x264 Encoding Options for Hardware Compatibility & DXVA - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 269 Old 01-18-2008, 08:15 AM
tetsuo55's Avatar
According to this thread: http://forum.doom9.org/showthread.php?t=133851
B-pyramids can be used with the latest x264 builds
Unless ofcourse someone reports a problem with a certain hardware decoder?
tetsuo55 is offline
post #32 of 269 Old 01-19-2008, 11:45 PM - Thread Starter
ExDeus's Avatar
I'm still seeing issues with B-pyramids. Can't use them just yet. Details @ doom9.
Get WMC Recording Storage Pooler 1.1.0.
Get ATI HD Registry Tweaks 0.16. Updated 2009-12-31.
Get Firewire drivers for DVRs. Updated 2009-02-25.
ExDeus is offline
post #33 of 269 Old 01-20-2008, 01:53 AM
tetsuo55's Avatar
Guess we still have to wait and test more then
tetsuo55 is offline
post #34 of 269 Old 01-20-2008, 02:12 PM
DJBlu's Avatar
For all those who wanted to revert their files back to 5.0 / 5.1 then this version will allow you to.
Attachment 99816
IDC Changerv0.2.zip 9.1826171875k . file
DJBlu is offline
post #35 of 269 Old 01-21-2008, 04:06 PM
brew99's Avatar
Attachment 99816
Cheers
brew99 is offline
post #36 of 269 Old 01-24-2008, 06:48 AM
Moondust's Avatar
First of all, my appreciation goes to Tetsuo55, ExDeus, DJBlu and others that contributed to this temporary solution for all their effort. Still a question though, for DJBlu.
Why isn't it possible to do the same IDC Changer trick to 1080p encodes?
Moondust is offline
post #37 of 269 Old 01-24-2008, 07:00 AM
arfster's Avatar
It's a different problem - it seems our cards only do up to lev4.1 decoding (makes sense of a sort, given that's all Bluray needs). Most 1080p encodes break that, but 720 ones don't - as they have less pixels, they can use far less ref frames and still not exceed the limit.
IDC Changer is essentially just bypassing an oddity in the PDVD decoder, which is why it works so quickly.
arfster is offline
post #38 of 269 Old 01-24-2008, 10:49 AM
brew99's Avatar
Afster,
If this is a limitation on the hardware manufacturers and decoders who are conforming to H264 standards, I can only assume that most x264 encodes are not targeted at those of us who use the hardware acceleration, but are for software decoding. This is really to bad, as we will start to see more "stand-alone" players and NMT that support H264 with HL@4.1 max.
Am I correct in assuming that the reason they are encoded at higer levels is it allows for better picture quality with smaller file size? Essentially, why would one not encode x264 at HL@4.1 for HD, to provide a greater compatability?
brew99 is offline
post #39 of 269 Old 01-24-2008, 10:56 AM
arfster's Avatar
It's more that the importance of 4.1 limits wasn't known - dxva problems with x264 were guessed to be caused by several things (pdvd? haali?). Now it's pinned down exactly what will work I guess more stuff will be encoded to be compliant. Maybe.
For 1080p at least, I'm not sure there's much of a quality difference by using vastly more ref frames - after all, Bluray and HDDVD get away with it. People say anime benefits a lot, but other than that it may not be too much of a restriction.
arfster is offline
post #40 of 269 Old 01-24-2008, 11:26 AM
brew99's Avatar
Great, thanks for the enlightenment..........Lets hope the encoders follow the new findings, and stick within the defined limits!
BTW, just wanted to thank of those (Arfster, Tetsuo55, ExDeus, DJBlu and others) in providing the wealth of knowledge and testing required to nail down the limitation of DXVA and x264 encodes. Keep up the good work!
brew99 is offline
post #41 of 269 Old 01-24-2008, 12:41 PM
Moondust's Avatar
Ah ok, so the IDC fix applies to a 1080p encode as well, but with a big chance that it won't help due to the number of ref-frames? Is re-encoding (with right settings) possible without any loss of picture quality?
Moondust is offline
post #42 of 269 Old 01-24-2008, 02:10 PM
arfster's Avatar
Yup :-( This is why some 720p files played but with the 20fps bug, while most 1080p stuff just didn't play at all.
Re-encoding always means a quality loss though, but if you have a very detailed video in might not be too bad. If it's already blurry and has artifacts, don't bother.
arfster is offline
post #43 of 269 Old 01-24-2008, 02:36 PM
Moondust's Avatar
Crystal, thanks a lot.
Moondust is offline
post #44 of 269 Old 01-24-2008, 06:44 PM
TheShadowRunner's Avatar
DJ, would it be possible for you to bundle your application with the required .NET files? (i assume it relies on .NET, which is why it won't work here: "Application couldn't initialize correctly (0xc0000135)".
TSR
TheShadowRunner is offline
post #45 of 269 Old 01-25-2008, 01:47 AM
DJBlu's Avatar
I'll upload them tonight when I get home from work.
DJBlu is offline
post #46 of 269 Old 01-27-2008, 04:16 AM
DJBlu's Avatar
IDC Changer required dll's
If you don't want to install .net 2.0 then use these to run the IDC Changer.
DJBlu is offline
post #47 of 269 Old 01-28-2008, 04:12 AM
bran82's Avatar
Quoted: 18 Post(s)
TY all for this great explanation, and DJBlu for the tool (which worked great on the 2 files I tested it on) <3!
bran82 is offline
post #48 of 269 Old 01-29-2008, 01:53 AM
Moondust's Avatar
Any news on other decoders going to support hardware acceleration? CoreAVC for example? Or is it still only rumors?
Moondust is offline
post #49 of 269 Old 01-29-2008, 04:48 AM
arfster's Avatar
THey've been claiming they would since the very first version.
arfster is offline
post #50 of 269 Old 01-29-2008, 05:00 AM
gorman42's Avatar
Quoted: 96 Post(s)
Liked: 51
It's a shame that this process works on 720p only. Few relatively modern machines have real problems decoding 720p.
The real problem come from 1080p content.
Even though I'm pretty confident that in six months time even mainstream CPUs won't have problems decoding all 1080p content available (with CoreAVC for sure, but I trust the developers of ffdshow too).
Software decoders are getting faster, CPUs are getting faster. 1080p content complexity remains fixed. There's only one outcome possible, IMHO. And this is more significant than MPEG2, considering that the need to apply postprocessing to HD content is greatly reduced when compared to what's needed to get good picture quality out of SD.
Seriously. AVS is a place where you go to learn to be unhappy. - Bear5k
gorman42 is offline
post #51 of 269 Old 01-29-2008, 06:15 AM
arfster's Avatar
It will work with 1080p that meets 4.1 standards, and x264 presets will likely increasingly meet that.
By the way, it's possible to have software decode with ffdshow, then output with interlaced flag and it will use the graphics card for deinterlacing, sharpening, denoise etc. Quite useful when the hardware decoder is misbehaving, but you need the card's postprocessing power (eg red shifted mpeg2 stuff, or non-compliant h264).
arfster is offline
post #52 of 269 Old 01-29-2008, 07:32 AM
Moondust's Avatar
So the 4.1 standards are fine and unambiguous and Powerdvd's H264 decoder applies those standards like it should? The only problem is most encoders being unfamiliar with these 4.1 standards? Right?
Moondust is offline
post #53 of 269 Old 02-02-2008, 03:33 PM - Thread Starter
ExDeus's Avatar
I don't know if I'd say that, but Cyberlink has interpreted the standard and implemented it, and we had to learn that it was the HD DVD / Blu-ray use of H.264 that was chosen to implement (i.e., L4.1). We are now trying to establish just how it was interpreted to match its implementation.
As of right now, b-pyramids are still in question, but short of that one feature, if you encode what should be a L4.1-compliant stream, DXVA should work with the Cyberlink decoder.
ExDeus is offline
post #54 of 269 Old 02-11-2008, 03:47 AM
Moondust's Avatar
I just noticed a L4.1 encode from the scene. It had L4.1 in the filename. So it looks like the L4.1 standard has reached the scene now.
Moondust is offline
post #55 of 269 Old 02-11-2008, 03:56 AM
bran82's Avatar
Quoted: 18 Post(s)
One little question though, if you use HW-acceleration you loose the ability to use custom subs right? Cause I couldn't get them to work under Zoom Player at least.
bran82 is offline
post #56 of 269 Old 02-11-2008, 04:00 AM
Jagercola's Avatar
Anybody use meGui to make DXVA compatible files? I was wondering if anyone had a profile that had everything the first post did. I guess you would just have to change the DPB size. Some of the existing choices are "SA-HD-DVD" and "PD-PS3-XBOX360".
Jagercola is offline
post #57 of 269 Old 02-11-2008, 06:19 AM
Schlotkins's Avatar
This may be off topic, but my question is how do I take 1080i m2ts files and use x264 to encode them so they work as AVC-HD files on my PS3. Is there a simple guide for this? I've tried to use MeGUI but I also get errors or something. I'd prefer not to deinterlace them when they are encoded. Any tips are appreciated.
Chris
Schlotkins is offline
post #58 of 269 Old 02-11-2008, 08:37 AM
tetsuo55's Avatar
Finally!! i just saw the same thing, but not all L4.1 releases are tagged as such
use directvobsub and dx9 renderless
tetsuo55 is offline
post #59 of 269 Old 02-11-2008, 11:34 PM - Thread Starter
ExDeus's Avatar
Originally Posted by ExDeus View Post
The best x264 profile is the MeGUI PD-PS3 profile, with B-pyramid disabled.
The PS3 profile options, sans B-Pyramid:
--level 4.1 --ref 3 --mixed-refs --bframes 3 --b-rdo --bime --weightb --direct auto --subme 6 --trellis 1 --analyse p8x8,b8x8,i4x4,i8x8 --8x8dct --vbv-maxrate 25000 --me umh --merange 12
My MeGUI installation has a PD-PS3 profile that just needs b-pyramid disabled.
ExDeus is offline
post #60 of 269 Old 02-12-2008, 09:16 AM
Anastasis's Avatar
Valnar, would you mind posting teh profiles you use with autoMKV in xml format?
Anastasis is offline
Reply Home Theater Computers
