1080 desktop resolution - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-09-2008, 01:16 PM - Thread Starter
homepc's Avatar
I would like to set my resolution on my desktop to 1080. I use this computer to watch DVD and pictures. But I would also like to use it for some internet. With this resolution, evything is WAY SMALL of course!! Is there any way I can keep my 1080 resolution and just "Enlarge" all the windows elements such as text, icons, title bars, etc.
I have played with the appearance settings and have it at least readable, but that doesn't help with the internet text. I do have internet explorer set to the largest text, but it still isn't big enough. I thought maybe there might be some utility that would enlarge everything? No?
Ray
homepc is offline
post #2 of 7 Old 01-09-2008, 02:38 PM
fitbrit's Avatar
Quoted: 54 Post(s)
Liked: 50
I believe Safari does that. Also, Firefox (maybe IE too) hold down ctrl and try your mouse scroll down- this will enlarge text in your browser.
fitbrit is offline
post #3 of 7 Old 01-09-2008, 02:38 PM
Justmtnb44's Avatar
If you use Mozilla Firefox as your web browser, you can hold Ctrl + mouse wheel to change the size of the text on web pages.
Justmtnb44 is offline
post #4 of 7 Old 01-09-2008, 03:13 PM
craysv1's Avatar
set your dpi higher
craysv1 is offline
post #5 of 7 Old 01-09-2008, 03:16 PM
bjmarchini's Avatar
get a bigger screen. I can read 1080 no problem at 92"
HD DVD: 45 SD DVD: 350 BR: 120
PCs: 12, Mame Arcade:1, HD HTPC: 1, WHS Server: 1, HD A3: 2, HD-A30: 1
bjmarchini is offline
post #6 of 7 Old 01-09-2008, 03:19 PM
sgriffin's Avatar
Opera works fine with multiple levels of zoom!
sgriffin is offline
post #7 of 7 Old 01-09-2008, 08:41 PM - Thread Starter
homepc's Avatar
Firefox and DPI works great!! THanks!!
homepc is offline
Reply Home Theater Computers
