Guide to Building a HTPC, Workstation and Server - Page 645 - AVS Forum
 15Likes
post #19321 of 19331 Old 11-06-2014, 09:21 AM
Liked: 0
Originally posted in the SC-65 Receiver thread as it and my HTPC are not playing nice with each other.
Also reviewing the software thread, I'm now guessing that's most of my problem... I thought I understood this stuff, I don't know crap
I have this MB
ASRock H97M-ITX 1150 mITX Intel Motherboard
Since I'm struggling with audio so much, would I be better served with add on video/audio card? If so, what style, price point should I be looking at?
part deux is offline
post #19322 of 19331 Old 11-06-2014, 04:45 PM
Liked: 0
Thanks to the site... I didn't know how much I didn't know!
Once I turned off HDMI, receiver and PC started playing nice with each other. Also set the receiver to just look to opt for signal.
Also deleted ALL the crap I loaded on the PC and started over with MPC. "Think" I got the settings right. Will have to review those a bit more. The sound is AWESOME.
post #19323 of 19331 Old 11-09-2014, 06:23 AM
Audio Adrenalin's Avatar
Hi Guys I just recently built myself this computer for a HTPC setup -Intel i3 3.4 4gig ram, Asrock motherboard with an inbuilt 2 gig intel video card- I'm running it via a HDMI cable through a Marantz sr5007 into a samsugng led tv -but when i use the computer to play video content streamed from the internet or playback recorded tv from a tv tuner card through windows media centre -I'm running windows 7 professional i get a line about 2 cm wide (same colours as the movie playing appearingon the sreen dividing the bottom 20-30% of the screen- has anyone had similar problems and how would you suggest to eliminate it?
Audio Adrenalin is offline
post #19324 of 19331 Old 11-15-2014, 09:31 AM
fly_sig's Avatar
Hallo,
I build a HTPC with the Asrock Q1900-ITX Mainboard
4GB Ram Kingston KVR13S9S8/4
4TB Western Digital WD40EZRX
Windows 7 Professional 64 bit
Suprise with the latest Intel Graphics Driver
IntelĀ® HD Graphics Driver for Windows* 7/8/8.1 version 15.33.30.3958 posted for Ivybridge and Baytrail
HD Audio bitstreaming is working without a flaw on my j1900 platform.
The DTS-HD Dolby True HD formats appears in the supported Intel Audio window.
Tested with Powerdvd 13, you can there choose the compressed HD Audio formats and my Onkyo AVR confirmed with the right DTS-HD Master Audio light.
Great little system.
Very happy.
fly_sig is offline
post #19325 of 19331 Old 11-16-2014, 08:11 AM
yevgeny's Avatar
Liked: 0
Did anyone tried XenServer with GPU passthrough? I would like to upgrade my GPU but not sure which one will work with it?
yevgeny is offline
post #19326 of 19331 Old 11-17-2014, 06:43 AM
Cocoboo's Avatar
Looking for a higher spec system with 2 HDMI out on the MB(one to fed a NAD M51 DAC, the other one to AVR), linear power,
Already Have: Case, HDD's( 2 x Samsung 830 ssd, 1 for OS, 1 for music storage), Win7 64bit, unRaid server for movie storage,
Am thinking,
i5 4460, http://www.pccasegear.com/index.php?...ducts_id=27548
Gigabyte GA Z97N , http://www.pccasegear.com/index.php?...ducts_id=27611
RAM , 4G http://www.pccasegear.com/index.php?...ducts_id=13237
250W DC-ATX PSU , http://www.hd-plex.com/HDPLEX-250W-H...age-Input.html
Having this PSU allows me to add a DGPU later if I want 4K etc otherwise the 160w version would suffice.
Cant decide on the linear supply,
http://www.hd-plex.com/HDPLEX-Fanles...CE-device.html
Or cheaper,
the Keces 116, as discussed here, http://www.stereo.net.au/forums/inde...-diy-wallwart/
Thoughs?
Cocoboo is offline
post #19327 of 19331 Old 11-17-2014, 07:23 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 173 Post(s)
Liked: 204
Am thinking,
i5 4460, http://www.pccasegea...oducts_id=27548
Gigabyte GA Z97N , http://www.pccasegea...oducts_id=27611
RAM , 4G http://www.pccasegea...oducts_id=13237
250W DC-ATX PSU , http://www.hd-plex.c...tage-Input.html
http://www.hd-plex.c...-CE-device.html
Or cheaper,
the Keces 116, as discussed here, http://www.stereo.ne...o-diy-wallwart/
Thoughs?
FYI, none of your links work - they all have some amount of the link replaced with "...".
gsr is online now
post #19328 of 19331 Old 11-17-2014, 03:08 PM
Cocoboo's Avatar
Thanks, fixed
Cocoboo is offline
post #19329 of 19331 Old 11-17-2014, 05:24 PM
Liked: 0
Hey guys I'm wondering about something
In my AMD displaysettings (driver) I set the RGB color space to Limited(16-235) for my TV. Should I enable this in madVR displaysettings and XBMC as well? Or will this somehow "limit" it twice, and mess up the colors?
swobu is offline
post #19330 of 19331 Old 11-21-2014, 08:03 AM
Desert Pilot's Avatar
Quoted: 36 Post(s)
Liked: 26
Originally Posted by renethx View Post
Yup, buy a third-pary cooler only when you feel the stock cooler is too loud under load.
Setting up DrivePool is very easy. StableBit DrivePool User Manual > Quick Start is a good starting point. You can add existing drives with data easily. I also recommend using StableBit Scanner along with DrivePool ($35 in total), that watches S.M.A.R.T values and scans the entire surface of each drive of the system periodically.
Setting up vilett's disparity is also very easy and intuitive. Unfortunately I can't find a good instruction. A review on disparity and its own forum may be helpful. I recommedn Verson 0.40 beta.
I would like to write a short instruction somewhere.
Hi Rene,
I am putting together a list of items for a new HTPC. My old system uses a JBOD approach to multiple hard drives. But, I see above you mentioned "Drive Pool." It looks pretty simple. Is it an alternative to RAID? In other words, if my new motherboard supports, lets say, 10 drives, 1 for SSD and 1 for BD drive and 8 HDDs, could I use Drive Pool for the 8 HDDs. Containing ripped BD movies (w/ anydvd). Using JRiver Media Center as playback software (which works with my current system).
Thanks! Marcus
Our Personal Website:
Marcus & LaMona Home Theater
Desert Pilot is offline
post #19331 of 19331 Old 11-23-2014, 02:58 AM
Liked: 1
hey all, long time lurker on here looking at various reviews or what not on AV products I have been interested in. I have read this thread occasionally because I have been considering building an HTPC. Not sure if I haven't looked hard enough, but I am wondering if any of you have been creating shopping lists for items that are already known to be discounted nicely on Black friday as far as building an HTPC. My goal is to build an HTPC that's silent, or near silent, does not need to do gaming. Only to handle all my backed up BDs and DVDs and play them on my 65" tv. So...any of you already planning ahead for black friday deals to save money on an HTPC build? thanks!
lfox likes this.
vegas2k is offline
Reply Home Theater Computers
Computers
