DVI-I to HDMI, but no Audio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-30-2007, 04:50 AM - Thread Starter
johnnyspo's Avatar
Greetings all.
I am upgrading my HTPC. My old setup was using onboard DVI-D and optical SPDIF connected to my HDTV (HDMI in, optical in). This time around, I am using a new MB and a Gigabyte GV-NX84G256H video card for its DVI-I (no onboard DVI) with the onboard optical SPDIF to the HDTV (same HDMI in, optical in as before). The video works fine, but no audio. I also tried the onboard line-out to the HDTV line-in, still no audio. As a test, I connected the onboard line-out to a set of speakers, and voila, AUDIO!. As another test, I connected the Gigabyte's component out to the HDTV with the optical audio, and voila, AUDIO!
It seems that the HDTV is being fooled into thinking that audio is coming in via the DVI-HDMI cable and thus ignoring its optical and line in. As I said, I did not have this problem with my old setup. The only difference is that the old MB was using DVI-D and the new video card is using DVI-I.
Any ideas? Thanks for the help.
-John
johnnyspo is offline
post #2 of 4 Old 11-30-2007, 06:10 AM
walford's Avatar
None of the DVI(digital video interface) connections contain audio. You have to use separate stereo audio as you have tried. When you do this with a stereo interface alongside the HDMI connection on your TV you also have to tell the TV to use it instead of the audio connections withing the HDMI cable.
walford is offline
post #3 of 4 Old 11-30-2007, 06:15 AM
david74's Avatar
Originally Posted by johnnyspo View Post
Greetings all.
-John
Seems to be a familiar problem with 8 series cards from Nvidia.
xpmediacentre.com.au/community/home-theatre-audio-plasmas-lcds-projectors/23711-dvi-hdmi-analog-sound-not-working-nvidia-drivers.html
David.
david74 is offline
post #4 of 4 Old 11-30-2007, 07:19 AM - Thread Starter
johnnyspo's Avatar
David.
Wow! Thanks for the thread link. You're awesome! I have been searching for about a week trying to find something. So I am not the only one with this problem. My old setup was using onboard nVidea 6150; the new GB video card is using the nVidia 8400GS. Seems like its a problem not just with GB cards, but with the nVidia 8400 and 8600.
Has anyone else successfully connected via DVI to HDMI using either one of these chipsets?
--John
Reply Home Theater Computers
