Guide to Building a HTPC, Workstation and Server - Page 649 - AVS | Home Theater Discussions And Reviews
 23Likes
post #19441 of 19442 Unread Today, 01:47 PM
pateman21's Avatar
Originally Posted by Andy_Steb View Post
The motherboard you picked has 10 sata ports. No need for an external sata controller for the type of build that you are doing.
I would go with faster memory
Loose the s chip, your not going to save any power.
Faster memory in terms of what? like below? Do you mean ddr4?
http://www.newegg.com/Product/Produc...82E16820231314
pateman21 is online now
post #19442 of 19442 Unread Today, 01:53 PM
pateman21's Avatar
Go with both analog and optical. Unfortunately Windows won't let you output to both simultaneously with same source but at least you have the ability to switch back and forth.
Outputting LPCM on the analogs, your receiver looses the ability to apply Prologic processing, which is nice to have on 2 channel sources.
Outputting optical you loose DTS-MA and LPCM
Thanks I will connect both sources. But in general I am confused with what solution I go with? Shall I get sound card since DAC on 3805 is 10 years old or just use mobo analog output? Also optical\toslink can only do 5.1 is this correct? I would like to stick with decent 7.1 output. Do I have option of True HD sound?
Reply Home Theater Computers
Computers
