Arcsoft TotalMedia Theatre - Page 149 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #4441 of 4463 Old 07-17-2014, 02:03 AM
pittsoccer33's Avatar
Quoted: 650 Post(s)
Liked: 432
Why not change your tv overscan setting? You can set it to pixel map a 1080p source - I just did a cousins LG recently. I think I found it under the picture menu.
pittsoccer33 is offline
post #4442 of 4463 Old 08-12-2014, 02:07 AM
1gkar's Avatar
Sorry about delay in responding. My TV does not have any such menu option. So, not sure what other possibilities are available, as nothing appears close inside TV menu.
The only way to enlightenment is to ask.
1gkar is offline
post #4443 of 4463 Old 08-12-2014, 06:35 AM
Quoted: 650 Post(s)
Liked: 432
^^I think what you want to enable is called JUST SCAN under the picture/aspect ratio settings.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
post #4444 of 4463 Old 09-05-2014, 12:01 PM
Hagar's Avatar
ARC Soft support
Just thought I'd throw in what I consider to be just remarkable support. I have the Asus Xonar HDAV 1.3 Dlx (and slim on another computer) and wanted to try the Total Media that came with the Asus card. I could not find the disk with the serial # on it.. I have it, just can't find it. So I asked Arcsoft if they could help me out with a serial so I could run version 3.0.13.144.
They did better then that, they sent me a link for the newest version 6.7 I think and a serial. Wow.
Now will this work with the Asus Xonar HDAV 1.3 DLX card like version 3? Do I really care?
I play BD through my Oppo 105D. But have a lot of DVD's on the computer.
But way to go ARCSOFT.
Dave
Hagar is offline
post #4445 of 4463 Old 09-07-2014, 08:47 AM
dazz87's Avatar
Quoted: 80 Post(s)
Liked: 40
Nm figure it out.
dazz87 is offline
post #4446 of 4463 Old 09-21-2014, 07:57 AM
Aryn Ravenlocke's Avatar
Quoted: 351 Post(s)
Liked: 134
Just curious, now that Total Media Theater has been completely discontinued and all traces except forum discussions removed from Arcsoft's site, what solution are folks going to use? Does this mean everyone starts using PowerDVD even though it is not a terribly good product?
whatever_gong82 likes this.
Aryn Ravenlocke is offline
post #4447 of 4463 Old 09-22-2014, 09:49 AM
Dahlsim's Avatar
I have both PowerDVD & TMT. TMT has often worked at times when PowerDVD wouldn't on a file or disk.
Hate to see it go, can still pull up the page link http://www.arcsoft.com/totalmedia-theatre/overview.html but not download.
Last version went to the Win 8.1 target so if it's solid it might be worth using for the foreseeable future on applicable media.
Family DVD Collection
Insider thread last question? R.I.P.
Nothing will ever be attempted if all possible objections must first be overcome.
Samuel Johnson 1709-1784, British Author
Dahlsim is offline
post #4448 of 4463 Old 09-22-2014, 11:24 AM
Quoted: 351 Post(s)
Liked: 134
I still have TMT 5. I was hoping to upgrade to 6 here in the near future now that I have my uber-server up and running. Alas, it seems that I will be having to find another solution.
post #4449 of 4463 Old 11-02-2014, 07:27 AM
whatever_gong82's Avatar
Sorry to bring back an old thread, but now that TMT is no more, it looks like all of us who are a video enthusiastic will have to find another solution. And, what's left as alternatives is the best of a sorry lot.
whatever_gong82 is offline
post #4450 of 4463 Old 11-02-2014, 07:29 AM
Hate to see it go, can still pull up the page link but not download.
I have TMT 5 and TMT 6, PowerDVD 14, and WinDVD 11 (Cinavia enabled.)
Review of PowerDVD 14--bloated and intrusive, and has the Cinavia crap on top of it.(I wished I got the last PowerDVD version before Cinavia was required of it by the MPAA and Sony. Oh well.) Wants to change your preferences to what Cyberlink wants, not what you want. I've since changed the preferences back to what I want, and set Windows to automatically not enable PowerDVD. I'll use it from time to time when TMT isn't working right on a disc, but it's not that often.
Review of WinDVD 11--Cinavia enabled as mentioned before. It works ok, but no great shakes, in my opinion. Even PowerDVD 14 runs rings around WinDVD 11. I have it only because the good people over at the Slysoft Forum recommended it. If I was to use another Blu-ray disc/DVD player, WinDVD would be the next to last one I would use. (Nero is bloated crap, and I refuse to use that piece of alleged 'software' on any PC of mine again.)
post #4451 of 4463 Old 11-02-2014, 07:30 AM
I would use TMT 5 until your OS can't support it anymore. I was trying to see if TMT 3 would work on my Windows 8.1 PC, but I found out it does not. It does, however, work on my Windows 7 laptop, so at least I have a quality Blu-ray/DVD player for my laptop. (And the weird thing is--I somehow got wise ahead of time, and bought 3 licenses apiece for TMT 5 and TMT 6 to use for my PC and 2 laptops, so I won't have to worry too much about playback choices for Blu-ray discs/DVDs for the foreseeable future.)
post #4452 of 4463 Old 11-03-2014, 08:57 AM
pochoboy's Avatar
Quoted: 27 Post(s)
I've just installed mpc-be and it looks like it supports blu-ray playback although I haven't tried it myself yet because I'm waiting for delivery on a new tv. I have tmt6 and was wondering if any or you had to chance to use mpc-be and maybe have an opinion on it vs. tmt6?
pochoboy is offline
post #4453 of 4463 Old 11-04-2014, 04:11 PM
Stereodude's Avatar
Quoted: 3454 Post(s)
Liked: 2527
MPC-HC and MPC-BE don't support BD menus. That's not necessarily a big problem if you only want to play the main movie. A more annoying issue is that they don't parse the various set stream commands in the .bdmv file associated with the playlist they select, so things like forced subtitle or audio tracks aren't automatically selected / enabled. So, you can be watching something like Thor: The Dark World with soft subtitles and you have to manually go through the subtitles and find the subtitle track that should have been enabled (after you figure out that you're missing the soft subtitles in the first place). The players also will default to playing back the longest playlist on the disc which makes them susceptible to some of the copy protection schemes that repeat scenes and change the order of scenes on the disc.
Stereodude is offline
post #4454 of 4463 Old 11-04-2014, 09:55 PM
pochoboy's Avatar
Quoted: 27 Post(s)
Stereodude,
yeah, I fiddle a bit with mpc and a blu-ray and saw that, Thanks! Guess I'll try to use tmt6 and possibly a stand alone bluray player.
Kinda tough having no menu options from the start.
pochoboy is offline
post #4455 of 4463 Old 12-30-2014, 03:34 AM
SJMAYE's Avatar
Stuttering after upgrade to TMT6
I upgraded from 5 back about 2 days before they pulled the plug on TMT. I have always had an on again off again problem with stuttered playback of blu-rays. It is ON-AGAIN. Can someone give me some tips? I have searched Stuttering. Is there a different term? It appears to be related to reading off the disc at playback as I have no issue when the blu-ray is ripped to my hard disk.
SJMAYE is offline
post #4456 of 4463 Old 12-30-2014, 10:25 AM
John P's Avatar
Quoted: 12 Post(s)
Try turning off Hardware Acceleration. If you are using Windows Media Center Hardware Acceleration must be turned off in both the application as you would run it from the desktop and from within Media Center. As I recall while playing a movie in Media Center right click on the screen and you should be able to get to the settings.
John P is offline
post #4457 of 4463 Old 12-30-2014, 10:48 AM
SJMAYE's Avatar
Hello John,
Thank you for your reply. I checked both within Media Center and running TMT6 from desktop. Both already show hardware acceleration off. Do you have any other thoughts? In case it matters the HTPC is running Intel HD 4000 graphics.
SJMAYE is offline
post #4458 of 4463 Old 01-21-2015, 12:04 PM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
TMT6 not WMC friendly?
Just came across a machine loaded with TMT6, but it looks like a standard PC software to me, not remote-operable but rely on the kbd/mouse. Sure it installed itself as an App under WMC but that's is, no "ten-foot" interface.
Am I missing something?
I thought TMT was like the BEST HTPC BR player? What good is it if it doesn't have the "ten-foot" interface?
MrBobb is offline
post #4459 of 4463 Old 01-21-2015, 12:18 PM
Brahmzy's Avatar
Quoted: 481 Post(s)
Liked: 371
Dude, TMT is a plug-in FOR WMC. WMC is your 10ft interface, which uses a remote.
HTPC | 12TB NAS | Harmony Elite | DENON X4200W | Sony XBR75X940D
Philips BDP7501 | Klipsch RF7II,RC64II,CDT5650CII | SVS SB2000 x2
Brahmzy is offline
post #4460 of 4463 Old 01-22-2015, 02:49 AM
SJMAYE's Avatar
Correct. Just seems to have a problem working....at least for me. I have owned 3 versions of this software. Each one flaky. I have all but given up on it and gone to using my PS3 for BluRay playback.
SJMAYE is offline
post #4461 of 4463 Old 07-30-2015, 02:44 PM
Liked: 0
Started receiving spam a few days ago at the e-mail address I used exclusively to buy TMT5 direct from Arcsoft a few years ago, making it appear there's been some sort of breach/leak of customer info at Arcsoft (e-mail addresses at least).
Wondering if anyone else who purchased it has any of the following messages sitting in their spam folder from the past few days:
Subject: Re: Are you struggling with Federal or Private student loans?
Subject: Re:call for details.
Subject: I think you need to know this...
See attached image for the from addresses etc.
heisenbug is offline
post #4462 of 4463 Old 08-08-2015, 08:14 PM
Chalupacabra's Avatar
Just fired up my HTPC after a long hiatus in use. Am running TMT5 version 5.3.1.196 along with AnyDVD HD. Every time I load a disc, the screen flickers with static (snow) and I have to restart the HTPC. OS is Windows 8 Pro and Proc is an i3 (can't remember which one). I've tried turning off AnyDVD before running the software, but the end result is the same. Nothing seems to work.
What's going on here? Is it salvageable?
Edit:
Unplugged the HTPC from my Monoprice 4x2 Matrix Splitter and plugged it straight into my Denon A7100. It works fine now. Not sure what was causing the previous problem as the Switch doesn't trip Macrovision for anything else.
Chalupacabra is offline
post #4463 of 4463 Old 11-11-2015, 03:11 AM
Quoted: 208 Post(s)
Liked: 47
When viewing a Blu Ray on a pc with TMT 6.7, TMT overrides the icc profile for the monitor. Is this an isolated issue with me or does any one else also experience this? Playing mkv does not do this, so I suppose it is some setting within TMT rather than windows.
Zhorik is offline
Reply Home Theater Computers
