HP Pavilion Slimline s3330f, is it a good prebuilt htpc? - Page 12 - AVS Forum | Home Theater Discussions And Reviews
post #331 of 336 Old 01-06-2009, 08:46 AM
ncinsguy's Avatar
i can't remember exactly how to get it out it's been awhile since i upgraded my memory, i had to go to the documentation on hp site but i think it slides to the front. go their sit it tells u how to get it out.
ncinsguy is offline
post #332 of 336 Old 01-06-2009, 09:31 AM
shivvy's Avatar
thanks, yeah I almost all optical drive slide out the front, I will get on HP's webiste, thanks again.
shivvy is offline
post #333 of 336 Old 01-12-2009, 04:09 PM
tandski's Avatar
I am interested in buying the s3330f from a guy on craigslist but he says it doesn't have a Blu-Ray/HD DVD player. I thought all s3330f's had that drive? Is that right? Also if it doesn't have Blu-Ray and is 6 mo old but in "perfect condition", is $300 a good deal for it?
tandski is offline
post #334 of 336 Old 01-12-2009, 04:20 PM
bondisdead's Avatar
Blu-Ray was an option, not an automatic thing. Depending upon the CPU, you'll likely need an upgraded video card (low-profile nvidia 8400gs/9300/9400/9500 will suffice), as the onboard vga won't cut it for blu-ray. Ask whether it uses built-in video from the motherboard or a plug-in video card. If you can get a copy of the receipt for warranty purposes, I'd call that a decent deal. My local Frys had a s3600 for $300 + tax before xmas. I got two Intel E2200 based ones with 2gb RAM and 500GB for $300 shipped, but those were refurbished with only a 90-day warranty.
bondisdead is offline
post #335 of 336 Old 01-12-2009, 06:46 PM
tandski's Avatar
Thanks for the reply. I hope I don't have to upgrade the video card, I will have to ask him tomorrow what it has. These are the specs I do know: AMD 64 X2 2.8ghz, 2gb RAM, 500gb HD, TV Tuner, and he has obviously reformatted the HD and reinstalled Vista Premium. How long are HP warranties normally?
tandski is offline
post #336 of 336 Old 01-13-2009, 12:37 PM
bondisdead's Avatar
One year. The TV tuner will take up the PCI slot, leaving you with one PCI-Express slot. That's the one you'd use to plop in a video card. You can get a low-profile card for about $30.
ALternately, if you wanted something new, I saw a s3700f at office depot for $350 + tax after rebate. Similarly equipped, but no tv tuner and only 320gb.
http://www.officedepot.com/catalog/t...archTxt=825845
Reply Home Theater Computers
