x264 Encoding Options for Hardware Compatibility & DXVA - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 269 Old 02-23-2008, 10:05 AM
embolism's Avatar
Originally Posted by embolism View Post
How do I get hardware decoding?
NVidia 8600GT card, using latest version
Cyberlink PowerDVD 7.3
Using MPC-HC with EVR
Thanks for any help
I was successful in getting hardware acceleration after removing all registry entries (MPC-HC) and using the version 403 (from doom9.org). Not all 720p files undergo hardware acceleration. Thanks for the IDC Changer, without which this wouldnt have been possible. I agree that hardware acceleration produces better 'quality' (just by perception). I did download the lastest NVIDIA drivers (mentioned in another thread) and it has option for 1080p24 output to my tv (52inch samsung LCD).
Have a doubt- should I expect all 720p material to undergo hardware acceleration? I can probably get 50% of them to get HA, I understand the newer files are better than the older ones.
embolism is offline
post #92 of 269 Old 02-24-2008, 01:17 PM - Thread Starter
ExDeus's Avatar
Originally Posted by ExDeus View Post
@DJBlu, I imagine there is more info you might need, but I have an MKV that won't work with IDC Changer. I get an "H264 Info not found" dialog box.
Originally Posted by DJBlu View Post
Attachment 102808
Should recognise more mkv's, i.e. earlier versions.
Thanks, worked perfectly on my problem file.
Get WMC Recording Storage Pooler 1.1.0.
Get ATI HD Registry Tweaks 0.16. Updated 2009-12-31.
Get Firewire drivers for DVRs. Updated 2009-02-25.
ExDeus is offline
post #93 of 269 Old 02-24-2008, 01:48 PM
TheShadowRunner's Avatar
DJBlu, could you bundle IDC Changerv0.3.zip with the .NET files it requires to run?
I want to avoid installing .NET at all costs and need to be able to use your program, arg!
TheShadowRunner is offline
post #94 of 269 Old 02-25-2008, 04:36 AM
gorman42's Avatar
Quoted: 62 Post(s)
Is an Nvidia 7300GT useful for DXVA?
Seriously. AVS is a place where you go to learn to be unhappy. - Bear5k
gorman42 is offline
post #95 of 269 Old 02-25-2008, 06:33 PM
embolism's Avatar
I doubt it would help @ gorman42. Has to be 8000 series.
embolism is offline
post #96 of 269 Old 02-25-2008, 11:23 PM
themolester's Avatar
its useful, but not for hd decoding, probably just for mpeg2 decoding at sd resolution. The 8500/8600 series came out with has a NEW version of purevideo (pv2.0?) decoding onboard (though i've heared some of the 8800s have it now too)
themolester is offline
post #97 of 269 Old 02-26-2008, 06:55 AM
DJBlu's Avatar
I posted them before
http://www.avsforum.com/avs-vb/showt...6#post12945196
DJBlu is offline
post #98 of 269 Old 02-26-2008, 06:57 AM
DJBlu's Avatar
I will hopefully be writing a command line version for all those that asked. If not then I will add a facility to add multiple files to the current IDC Changer.
DJBlu is offline
post #99 of 269 Old 02-26-2008, 01:12 PM
Either way would be great, I personally think it would be a waste of time to make a second completely separate program (depending on how it was coded), when command line arguments could be added with just a few lines.
Also, it would be great if you included OLE drag-n-drop functionality (drag a mkv to window, it prefills the path). I have not done this before, but I imagine its only a couple lines as well
Regardless of how it gets coded, thanks again for a very useful tool. Heres hoping we dont need it anymore ... very soon
post #100 of 269 Old 02-26-2008, 01:54 PM
DJBlu's Avatar
Console Apps are written differently as they are sequencial. I can add Ole drag n drop, will be in a few days time.
DJBlu is offline
post #101 of 269 Old 02-26-2008, 02:28 PM
DJBlu's Avatar
Attachment 103176
Added Ole drag and drop
Just drag the files you want to change into the window.
IDC Multi Changer.zip 11.619140625k . file
DJBlu is offline
post #102 of 269 Old 02-26-2008, 11:50 PM
Attachment 103176
Thank you very much, ole makes things much easier. I appriciate all the hard work.
But I must disagree with your other comment, some parts may be different, and depending on how you coded it (since you weren't planning on dual-use) it may or may not be easier just to copy and paste some code to make a second application...but you certianly CAN have a console + gui program
Many, many gui applications have command line arguments you may pass. vlc and zoomplayer are shining examples. You would be shocked at how much you can control from the command line through zoomplayer
You grab the arguments, set a variable (if you want, so you can check for it later, to autoclose, or whatever) then using code you prefill the location, change the IDC and "click" the change button.
I would not consider this a "console" application, but it would be relatively automated. If you needed to do a large quantity, the multichanger would probobly work better. For automated scripts it may be easier to have a true console application that you were planning on making.
PS. I'm getting kinda off the dxva topic, and I don't want to sound ungrateful, cause I really do appriciate the program especially with drag/drop. So, I'll stop here; you can code it whichever way you want, and we all will appriciate it either way.
post #103 of 269 Old 02-27-2008, 01:01 AM
DJBlu's Avatar
The only thing stopping the Console app is lazy programming on my part as I haven't coded the change to the mkv's in a function its just under the button. I will tho in time write the console app.
DJBlu is offline
post #104 of 269 Old 02-27-2008, 06:18 AM
gorman42's Avatar
Quoted: 62 Post(s)
I think you got it wrong. http://www.nvidia.com/object/IO_43029.html shows clearly that some form of acceleration is available. I'm just wondering if it is in any way worth it.
I have an E2160 overclocked to 2.6 GHz, if using DXVA could bring CPU utilization from 85% to 55% I'd do it, as an example. If it's just a few percentage points, then it wouldn't be worth the hassle.
gorman42 is offline
post #105 of 269 Old 02-27-2008, 11:38 AM
DJBlu's Avatar
Had sod all to do at work today so here you go
Console Version
Attachment 103261
IDCChange.zip 5.80078125k . file
DJBlu is offline
post #106 of 269 Old 02-27-2008, 03:39 PM
hrmm... you seem to be right, some accelleration of h264 IS in fact available in the vast majority of the geforce line. I guess what I was referring to, is the lack of IDCT and CAVLC/CABAC as that was only available on the 8500/8600 series. How much of a difference this makes, I'm not sure...
I have not tried to get a non-8500/8600 to decode h264 before, so I'm not even sure what the process would be (if it is even different). All I can say, is try it out, and see if it works. I looked up the definition, and somone else may be able to give a more scientific explination... but IDCT stands for inverse discrete cosine transform.... maybe its just me, but that sounds like some complex calculations, and a good thing to offload from cpu.
Also important to mention however, if you check on newegg, you'll find some VERY cheap 8500s available; they start at just over 50 dollars. You will no doubt notice more power in games, and you will have the fullest hw acceleration possible. I just recently upgraded myself to get the 8600gts for a little over 100. Was a very nice purchase, and I'd do it again. No doubt this is far cheaper than upgrading 200 bucks on a new core2 chip or an equivelant to do full software decoding (which... admitedly, will decode a wider variety of things with fewer compatability problems).
Anyway, I tentatively retract my previous statement; could some one please clarify how much processing is required for hd h264 decoding of idct and cavlc/cabac compared to the rest of the h264 decoding? Is it a good chunk of the processing, or just 1-2 % on top of the rest.
post #107 of 269 Old 02-27-2008, 04:53 PM
arfster's Avatar
I had a 7300GT a while back - although it would accelerate h264 (near halving CPU), it would skip at times on more complicated scenes. Not enough memory bandwidth, someone suggested.
arfster is offline
post #108 of 269 Old 02-27-2008, 06:28 PM
embolism's Avatar
Console Version
Attachment 103261
Whats the console version supposed to do? On vista, nothing happens after I unzip and execute the file. Im not a tech guy..
embolism is offline
post #109 of 269 Old 02-27-2008, 09:43 PM - Thread Starter
ExDeus's Avatar
Attachment 103176
So, one additional request... adding the ability to pre-populate the list of files in this GUI version from a command-line argument. That would be the best of both worlds: The ability to add a context-menu item for .mkv and .avi files to edit them in the IDC Multi Changer, and the ability to drag 'n' drop in new files. The console app could be used instead, but I'm not into batch processing, just ease of access to the program.
Also, when I click the Add Files button, I get the following exception:
Unhandled exception
Method not found: 'System.String[]
System.Windows.Forms.OpenFileDialog.get_SafeFileNames()'.
Code:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.MissingMethodException: Method not found: 'System.String[] System.Windows.Forms.OpenFileDialog.get_SafeFileNames()'.
   at WindowsApplication1.F.Button1_Click(Object sender, EventArgs e)
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.832 (QFE.050727-8300)
    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
IDC Changer
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/IDC%20Changer/IDC%20Multi%20Changer.exe
Microsoft.VisualBasic
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.42 (RTM.050727-4200)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Data
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
ExDeus is offline
post #110 of 269 Old 02-28-2008, 01:55 AM
DJBlu's Avatar
I wouldn't use this version if you don't know what the console is.
Try the one further up the page
DJBlu is offline
post #111 of 269 Old 02-28-2008, 03:55 PM
ricabullah's Avatar
Hi guys; thanks for all.
I'm not familiar with X264 and mkv.
Anyway i've made some encoding trials with meGui (X264 v.736) with L 4.1.
OS Vista32, Rendering graph: Haali Splitter > Cyberlink h264 decoder(latest Ultra patched) > EVR.
(HW: E6750, 2GB RAM 800Mhz, nVidia 8600GTS)
CPU usage is %13 with Cyberlink while ffdshow consumpts %44.
So hardware decoding is working but on the other hand, hardware deinterlacing never works.
(the source file was European HDTV h264 mpegTS 1920*1088i)
Here is a SS: (here, source file was 1440*1088i)
Any help from you experienced users will be appreciated.
Chronical Tester
ricabullah is offline
post #112 of 269 Old 03-02-2008, 12:28 AM
rebkell's Avatar
Quoted: 413 Post(s)
Liked: 283
What does your avs file look like, did you run Avisynth creator in megui? If not, let it analyse the source and make an avs script for you My first guess would be you need to deinterlace the source, probably with tfm() .. the Avisynth creator will let you see what the output will look like.
rebkell is offline
post #113 of 269 Old 03-02-2008, 09:00 AM
ricabullah's Avatar
Hi rebkell, thanks for respond.
I was just investigating hardware deinterlacing capability of x264 L4.1 as well.
Normally, i prefer to re-encode h264 source files to h264 again and leave them interlaced.
So finally i can watch them on HA mode.
After i understood x264 just gives hardware decoding, i've found this method for converting to x264.
This method is for interlaced source files.
First, i demux the source ts file and dump original ac3.
After re-encoding to x264, i remux encoded video with original audio into mkv using Haali muxer.
I prepare this graph: (you don't need to resize of course)
And i save this text as avs:
Here is my megui config:
Here are the sample files:
(Decoding graph:
For Vista: Haali Splitter > Cyberlink h264 decoder (of Ultra) > EVR
For XP: Haali Splitter > Cyberlink h264 decoder (of Ultra) > Overlay (or WMR9) )
Source file:
http://rapidshare.com/files/95449126/tenis.ts.html
Encoded file without deinterlacing and resizing: (HA)
http://rapidshare.com/files/95480185/tenis.mkv.html
Encoded file with deinterlacing and resizing: (HA)
http://rapidshare.com/files/96213704..._rica.mkv.html
Chronical Tester
post #114 of 269 Old 03-02-2008, 05:06 PM
jedicouncil's Avatar
The console version works without a hitch. Thanks!
jedicouncil is offline
post #115 of 269 Old 03-02-2008, 05:32 PM
rebkell's Avatar
Quoted: 413 Post(s)
Liked: 283
Rica I have no suggestions, you're in territory I've never been around. doom9.org is where the pros hang out.
rebkell is offline
post #116 of 269 Old 03-02-2008, 05:58 PM
ricabullah's Avatar
Thanks rebkell; i hang out here since i'm not a pro
BTW, there are lots of pros here.
This, i think, explains why i'm here.
Chronical Tester
post #117 of 269 Old 03-04-2008, 05:24 AM
Moondust's Avatar
I decided to give HA another try today and I actually got it working (x264), even at 1024x576 (projector native resolution). I am thrilled! BUT (there it is) HA doesn't seem to kick in when the auto-loading version of DirectVobSub is loaded. I am using AC3Filter, DirectSound, VMR9 renderless (only one working with HA) and the Cyberlink H264 decoder. What can I do to be able to display subtitles?
[edit]
Ow boy, I have been cheering too soon. When using HA there is some kind of macroblocking/dithering on a large scale. It also flickers in those areas where the picture is distorted. It's not watchable though since it's not a smooth picture. Does any of you know what this is and how I can fix it?
[/edit]
Moondust is offline
post #118 of 269 Old 03-06-2008, 07:04 AM
embolism's Avatar
Regarding HA for 1080p, I heard doing this might help:
Change the Level to 4.1 and use 5 Ref Frames for 1080p
DJ - with your application, we change profile to 4.1
How does one use 5 ref frames?
Has anybody achieved acceleration for 1080p on any graphic card?
embolism is offline
post #119 of 269 Old 03-06-2008, 08:03 AM
tetsuo55's Avatar
[edit]
[/edit]
you need to disable directvobsub and enable the built in subtitle decoder of MediaPlayerClassic
tetsuo55 is offline
post #120 of 269 Old 03-06-2008, 11:12 AM
Moondust's Avatar
Originally Posted by tetsuo55 View Post
you need to disable directvobsub and enable the built in subtitle decoder of powerdvd
Thanks for replying. I use MPC-HC with the Powerdvd H264 decoder. I haven't been able to load an x264 mkv file in Powerdvd (version 7.3319a). Is there a subtitle possibility other than directvobsub in MPC-HC?
Moondust is offline
Reply Home Theater Computers
