no option for spdif in powerdvd - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 01-20-2008, 07:49 AM - Thread Starter
jtb19nh's Avatar
i am using powerdvd 7.3 ultra, I have a asus p5ad2-e deluxe mobo, i am using the onboard audio/ c-media cmi 9880. In powerdvd there is no option for spdif, if i select 6 speakers the sound will come out all speakers. any one have any ideas what is causing this? I did just install the vista codec pack, but im not sure if the option was the install.
jtb19nh is offline
post #2 of 16 Old 01-20-2008, 07:53 AM - Thread Starter
jtb19nh's Avatar
also there is the spdif option in the arcsoft player but when i select it i get no sound. if i select 5.1 i get sound!
jtb19nh is offline
post #3 of 16 Old 01-20-2008, 09:50 AM
Eluder's Avatar
Quoted: 40 Post(s)
So under the audio tab in PDVD you don't have the option for Use SPDif under Speaker Environment? That seems pretty strange. What OS are you using?
Eluder is offline
post #4 of 16 Old 01-20-2008, 10:27 AM - Thread Starter
jtb19nh's Avatar
that is correct there is no option for spdif. im using vista.,
jtb19nh is offline
post #5 of 16 Old 01-20-2008, 10:32 AM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
huh??
kapone is offline
post #6 of 16 Old 01-20-2008, 10:41 AM
Storme's Avatar
what is selected as default in your control panel? do you have SPDIF as an option in there? what happens when you click test?
Storme is offline
post #7 of 16 Old 01-20-2008, 10:42 AM
720p's Avatar
Make sure you are not playing anything when you click on the configuration button in pdvd.
720p is offline
post #8 of 16 Old 01-20-2008, 10:47 AM - Thread Starter
jtb19nh's Avatar
[/IMG]
jtb19nh is offline
post #9 of 16 Old 01-20-2008, 10:53 AM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
Is your SPDIF connected and configured under Windows?
kapone is offline
post #10 of 16 Old 01-20-2008, 10:57 AM - Thread Starter
jtb19nh's Avatar
yes it is connected. thats how im getting my sound!!!
jtb19nh is offline
post #11 of 16 Old 01-25-2008, 03:26 PM
htc@htc.be's Avatar
When I have AC3filter installed I see the 'use SPDIF' label in the drop down menu in PowerDVD audio settings. When it is not installed I do not see it.
It has to do with the setting inside AC3filter.
Whatever I do, I do not get 5.1 through the SPDIF :-(
EDIT:
I stopped DVDpower Ultra. I did deinstall AC3filter. I reinstalled it. I started DVDpower but before starting the DVD to test what was happening, I did go into the sttings wher I did see 'use SPDIF' again. I did choose that option and now it works! Extremely strange and not very logical at all.
I do have 5.1 in my DENON AVR4308. :-)
htc@htc.be is offline
post #12 of 16 Old 01-25-2008, 03:53 PM
ES_Revenge's Avatar
Quoted: 411 Post(s)
Liked: 133
Do you have the retail version of PDVD Ultra or the OEM version? The OEM version only supports 2ch in 99% of cases.
Edit: Okay, nm, you have the retail I think from your dropbox...
I'm guessing this is XP since you're using AC3filter... In that case be sure that AC3filter is setup properly for pass-through of DD/DTS streams.
Edit2: Okay I see you say you're using Vista? Then you shouldn't need AC3filter at all--that will likely just mess things up. Be sure you have your latest sound driver installed (from C-Media not your board maker, as board manufacturers usually don't update links/drivers that often). Then make sure your digital output settings are correct in Vista's sound control panel applet.
ES_Revenge is offline
post #13 of 16 Old 01-25-2008, 05:00 PM
Aesculus's Avatar
Quoted: 18 Post(s)
EDIT:
Check to see if you have the SPDIF running in exclusive mode in Windows. If so then the AC3Filter would have it locked and no other app would be able to write to the device.
Chris
Aesculus is offline
post #14 of 16 Old 01-26-2008, 09:45 AM - Thread Starter
jtb19nh's Avatar
the digital output setting says it is working, but when i hit test i dont get any sound. If i hit test on speakers i get sound through all speakers.
jtb19nh is offline
post #15 of 16 Old 06-07-2008, 12:05 PM
kklarson's Avatar
This gave me the clue I needed. I did have another piece of software running that was also using the SPDIF output, BeyondTV. When I closed it, SPDIF became an option in my OEM version of PowerDVD BD that came with my Lite-On DH-4O1S-08 Blu-ray drive. I can now use PowerDVD BD OEM to play Blu-ray movies with Dolby Digital 5.1 output and have no need to splurge for the upgraded version.
kklarson is offline
post #16 of 16 Old 06-07-2008, 09:50 PM
astrallite's Avatar
Quoted: 25 Post(s)
Liked: 26
That's funny for me there is no output in powerdvd in vista with spdif but with ac3filter + media player classic its flawless with all mcpcm sources.
astrallite is offline
Reply Home Theater Computers
