256GB/512GB
- HBA: Supermicro AOC-SAS2LP-MV8 x 2 (supports 16 SATA drives in total)
Thanks Rene
I see Microcenter has an older version of this board that has 4 instead of 10 sata controllers @ 3gbs but not the one you suggested is there another board option and would I use the same memory?
Will the Supermicro AOC-SAS2LP-MV8 be compatible with larger 4-6 TB HDD
What size ssd would you suggest with window server 2011 and flexraid? Was the PSU enough for this server build? Is the i7 overkill or should I be okay?
Last question which HDD do you prefer in servers like this?
MrPictureman is online now
post #19292 of 19293 Old Today, 02:14 AM - Thread Starter
AVS Club Gold
renethx's Avatar
Quoted: 208 Post(s)
Liked: 371
Several others:
ASRock Z97 Extreme6, Z97 Extreme4, Z87 Extreme6, Z87 Extreme4
ASUS Z97-PRO, Z87-PRO, Z87-PLUS
Memory should work with any mb.
Yes, AOC-SAS2LP-MV8 supports any 4-6TB HDD.
MX100 256GB SSD is a good choice, it's only $110 at Micro Center, I guess.
750W PSU is enough for 20-25 HDDs.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
renethx is offline
post #19293 of 19293 Old Today, 09:27 AM
Several others:
Thanks Rene
I really appreciate your help
Reply Home Theater Computers
Computers
User Tag List
