HDMI 1.3a (question) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-30-2008, 05:05 AM - Thread Starter
kowal's Avatar
Is HDMI 1.3a backwards compatible .....with the original HDMI standard.
I can get a good deal on some 1.3a cables.....but i want to make sure i will be able to use them with my current equipment (directv box, PS3, HTPC).
I just want to be sure before i order them?
asrock aliveNF6G-vsta
amd phenom 9500
4gb corsair ram
radeon 4670
antec fusion case
asus bluray drive
windows 7
kowal is offline
post #2 of 8 Old 01-30-2008, 05:57 AM
THXUltra2's Avatar
The cables are the same. Actually you don't need 1.3a cables for the extra features in HDMI 1.3a.
THXUltra2 is offline
post #3 of 8 Old 01-30-2008, 09:52 AM
jimwhite's Avatar
Not!... One of the "features" of HDMI 1.3a was a DOUBLING of the available bandwidth... many pre-1.3a cables will not cut the mustard for future implementations...
For the OP, go for the 1.3a cables...
Jim White
St. Petersburg, FL
jimwhite is offline
post #4 of 8 Old 01-30-2008, 10:03 AM
mpgxsvcd's Avatar
Quoted: 2778 Post(s)
Liked: 2462
Please correct me if I am wrong but I didn't realize there were any 1.3a video sources currently available for you to test that theory? There are certainly 1.3a audio sources out there. However, 1.3a audio is losslessly compressed audio it is actually smaller than the LPCM audio that comes across a 1.2 cable.
At the moment and in the foreseeable future an HDMI 1.2 cable is can accomplish everything that an HDMI 1.3a cable can.
mpgxsvcd is offline
post #5 of 8 Old 01-30-2008, 10:05 AM
MrBostn's Avatar
This hdmi cable crack is crazy.
I just browsed the thread dedicated to hdmi issues, the
poor people are going crazy..handshake issues, audio issues, unplug this before that, then power up this before that. Aii Yaa
MrBostn is offline
post #6 of 8 Old 01-30-2008, 10:26 AM
jimwhite's Avatar
Please correct me if I am wrong but I didn’t realize there were any 1.3a video sources currently available for you to test that theory?
It's not a theory, it's the spec!
Not all, but MANY of these problems are caused by really low quality cables and DVI-HDMI converters... I had to throw away 3 converters that caused random handshake issues!
Jim White
St. Petersburg, FL
jimwhite is offline
post #7 of 8 Old 01-30-2008, 01:05 PM
ES_Revenge's Avatar
Quoted: 419 Post(s)
Liked: 138
Perhaps some very poorly made cables may have issues but if your "theory" (yes I'm calling it that too) was correct than why are Monoprice 1.3a cables essentially the same as their older non-1.3a cables only sold at slightly higher prices (while the older ones get discontinued)?
The wire sizes (gauge) and wire material inside the cable is the same, the connectors look the same... I mean what exactly happened to the cable to make it "double the available bandwidth"? Oh wait did they dip it in a special 1.3a solution before shipping it? LOL. Or maybe the end connectors have cooling units attached to cool the conductors in them into superconductivity? LMAO.
If the wires were made of something different or the gauge sizes were all larger, compared to the non-1.3 cables you'd have something there. But when they are otherwise exactly the same but just with 1.3a branding/certification? Again, I'd really like to know how one cable suddenly has the capacity for "double the bandwidth" with nothing really changed at all.
ES_Revenge is offline
post #8 of 8 Old 01-30-2008, 01:57 PM
archibael's Avatar
Well, I'll take issue with this. One thing that could have changed is their testing criteria. To meet the HDMI 1.2 spec, for instance, they might have tested the signal quality of the cable to meet 250GHz and now for 1.3a they have to reject those cables which don't meet 350GHz specs. Those numbers are completely made up, but you can see how a cable with signal quality that's fine at 300GHz would meet 1.2 specs but not 1.3a, and therefore get labelled differently. Even without making any changes to the cable-making process, you could have devices which (through normal process variation) can't make the new specs.
That said, who effing cares? Nothing supports RealColor or TrueColor or DeepColor or whatever they're calling it nowadays. That's the only bandwidth limited item in the new spec. I'd agree with your suggestion to go with an HDMI 1.2 cable until you see something which does.
I do not speak officially in any sense for
Intel Corp., Technology Manufacturing Group
but I do work there.
archibael is offline
Reply Home Theater Computers
