Arcsoft TotalMedia Theatre - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #631 of 4463 Old 03-17-2008, 09:29 PM
Davinleeds's Avatar
Mine quarantined 5 days ago
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #632 of 4463 Old 03-17-2008, 09:42 PM
xanvil's Avatar
In my v.109 installation, the only files that are identified by Eset NOD32 Antivirus, which is supposed to be a pretty good antivirus program, are
C:\\Program Files\\ArcSoft\\TotalMedia Theater\\Plugins\\VideoModule\\PlayDVD\\UI\\Media_01.aui
C:\\Program Files\\ArcSoft\\TotalMedia Theater\\Plugins\\VideoModule\\PlayDVD\\UI\\Media_02.aui
Each is identified as a "Themida application" by Eset and they have been identified on the ArcSoft Forum as legitimate parts of the TMT installation. ArcSoft reports that hackers have used these file names for malware, but the TMT files are legitimate. These files will be quarantined by NOD32 and I don't believe TMT runs if these files are quarantined, although I could be mistaken about that.
michael
xanvil is offline
post #633 of 4463 Old 03-17-2008, 10:48 PM
drsmithdtv's Avatar
The file path for Trojan-Downloader.Win32.Bagle.la as identified by Zone Alarm was
C:\\Program Files\\ArcSoft\\TotalMedia Theatre\\uMCEDVDPlayer.exe
drsmithdtv is offline
post #634 of 4463 Old 03-18-2008, 04:08 PM
8:13's Avatar
Any other complaints from the list need to be removed?
First page.
There is new, and then you are new.
This is a moral of the bears and their cereal.
8:13 is offline
post #635 of 4463 Old 03-18-2008, 04:24 PM
Davinleeds's Avatar
8;13
Have you seen Jason's comment about the list?
http://www.arcsoft.com/forum/forum_posts.asp?TID=355
More info needed?
post #636 of 4463 Old 03-18-2008, 04:35 PM
8:13's Avatar
Davinleeds,
Maybe the people who made the complaint can try 109 and reply saying whether
or not the problem is fixed.
Too bad when they originally made the complaint they didn't list their system specifications.
8:13 is offline
post #637 of 4463 Old 03-18-2008, 04:59 PM
Andy o's Avatar
michael
That happened to me too, but only when advanced heuristics was enabled. It's most probably a false positive. I let them install (or TMT wouldn't work properly) and my PC is running fine, besides the obligatory disabling of the stupid startup entries and pointless services that these companies seem to think they have the right to trojan-horse into your computer. (And yes, I'm calling those trojans, as they are exactly how they work)
Andy o is offline
post #638 of 4463 Old 03-18-2008, 07:00 PM
UFGrayMatter's Avatar
I've been having some problems w/ a couple discs playing from ISO and Folder structure. I was able to get Spider-man 3 to play, but not 28 Weeks Later or Live Free or Die Hard.
Comparing the 3, the latter 2 had "BDSVM" folders - I removed them and now TMT plays the movies!
There is a warning that says the firmware isn't new enough? What is that about??
What am I missing by moving the BDSVM?
Ryan
UFGrayMatter is offline
post #639 of 4463 Old 03-20-2008, 05:07 PM
Davinleeds's Avatar
Arcsoft for the last week won't open in windowed mode. It'll open but I have to maximize it, other choice is minimize and that IS minimize. Usually it would open windowed and I could drag it to my second display. PDVD remains windowed and double clicking brings PDVD to full screen then, windowed, but double clicking ArcSoft minimizes it. Am I having a brain cramp with XP or is ArcSoft messing with me? ArcSoft is enabled for always on top, and it isn't.
post #640 of 4463 Old 03-20-2008, 06:18 PM
Ryan
Well - the new AnyDVD fixed this problem. I wonder why just copying the BDSVM folder worked though?!?
post #641 of 4463 Old 03-20-2008, 06:23 PM
Vern Dias's Avatar
It probably is opening windowed, it's just that the window has been moved off of the visible screen area.......
Vern
Vern Dias is offline
post #642 of 4463 Old 03-20-2008, 06:51 PM
Davinleeds's Avatar
Thanks, but looked into that, and no.
post #643 of 4463 Old 03-21-2008, 09:20 AM
FraserGJ's Avatar
I get this, my Arcsoft opens in windowed mode on my primary monitor and I drag it to my second monitor. If I double click to get it full screen then double click again to go back to windowed mode and it vanishes totally. Not exactly the same problem but seems similar
Works fine on my primary monitor but my secondary monitor top left corner is -1366x0 so I thought that might be confusing it...
You can get it back by right clicking on taskbar icon
FraserGJ is offline
post #644 of 4463 Old 03-21-2008, 10:53 AM
Davinleeds's Avatar
Right click only offers, minimize and full screen.
But I unclicked on top and 16x9. Click apply and reclicked always on top, worked upon reopening. But it won't the next startup. Usually a setting
post #645 of 4463 Old 03-21-2008, 12:50 PM
Cap.T's Avatar
I've got a question regarding DTS HD Master Sound. In PowerDVD the Audiobitrate is constantly changing from 0 up to somewhere in the 4000 range. In Arcsoft the bitrate is constant at 448 kbps. Why is that? Thanks!
Cap.T is offline
post #646 of 4463 Old 03-21-2008, 01:54 PM
Rathbone's Avatar
Quoted: 53 Post(s)
Liked: 25
I think lossless is downsampled to 448 kbps in TMT that's why I never use it for playback of lossless audio. WinDVD 9 downsamples to 1509 kbps. PDVD only shows the stream bitrate, not the output bitrate. I think Nero is the only player that doesn't downsample but I am not sure about it.
Rathbone is offline
post #647 of 4463 Old 03-21-2008, 03:26 PM
Cap.T's Avatar
Thank you. What about Dolby True HD and PCM-Sound? Are those downsampled as well? They both show constant bitrates at 4500 kbps. In PowerDVD there change all the time. Does that mean that TMT keeps the bitrate for those formats constantly at 4500?
I have another strange bug with TMT. When listining to a PCM 5.1 Bitstream my rear right channel is mute. All other channel seem to work fine. In Version 105 it was the channel swapping and in 109 this. This program doesn't work for me yet.
PowerDVD downsamples as well? I actually never noticed that...
Cap.T is offline
post #648 of 4463 Old 03-22-2008, 04:36 AM
Davinleeds's Avatar
http://www.arcsoft.com/forum/forum_posts.asp?TID=379
post #649 of 4463 Old 03-22-2008, 08:01 AM
Oppo Beta Group
RichB's Avatar
Quoted: 868 Post(s)
Liked: 565
I thought TMT downsampled only AACS protected source?
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is online now
post #650 of 4463 Old 03-22-2008, 08:46 AM
taz291819's Avatar
- Rich
That's what I've been told by a beta tester.
Also, the new update works great with Catalyst 8.3.
Currently testing 3D with Sammy DLP, shutter glasses, and HTPC
taz291819 is offline
post #651 of 4463 Old 03-23-2008, 05:47 AM
Vern Dias's Avatar
But it broke Catalyst 7.12!!!!! Nothing but a black screen after installing the update. Don't these guys test this stuff??????
Vern
post #652 of 4463 Old 03-23-2008, 07:07 AM
JDLIVE's Avatar
Quoted: 95 Post(s)
Liked: 51
Send a message via Yahoo to JDLIVE
I installed the new trial and am only getting 2 channel audio? Using analog outs from my Revo 7.1. Plays everything I've tried so far, do you need to buy it to get the full audio?
JDLIVE is offline
post #653 of 4463 Old 03-23-2008, 07:09 AM
Davinleeds's Avatar
In all settings in TMT audio?
post #654 of 4463 Old 03-23-2008, 08:11 AM
wxboy's Avatar
omg. tmt WORKS with ripped BD/HD discs. Everything except discs with the BDSMV folder, but remove that and the disc plays, just with no menu. Will have to try running them thru any DVDand see if that helps. This is on a 7900gs btw. Still a bit choppy, but have to experiment and tweak some settings still
wxboy is offline
post #655 of 4463 Old 03-23-2008, 09:15 AM
jimwhite's Avatar
just goes to show ya.... one man's delight is another's nightmare.... I'd like to see SA-like playback from the original disc before I'd even THINK about those huge rips....
Jim White
St. Petersburg, FL
jimwhite is offline
post #656 of 4463 Old 03-23-2008, 09:37 AM
Davinleeds's Avatar
30% off
http://www.arcsoft.com/support/downl...troversion.asp
post #657 of 4463 Old 03-23-2008, 09:51 AM
chillspace's Avatar
30% off
Went to try the coupon code but it doesn't work when I enter it in at the Element 5 checkout. Has anyone been able to get it to work?
Eric
My Stuff: Panasonic TC-P65ZT60 w/  Ideal-Lume Bias Lighting, Yamaha RX-V3800, Oppo BDP-103D
chillspace is offline
post #658 of 4463 Old 03-23-2008, 09:53 AM
wxboy's Avatar
SA-Like?
Btw, increasing priority of process cleared up chopiness... oh yea... and turning on HW accel... oops
wxboy is offline
post #659 of 4463 Old 03-23-2008, 09:58 AM
jimwhite's Avatar
SA-Like?
stand-alone-like
Jim White
St. Petersburg, FL
jimwhite is offline
post #660 of 4463 Old 03-23-2008, 11:09 AM
Davinleeds's Avatar
It has to be your first activation, and put in exactly ACTIVATION08. I used the 20% discount earlier. Other than that you'll have to ask Arcsoft support.
Reply Home Theater Computers
