Custom Resolution Tool for Intel Graphics: Easier Overscan Correction - Page 34 - AVS Forum | Home Theater Discussions And Reviews
post #991 of 1292 Old 02-11-2009, 04:04 PM - Thread Starter
archibael's Avatar
Originally Posted by shelman View Post
Thanks Archibael, I have not tried it on DVI yet, but will do that tonight. Unfortunately my laptop does not have DVI, so it won't help me here.
As a side note, I was not sure if TotalDTDCount=1 was supposed to be used on all 4 attempts, but I did.
Here are the results for your suggestions.
7C 2E 90 A0 60 1A 1E 40 30 20 36 00 CB 28 11 00 00 1A 37 01
Produced a 1680 X 1050 resolution, and text was blurry.
20 3C 80 A0 70 B0 23 40 40 20 36 00 00 00 00 00 00 1A 37 01
28 3C 80 A0 70 B0 23 40 30 20 36 00 00 00 00 00 00 1C 37 01
28 3C 80 A0 70 B0 23 40 30 20 36 00 00 00 00 00 00 1A 37 01
Produced a 1920 X 1080 resolution, and text was blurry.
Thanks for your help, truely appreciated. Any other suggestions?
Something's seriously wrong, there. Are you filling all the DTD_1 registry entries (there are like 12 in some cases), or just one? I ask because the last three DTDs I gave should all be 1920x1200, not 1680x1050 or 1920x1080. Seems like something isn't going right in the registry. Leave DTD_2, DTD_3, DTD_4, and DTD_5 alone; they'll be ignored anyway if TotalDTDCount is 1 (again, there could be ~12 of these; I'd modify all TotalDTDCount to 1).
If text is blurry, you're likely looking at a scaling issue (the TV is trying to scale the incoming resolution to its native rez-- 1920x1200-- and doing it poorly).
Did not comprehend that you were on a laptop; the BIOS could be refusing 1920x1200. One thing to try to verify that would be 1918x1200:
28 3C 7E A2 70 B0 23 40 30 20 36 00 00 00 00 00 00 1A 37 01
I do not speak officially in any sense for
Intel Corp., Technology Manufacturing Group
but I do work there.
archibael is offline
post #992 of 1292 Old 02-11-2009, 06:26 PM
vobekk's Avatar
I try to utilise Archibael suggestion to eliminate overscan on my Mitsubishi65" TV using DTD Calculator on my Inspiron 1525 with Mobil Intel 965 Chipset.
When I try to write DTD which I generated into a registry by pressing "Write DTDs to Registry" button I am getting errow message:
"An unhandled error has occured and has been logged.
Click OK to continue:
Object reference not set to an instance of an object."
Apparantly I can not create entry to a registry.
Can you help me.
vobekk is offline
post #993 of 1292 Old 02-11-2009, 07:55 PM
drdeath691's Avatar
Setup:
PC: Dell Studio Hybrid 140 Intel mobile 965 express chip
HDTV: Sony 57WS520
Connected: HDMI/HDMI, Have also tried DVI/HDMI with same result.
OS: Vista Home Premium 32-bit SP 1
Problem:
I can get the Display set up just how I like it but after viewing a Video through Mediaportal or XBMC the resolution of my monitor shifts creating black lines on the screen or in the corners. I have used the DTDCalc tool but one thing I noticed is that when I use the Ruler portion the right side of the screen has a slant to it. I don't know if this is related but I am completely stumped. I have tried everything I can think of and I am about to re-install as a last ditch effort.
Hopefully someone can offer advice or guidance so I can get this corrected.
Real time EDID:
Monitor Asset Manager Report, generated 2/11/2009 (6.0.6001)
Copyright (c) 1995-2008, EnTech Taiwan.
Hardware data
BUS_SLOT = PCI00000.PCI00004.PCI00008.PCI0000C.PCI00010.PCI00014.PCI000 18.PCI0001C
00000000 = 2A008086.20900006.06000003.00000000.00000000.00000000.000000 00.00000000
00000008 = 2A018086.00100504.06040003.00010008.00000000.00000000.000505 00.000000F0
00000010 = 2A028086.00900007.03000003.00800000.FE600004.00000000.D00000 0C.00000000
000000D0 = 28348086.02800005.0C030003.00800000.00000000.00000000.000000 00.00000000
000000D1 = 28358086.02800005.0C030003.00000000.00000000.00000000.000000 00.00000000
000000D7 = 283A8086.02900106.0C032003.00000000.FE8FDC00.00000000.000000 00.00000000
000000D8 = 284B8086.00100106.04030003.00000008.FE8F8004.00000000.000000 00.00000000
000000E0 = 283F8086.00100506.06040003.00810008.00000000.00000000.000404 00.000000F0
000000E8 = 28308086.02800005.0C030003.00800000.00000000.00000000.000000 00.00000000
000000E9 = 28318086.02800005.0C030003.00000000.00000000.00000000.000000 00.00000000
000000EA = 28328086.02800005.0C030003.00000000.00000000.00000000.000000 00.00000000
000000EF = 28368086.02900106.0C032003.00000000.FE8FE800.00000000.000000 00.00000000
000000F0 = 24488086.00100107.060401F3.00010000.00000000.00000000.200101 00.228000F0
000000F8 = 28158086.02100007.06010003.00800000.00000000.00000000.000000 00.00000000
00000200 = 816810EC.00100500.02000002.00000008.0000E801.00000000.FE9FF0 04.00000000
00000300 = 2380197B.00100106.0C001000.00000008.FEAFF800.FEAFF400.000000 00.00000000
00000400 = 432814E4.00100106.02800003.00000008.FEBFC004.00000000.FDF000 0C.00000000
01040000 = 00FFFFFF.FFFFFF00.4DD9F801.01010101.000E0103.80000078.0A0DC9 A0.57479827
00000020 = 12484C20.00000101.01010101.01010101.01010101.0101011D.801871 1C.1620582C
00000040 = 25001009.0000009E.8C0AD08A.20E02D10.103E9600.04030000.001800 00.00FC0053
00000060 = 4F4E5920.54560A20.20202020.000000FD.003B3D0F.2E08000A.202020 20.202001DF
01040100 = 02031A76.47850203.04060701.23090707.83010000.65030C00.100001 1D.007251D0
00000020 = 1E206E28.55001009.0000001E.8C0AA014.51F01600.267C4300.040300 00.00988C0A
00000040 = D08A20E0.2D10103E.96001009.00000018.8C0AA014.51F01600.267C43 00.10090000
00000060 = 00980000.00000000.00000000.00000000.00000000.00000000.000000 00.00000097
Monitor #1 [Real-time 0x0041]
Model name............... SONY TV
Manufacturer............. Sony
Plug and Play ID......... SNY01F8
Serial number............ n/a
Manufacture date......... 2004, ISO week 0
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. Undefined or variable
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.625 - Ry 0.340
Green chromaticity....... Gx 0.280 - Gy 0.595
Blue chromaticity........ Bx 0.155 - By 0.070
White point (default).... Wx 0.283 - Wy 0.298
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 15-46kHz
Vertical scan range...... 59-61Hz
Video bandwidth.......... 80MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #1....... 720x480p at 60Hz (4:3)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Standard timings supported
640 x 480p at 60Hz - IBM VGA
EIA/CEA-861 Information
Revision number.......... 3
DTV underscan............ Not supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 6
Detailed timing #1....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing #2....... 1440x480i at 60Hz (4:3)
Modeline............... "1440x480" 27.000 1440 1478 1602 1716 480 488 494 524 interlace -hsync -vsync
Detailed timing #3....... 720x480p at 60Hz (16:9)
Detailed timing #4....... 1440x480i at 60Hz (16:9)
CE video data (timings supported)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1) [Native]
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
640 x 480p at 60Hz - Default (4:3, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 0.1.0.0
Maximum TMDS clock....... 165MHz
Report information
Date generated........... 2/11/2009
Software revision........ 2.20.0.779
Raw data................. 00,FF,FF,FF,FF,FF,FF,00,4D,D9,F8,01,01,01,01,01,00,0E,01,03, 80,00,00,78,0A,0D,C9,A0,57,47,98,27,
......................... 12,48,4C,20,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01, 01,01,01,1D,80,18,71,1C,16,20,58,2C,
......................... 25,00,10,09,00,00,00,9E,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00, 04,03,00,00,00,18,00,00,00,FC,00,53,
......................... 4F,4E,59,20,54,56,0A,20,20,20,20,20,00,00,00,FD,00,3B,3D,0F, 2E,08,00,0A,20,20,20,20,20,20,01,DF,
......................... 02,03,1A,76,47,85,02,03,04,06,07,01,23,09,07,07,83,01,00,00, 65,03,0C,00,10,00,01,1D,00,72,51,D0,
......................... 1E,20,6E,28,55,00,10,09,00,00,00,1E,8C,0A,A0,14,51,F0,16,00, 26,7C,43,00,04,03,00,00,00,98,8C,0A,
......................... D0,8A,20,E0,2D,10,10,3E,96,00,10,09,00,00,00,18,8C,0A,A0,14, 51,F0,16,00,26,7C,43,00,10,09,00,00,
......................... 00,98,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00, 00,00,00,00,00,00,00,00,00,00,00,97
Thank-you in Advance
drdeath691 is offline
post #994 of 1292 Old 02-11-2009, 09:04 PM
drdeath691's Avatar
Could my problem to the issue above be to the fact that my HDTV is not relaying a fixed screen sized?
If so is there anyway I can force a screen size using DTDcalc or Moninfo custom .inf file?
post #995 of 1292 Old 02-12-2009, 12:41 AM - Thread Starter
archibael's Avatar
Can you help me.
I have not seen that error in DTDCalc before; perhaps Wo0zy can chime in with thoughts.
You can always manually enter the DTD into the registry. Tack a "37 01" onto the end of it and stuff it in all instances of DTD_1, then change all instances of TotalDTDCount to 1.
post #996 of 1292 Old 02-12-2009, 12:43 AM - Thread Starter
archibael's Avatar
What resolution are you trying to send?
post #997 of 1292 Old 02-12-2009, 01:19 AM
drdeath691's Avatar
I have tried 1920x1080 and 1280x720. I used DTDcalc for custom resolution also. I can get the screen where I want it but it drifts over time and it's driving my bonkers
post #998 of 1292 Old 02-12-2009, 02:11 PM
shelman's Avatar
HI Archibael, thanks for the response.
I tried the 28 3C 7E A2 70 B0 23 40 30 20 36 00 00 00 00 00 00 1A 37 01, but that too produced 1920 X 1080. There is only one DTDTotalCount per device, and I assume Device 0 is the laptop screen, and Device 1 is the Samsung Monitor. I have made all DTD_1 changes to Device 1. I did change the DTDTotal Count on both to 1 though. I have not interferred with any of the other settings in DTD_2 through DTD_5.
Regards
shelman is offline
post #999 of 1292 Old 02-12-2009, 02:12 PM
vobekk's Avatar
Archi,
Thank you for your reply.
I did not quite understood how I can shavel manually DTD into registry.
I substituted last characters in string on "37 01" and I had only one instance of DTD to send to registry but when I pushed "Write DTDs to Registry" I got the same error message:
Thank you for your future answer.
vobekk is offline
post #1000 of 1292 Old 02-12-2009, 03:34 PM - Thread Starter
archibael's Avatar
Regards
Unless you're missing some DTD_1s or TotalDTDCounts (did you look manually, or search using F3?), you've exceeded my area of expertise. I'm at a loss. Putting a new DTD in should either produce no effect or produce the correct resolution. It shouldn't produce something random like 1080p.
post #1001 of 1292 Old 02-12-2009, 03:47 PM - Thread Starter
archibael's Avatar
Archi,
Again, I don't understand why that would happen with DTDCalc... although "37 01" should only be added if you're adding the DTD through regedit. If you're adding that in DTDCalc I can see problems.
Wo0zy?
post #1002 of 1292 Old 02-12-2009, 05:02 PM
Wo0zy's Avatar
Wo0zy?
Sorry. Been tied up with work.
Last time I saw one of Paul's app's produce an error like that it was on a Vista PC with a DotNet installation problem. The fix was to manually download the latest patch for DotNet version 2. It wasn't DTDCalc but one of our VMC DVD library apps but the info may point vobekk in the right direction.
BTW a new version of DTDCalc is immanent. Just testing it now. Will PM you once I get the release notes.
Wo0zy
Wo0zy is offline
post #1003 of 1292 Old 02-12-2009, 10:06 PM
vobekk's Avatar
Thanks, Wo0zy,
The direction you pointed me I did not understand.
But I found that I had DTD calc v1.00 and although I changed it to v1.02 I am still getting the same result:
Will put all my hope on "imminent" latest DTD calc release and a little bit on your assistance as well, guys.
Thanks a lot.
vobekk is offline
post #1004 of 1292 Old 02-13-2009, 02:07 AM
Wo0zy's Avatar
Thanks, Wo0zy,
Thanks a lot.
I suspect you'll have the same problem with the new version although it may be using DotNet 3 so perhaps not (I'll check with Paul).
Check Windows Update for anything DotNet Framework related. If nothing comes up go to http://www.microsoft.com/downloads/d...displaylang=en download and install. The service pack is also listed at the bottom of the page. Get that too (that may well be the issue).
Edit. Just a thought. You are right clicking the DTDCalc shirtcut and selecting "run as administrator"? This only applies if you're running Vista.
Wo0zy
Wo0zy is offline
post #1005 of 1292 Old 02-14-2009, 02:59 PM
vobekk's Avatar
Thanks again, Wo0zy,
1. In my Vista Home Premium I always run DTDcalc as administrator.
2. I tried to install DotNet Patch you reccomended - the system said it is already installed and system rechecked it again - installed.
But result in using DTDCalc the same error message after pressing "Write DTDs to Registry":
3. I hope you can help me to input DTD I was able to generate from EDID TV and via Tuning tab precisely for my TV. Take a look:
http://www.avsforum.com/avs-vb/attac...1&d=1234648651
vobekk is offline
post #1006 of 1292 Old 02-14-2009, 03:04 PM
vobekk's Avatar
Wo0zy, Archi,
I forgot to use the most important wrd in my previous message:
Help me to input DTD into registry MANUALLY!
Thanks again.
vobekk is offline
post #1007 of 1292 Old 02-14-2009, 05:40 PM
Wo0zy's Avatar
Never seen DTDCalc produce this error and neither has the guy that developed it so I'm out of ideas I'm afraid.
To manually add you need to do three things
1. Make sure you add "37 01" to the end of your calculated DTD.
2. Search the registry for all instances of "TotalDTDCount" and change the values for each to 1.
3. Search the registry for all instances of "DTD_1" and change the values to your calculated DTD.
There will be several entries for each and only some matter but change them all anyway.
Hope that helps.
Wo0zy
Wo0zy is offline
post #1008 of 1292 Old 02-15-2009, 08:50 AM
hdejongh's Avatar
Sounds like a scaling issue (illegible letters is typically because of scaling).
In the Intel Graphics Tray, do you have "Keep Aspect Ratio" or "Full Screen"? What do you mean when you say "change the TV back to 16:9"?
hi, i cant find those options.
What i mean is in the samsung menu i have to following options:
size: 16:9, wide zoom, zoom, 4:3, just scan
if i choose 16:9 i have overscan
if i choose just scan then i have no overscan..
but with just scan i get the illegible letters
thanks for helping
hdejongh is offline
post #1009 of 1292 Old 02-16-2009, 08:26 AM - Thread Starter
archibael's Avatar
Just scan is what you want on the Samsung.
On the Intel Graphics Tray, under Display Settings, I have a "Display Expansion" section, although I had thought it was called "Aspect Ratio" in other versions of the drivers. Either way, tweaking that should mess with the scaling. Don't know why you'd be getting scaling with the drivers set to 1080p, though.
post #1010 of 1292 Old 02-16-2009, 08:53 AM
zazan's Avatar
archibael:
I have exactly the same problem with my Toshiba 42" 10bit LCD.
There's an ExactScan option, means pixel to pixel.
After clean install of Vista 32 and then 1608 Intel drivers I get terrible fonts.
Switching TV to Wide overscales picture and make fonts a bit better but still almost unreadable.
zazan is offline
post #1011 of 1292 Old 02-16-2009, 09:15 AM - Thread Starter
archibael's Avatar
This must be a fairly new occurence, then. The G965 board looked perfect on 1080p. Something's telling the graphics drivers to scale. Unfortunately, as I am not running Vista, it's harder for me to help you. Is there a setting like "Panel Fitting" or something similar?
post #1012 of 1292 Old 02-16-2009, 02:54 PM
zazan's Avatar
Yes, there's AspectRatio Option under Intel graphics properties, which gives to adjust an overscaled screen with no problem. Fonts are better but still not intact.
And the biggest problem is that after overscale adjustment, if the TV set on Off and On with working PC, Vista gives fatal error of Windows Explorer.
So, staying with ExactScan and terrible fonts meanwhile.
Forget to say, I have G35 board.
zazan is offline
post #1013 of 1292 Old 02-16-2009, 04:44 PM - Thread Starter
archibael's Avatar
Did see a bug (supposedly solved in a driver release) of something which was inadvertently scaling then scaling again, even when it was the right resolution to begin with. Have you tried a different driver-- earlier or later?
post #1014 of 1292 Old 02-17-2009, 12:58 AM
hdejongh's Avatar
Well the strange thing is that i dont have the problem when i use VGA.
hdejongh is offline
post #1015 of 1292 Old 02-17-2009, 09:14 AM
zazan's Avatar
archibael:
Yes I have. Same thing.
What's interesting that 1920x1080P 50Hz listed in Intel properties supported resolutions, but if I run TV Wizard it recognizes my FHD LCD as 720P and put 1280x720 perfectly scaled in ExactScan.
zazan is offline
post #1016 of 1292 Old 02-27-2009, 12:14 AM
dshoe's Avatar
Hello
I apologize in advance if this may be slightly off-topic, but you guys seem to know the ins and outs of various custom settings of the Intel GMA hardware. My problem is getting the D945GCLF2 motherboard to output composite video via the 7-pin. S-Video works fine, but the manual also states:
The board supports S-Video output via a 7-pin back panel connector that provides both 4-pin S-Video and a Composite Video signal.
(Bold emphasis by me)
However, the non S-Video pins seem to be dead and I get no composite signal on those pins. The driver settings offer no option to switch from S-Video to composite (only displaying that the driver is currently switched to S-Video output) and I'm guessing now that I just need to set a hidden registry flag or key to switch from S-Video to a composite signal. I don't mind getting my hands dirty, so could someone please tell me what I need to change in the registry to achieve the desired result?
PS: Yes, I already tried the 470pf capacitor 'trick'. But the quality looked inferior to a native composite signal.
PPS: The Intel TV-Wizard is avaliable on the D945GCLF2 setup CD - although it doesn't seem to work (yet?) with this board: everyone who tried it got an error about "not having the right components". Which is a bit of a shame, because looking trough the language files of the wizard it does seem to support the setting of S-Video or composite signal.
Please help me with this if you can. I really tried everything so far but still no luck...
dshoe is offline
post #1017 of 1292 Old 02-27-2009, 09:44 AM - Thread Starter
archibael's Avatar
I don't think TVWizard ever worked with the 945 chipset of any sort.
Typically the composite vs Svideo decision is made by the chipset autodetecting which pins on the 7-pin connector are giving a 75Ohm termination-- if it's just the Y and C pins, it goes to Svideo, but if the CVBS pin is the only one connected it goes to composite.
I was never able to get any sort of registry tweak to work to select between composite, Svideo, or component on my Prolink SDVO board; I had to yank a resistor off to get the proper resistance since the design was buggy.
post #1018 of 1292 Old 02-27-2009, 11:18 AM
dshoe's Avatar
Interesting, thanks
So you're basically saying that it should switch to composite if the right pins are connected? It didn't seem to work with my 7pin cable I bought, but maybe it wasn't set to the right pins...
I think I will try again with a cable I soldered myself. From this back panel picture: https://www.logicsupply.com/blog/wp-.../d945gclf2.jpg
Which pins are the ones which carry the composite signal?
dshoe is offline
post #1019 of 1292 Old 02-27-2009, 01:12 PM - Thread Starter
archibael's Avatar
I'd have to ohm it out myself with the cable I have. I'll try to get that done at home soon.
post #1020 of 1292 Old 02-27-2009, 07:20 PM
Pheran's Avatar
Hi folks,
This utility looks promising, but I'm fairly confused about what I need to do. I've got a Dell Studio Hybrid (GMA965/X3100) plugged into a Sharp LC-19SB14U via HDMI. It seems that the Sharp is pretty stupid, because it's giving out nonsense over HDMI, like that its native resolution is 1080i. According to Sharp this is a 1366x768 panel. The display works set to 1280x720, but it's obviously being scaled as all the text looks like crap. Is there any way I can use DTDCalc to force this thing into native resolution?
Here's the output of the Intel driver:
Intel(R) Graphics Media Accelerator Driver for Mobile Report
Report Date: 02/27/2009
Report Time[hr:mm:ss]: 20:54:27
Driver Version: 7.15.10.1637
Operating System: Windows Vista (TM) Home Premium* , Service Pack 1 (6.0.6001)
Default Language: English
DirectX* Version: 10.0
Physical Memory: 3062 MB
Minimum Graphics Memory: 8 MB
Maximum Graphics Memory: 358 MB
Graphics Memory in Use: 131 MB
Processor: x86 family 6 Model 15 Stepping 13
Processor Speed: 1995 MHZ
Vendor ID: 8086
Device ID: 2A02
Device Revision: 03
* Accelerator Information *
Accelerator in Use: Mobile Intel(R) 965 Express Chipset Family
Video BIOS: 1588.0
Current Graphics Mode: 1280 by 720 True Color (60 Hz)
* Devices Connected to the Graphics Accelerator *
Active Digital Televisions: 1
* Digital Television *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 2.20
DDC2 Protocol: Supported
Maximum Image Size: Horizontal: 17.0 inches
Vertical: 9.0 inches
Monitor Supported Modes:
1280 by 720 (60 Hz)
1920 by 540 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 ff ff ff ff ff ff 00 4d 10 04 10 01 01 01 01
00 11 01 03 80 2c 19 78 0a ef ca a3 55 47 9a 24
12 47 49 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 01 1d 80 18 71 1c 16 20 58 2c
25 00 b8 fa 10 00 00 9e 01 1d 00 72 51 d0 1e 20
6e 28 55 00 b8 fa 10 00 00 1e 00 00 00 fc 00 53
48 41 52 50 20 48 44 4d 49 0a 20 20 00 00 00 fd
00 31 3d 1f 2e 08 00 0a 20 20 20 20 20 20 01 00
02 03 19 71 45 85 04 03 02 01 23 09 07 07 83 01
00 00 66 03 0c 00 10 00 80 8c 0a d0 8a 20 e0 2d
10 10 3e 96 80 b8 fa 10 00 00 18 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 6f
* SDVO Encoder Report *
** Encoder 1 **
Vendor ID: Chrontel
Device ID: 71
Device Revision: 2
Major Version: 1
Minor Version: 1
-Pheran
Pheran is offline
Reply Home Theater Computers
