Arcsoft TotalMedia Theatre - Page 148 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #4411 of 4463 Old 03-29-2012, 11:58 AM
tj_jokestar's Avatar
does anybody know if there is still support for 3 for new blurays or are we forced to upgrade to 5 now. Im currently using 3.0.1.190 trying to watch star wars on bd and it says i need an update but arcsoft says its the current version
tj_jokestar is offline
post #4412 of 4463 Old 04-05-2012, 06:57 PM
isamu's Avatar
Quoted: 34 Post(s)
Maybe I'll try this out. Is it a better player than say, VLC and MPC?
isamu is offline
post #4413 of 4463 Old 04-06-2012, 08:19 AM
dabl's Avatar
http://www.arcsoft.com/forum/forum_p...-release-notes
Arcsoft update and/or notification mechanism(s) have been less than ideal recently.
There was an update to v5 in March but the only way to get it is to uninstall your current version and reinstall the currently available trial version.
dabl is offline
post #4414 of 4463 Old 04-06-2012, 07:11 PM
thanks decided to upgrade to five since they had it on sale, everything's works great thanks
post #4415 of 4463 Old 04-18-2012, 09:51 AM
charlievoviii's Avatar
im about to get my money back, their tech support is a joke.
charlievoviii is offline
post #4416 of 4463 Old 05-31-2012, 01:16 PM
holyindian's Avatar
Quoted: 83 Post(s)
Liked: 44
I am trying to set the audio options in TMT 5. Under AV Center I dont get to see the Sound Cards in the drop down list under Audio Output. Neither do i see output mode.
I am using a pretty good Graphic card, its a ASUS HD7850-DCII
OS is Windows 7
And my HTPC is connected to an A/V Denon 4311CI, which is capable of handling all the latest sound technologies.
holyindian is offline
post #4417 of 4463 Old 05-31-2012, 05:38 PM
Davinleeds's Avatar
Select the audio, select your output. Using 7770
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #4418 of 4463 Old 05-31-2012, 09:45 PM
randalthor's Avatar
I just purchased TMT5 for $50 two days ago. I was able to use the coupon code: SOFTTMT5 Just thought I'd share that with you guys.
I'm really liking the program so far, but I have one minor annoyance. Whenever I play a blu ray, the sub menu is on screen and I have to close it each time. It's the menu that has the play, pause, stop, etc. buttons on it. I don't want to have to close this sub menu every time I play a blu ray. Is there a setting to stop TMT5 from having this menu open by default?
"Here on the moon, our weekends are so advanced, they encompass the entire week." Ignignokt from Aqua Teen Hunger Force
randalthor is offline
post #4419 of 4463 Old 06-03-2012, 06:49 PM
Shanndogg's Avatar
Is there a way to use LAV Splitter in conjunction with TMT 5 so that only forced subtitles from MKV are sent to TMT 5? My free trial ran out so I can't test this, but I know TMT 5 has mkv subtitles always on by default which is a killer for me. I just recently started messing around with MPC-HC with LAV and wondered if there is a way to get LAV to work with TMT 5.
Shanndogg is offline
post #4420 of 4463 Old 06-24-2013, 11:53 AM
jnd53's Avatar
I am using 5. I upgraded to 6.0 on windows 7 pro, but with the problems I had playing or should I say not playing blu-ray iso files. I switched back to 5.0 wish I could get my money back for the upgrade.
JD
jnd53 is offline
post #4421 of 4463 Old 06-24-2013, 01:13 PM
Zasekamoz's Avatar
JD
Which version of TMT 5 do you have now?
Zasekamoz is offline
post #4422 of 4463 Old 06-25-2013, 11:47 AM
jnd53's Avatar
TMT5 (5.2) Version 5.3.1.146
jnd53 is offline
post #4423 of 4463 Old 06-25-2013, 11:58 PM
elesapp's Avatar
okay.In the Reservoid dogs shot. It looks like makeup on his face. Under the eyes. 10.gif
elesapp is offline
post #4424 of 4463 Old 06-26-2013, 02:37 PM
Elpee's Avatar
Quoted: 61 Post(s)
Looks like a lot of questions here not answered.
Elpee is offline
post #4425 of 4463 Old 08-18-2013, 01:43 PM
mcguidance's Avatar
Is this still the best option for Windows media center for playing BRs?
mcguidance is offline
post #4426 of 4463 Old 08-18-2013, 02:09 PM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
im still using tmt5 and I cant imagine something better. well i guess i can, but cant realistically see something better. my drive came with powerdvd so that's my only other experience with bluray playback.
i use media center studio to customize my themes and with tmt5 i could change the PNG files it uses to mimic the wmc blue background to ones that came from my mcs theme. so flipping from wmc, media browser, and tmt5 are all mostly transparent given the same background
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #4427 of 4463 Old 01-31-2014, 07:59 AM
originalsnuffy's Avatar
Does anybody know how to enable 5.1 output decoding when playing a single MT2S file in version 6.5 ? Do I need to change a DLL or something?
I took a look in the registry under Arcsoft and did not see much to work with. Perhaps the important registry entries are tucked away?
I am playing 2001 and Clockwork Orange which are multi channel. But TMT is only sending stereo to the HDMI on my receiver. At one point I had this working, I thought. I am not sure what went wrong.
The audio options only show HDMI and decode to PCM. Which makes sense as my receiver can only take that. But there are no options related to choosing 5.1 etc.
The receiver can receive 5.1 LPCM from MPC-HC on this machine just fine so its not a receiver issue.
The software is activated and licensed.
originalsnuffy is offline
post #4428 of 4463 Old 02-01-2014, 09:15 AM
Elpee's Avatar
Quoted: 61 Post(s)
A real quick question.
I can play m2ts folders just fine with TMT 5 or 6. But everytime I play .mkv movies I ALWAYS get the error as below
I don't know how to fix it.
Please help!
Thank you very much.
Elpee is offline
post #4429 of 4463 Old 02-01-2014, 09:25 AM
kokap's Avatar
kokap is offline
post #4430 of 4463 Old 02-01-2014, 06:13 PM
Elpee's Avatar
Quoted: 61 Post(s)
Fixed it. A thump up for your help that definitely saves me time to contact TMT CS.
Elpee is offline
post #4431 of 4463 Old 07-16-2014, 02:21 PM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
Does TMT still support HDDVD playback??
vcrpro3 is offline
post #4432 of 4463 Old 07-16-2014, 02:35 PM
Quoted: 648 Post(s)
Liked: 426
Yes ^^^ If you look in my post a few up disc on the right side of the screen in my Troy HD-DVD.
post #4433 of 4463 Old 07-16-2014, 02:37 PM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
A mystery:Playing blu ray movies in TMT6 with Dolby Digital TrueHD and DTS HD soundtracks...
The hardware-Asrock FM2A85X Exteme 6 MB, AMD A8-5600 APU with Radeon HD7650 video, Asus Xonar HDAV1.3 soundcard.
The result- During the intro and menu phase of the disc when the audio is either regular DD or DTS, audio playback is fine. I have the information panel open that shows video and audio codec open, once the main title comes up in either HD audio formats, all audio goes away. Playback with either Power DVD or WinDVD has no problems...If using onboard Realtek 892 audio-no problem.. I am using the Xonar because of the convienience of having the RCA connectors on it and its daughtercard as i am feeding directly to a Marantz 5 channel power amp, and, its sound quality is much better than the onboard audio chipset. Any insights???
(same thing for TMT5)
vcrpro3 is offline
post #4434 of 4463 Old 07-16-2014, 02:50 PM
Dark_Slayer's Avatar
Quoted: 655 Post(s)
Liked: 434
5.1 HD audio needs 6 RCA connections and 7.1 needs 8. Sounds like you have 6 with one going directly to your sub? Have you tried a blu ray that you specifically know is 5.1 dts-hd?
Dark_Slayer is online now
post #4435 of 4463 Old 07-16-2014, 03:59 PM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
Got it hooked up correctly...as i said, regular DD and DTS give surround audio...the HD flavors do not......
vcrpro3 is offline
post #4436 of 4463 Old 07-16-2014, 04:02 PM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
My TMT6 (even after several installs and uninstalls) on 2 different machines crashes when trying to play an HDDVD..DVD and Blu Ray are ok...
QUOTE=pittsoccer33;25797537]Yes ^^^ If you look in my post a few up disc on the right side of the screen in my Troy HD-DVD.[/QUOTE]
vcrpro3 is offline
post #4437 of 4463 Old 07-16-2014, 05:15 PM
Quoted: 648 Post(s)
Liked: 426
im still on tmt5
post #4438 of 4463 Old 07-16-2014, 05:54 PM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
I had TMT5. It stopped playing most Blu Ray discs and was displaying a critical update was needed but would never download or install said update. Going to the Arcsoft website and looking for TMT5 update yielded nothing.......
Originally Posted by pittsoccer33 View Post
im still on tmt5
vcrpro3 is offline
post #4439 of 4463 Old 07-16-2014, 10:02 PM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
...Damned sad when you have to run another expensive program to get the first expensive program to work somewhat correctly; Playing HD-DVDs will only work with AnyDvd active.....
vcrpro3 is offline
post #4440 of 4463 Old 07-16-2014, 11:11 PM
1gkar's Avatar
Have built a 3D-capable HTPC utilizing Intel HD4600 iGPU. Have an LG 55" 3D LEDTV that suffers from overscan, or scaling issue where I have to adjust from full 1980x1080p resolution. Intel's graphic (driver version=10.18.10.3621) card properties will not allow me to save -or restore- my rescaled resolution.
Whenever I used the latest TMT6 trial version to playback 3D isos, it plays great. However, when I close out of the programme, it readjusts my resolution back to full 1080p. I then have to manually readjust back to my rescaled res.
I emailed Arcsoft, but their {lack of}support staff only told me what I already knew. No advice on how -or- if it would be rectified. I responded stating I won't be spending any money their way, then.
I assume this is an Intel issue? If so, does anyone know if, or can it, be fixed? I assume not every graphics card drivers/software has the same (or similar) issues? Any work-arounds that will allow TMT6 to restore to my rescaled res? I would buy TMT6 in a heartbeat, except for this issue.
Thanks in advance.
The only way to enlightenment is to ask.
1gkar is offline
Reply Home Theater Computers
