Anyway to make a digital out port? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-21-2008, 09:16 AM - Thread Starter
acencha's Avatar
I remember I read somewhere that there was a way to make a digital out port for a computer without one, but I can't seem to find it. Does anyone know how to make one? I don't want to buy another sound card just for that.
acencha is offline
post #2 of 3 Old 01-21-2008, 09:22 AM
vladd's Avatar
Liked: 39
If your motherboard has a spdif out header, you can make a coax connector for it easily. Ignore the 5V pin and just connect the other two to a female RCA jack.
vladd is offline
post #3 of 3 Old 01-21-2008, 05:48 PM
GaryD123's Avatar
My MSI mobo has a 3 pin connector for a spdif connector. I was able to buy an Asus spdif board with Toslink and a Coax connecters which is a small PCB and a bit of electronics on it. I used an audio cable from a CD Rom drive and pulled the pins out and use that as the cable to connect it.
GaryD123 is offline
Reply Home Theater Computers
