Stream Cable Over Wireless Network + PVR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-11-2008, 07:21 AM - Thread Starter
jriggs420's Avatar
Hi all, new here, hope I'm posting in the correct forum.
How can I use my existing wireless network to stream cable TV broadcast? I would also like to be able to change the channel over the network. Is this even possible? I don't have HD, so that's not a concern (yet).
I also need a recommendation on a video card that will allow me to view the cable signal on my comp to record as well as broadcast it wirelessly.
I'm on Windows XP, just a basic desktop for now. I consider myself technically adept, but this area has a steep learning curve with a multitude of options, so thanks in advance for any suggestions and/or links-
jr
jriggs420 is offline
post #2 of 3 Old 01-11-2008, 09:00 AM
MikeE's Avatar
MikeE is offline
post #3 of 3 Old 01-11-2008, 09:23 AM
MrBostn's Avatar
You may find that video over a wireless network isn't that great. You'll need to have at least a G network, and probably N. Encryption may hinder it also. You may need to shut off any security on the wireless to get enough bandwidth
MrBostn is offline
Reply Home Theater Computers
