GeForce 8200 - 8 Channel LPCM Output Fully Supported!! - Page 60 - AVS Forum | Home Theater Discussions And Reviews
post #1771 of 2308 Old 07-17-2008, 10:14 AM
DraZtiK's Avatar
Originally Posted by dedwards View Post
Also, which of these boards is confirmed to work with a Denon AVR?
I'm planning to do an HTPC upgrade, and would like to get Blu-ray playback as well. No need for ripping, just playback from the BD media. I have a Denon AVR and a 5.1 setup.
search the thread, multiple people already stated they have it working with Denon AVRs.
DraZtiK is offline
post #1772 of 2308 Old 07-17-2008, 12:00 PM
jimbokka's Avatar
The Abit A-N78HD works with my Denon AVR-3806 without problems.
jimbokka is offline
post #1773 of 2308 Old 07-17-2008, 02:31 PM
craig aguiar's Avatar
Thanks for the reply, that's good to know. What are you using for software? OS? Does this MoBo have the PAP? Actually do even need that to get LPCM? I'm still learning here.
Now that I know this MoBo will work with my receiver, can anyone tell me weather or not upgrading to this MoBo will give me uncompressed LPCM over the HDMI?
Craig
craig aguiar is offline
post #1774 of 2308 Old 07-17-2008, 02:36 PM
I just realized this is an AMD board. Does anyone know the Intel equivilant?
Thanks, Craig
post #1775 of 2308 Old 07-17-2008, 02:54 PM
DraZtiK's Avatar
For future reference,
I purchased a Biostar MB TF8200 and could not get audio out over HDMI for nothing. it just kept saying not connected, I pulled the board out and RMAed it. new one came today and reinstalled it, NOTHING was changed... drivers, BIOS, OS, settings, etc. Fired it up and audio over HDMI works great.
So, if your having problems getting audio out over HDMI, It could be a faulty motherboard.
DraZtiK is offline
post #1776 of 2308 Old 07-17-2008, 05:48 PM
Oppo Beta Group
RichB's Avatar
Quoted: 1273 Post(s)
Liked: 873
I just got an ASUS M3N78.
It need a bios update to recognize the Phenom 9550.
All seems well. Blu-ray and HD DVD playing ok.
I have not had a chance to play with the audio.
One big problem is the gigabit network is slooooow.
It acts more like 100mb. I have tried to play with the parameters with little success. I have looked for drivers and updated all of them from the ASUS site.
Does anyone have any recommendations?
Rich
Oppo UPD-205 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 | ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG 65C7 | Lumagen 2020
RichB is online now
post #1777 of 2308 Old 07-17-2008, 05:55 PM
odditory's Avatar
Rich
Are you running Vista? Make sure you've updated to SP1 since there were ethernet throughput issues with Vista prior to SP1, depending on the O/S of the other computer (i.e. media server) you were copying files to or from. Without going into the long technical explanation, if SP1 doesn't fix it then there's other issues. Anyway it was driving me nuts too.
odditory is offline
post #1778 of 2308 Old 07-18-2008, 02:37 AM
wilsonj's Avatar
Just like to say the 177.66 drivers dont work for me! Powerdvd8 starts up and gives me a black screen. Then locks up. I guess they are beta, unlike the 175.xx drivers!
wilsonj is offline
post #1779 of 2308 Old 07-18-2008, 03:09 AM
l3ok's Avatar
Hi
I am in the process of upgrading my HT system to support BR. I have ordered a Sony DG820 and now need to upgrade my PC to be able to take advantage of this.
Current system.
Intel 3ghz dual core
1G Ram
To be able to get full HD audio I will get the ASUS Xonar HDAV1.3.
Do I need to get a new processor and board to be able to output the video or can I upgrade RAM and GPU?
If I need to do a full upgrade I am thinking of getting:
Phenom 9550
XFX 8300
2G DDR2 1066
What do you guys suggest...
l3ok is offline
post #1780 of 2308 Old 07-18-2008, 03:50 AM - Thread Starter
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Current system.
1G Ram
You need to upgrade only the video card (e.g. GeForce 8400 GS [G98]/8500 GT/8600 GT/9500 GT, Radeon HD 3450/3470/3650, as low as $25). If you use Windows XP (Xonar HDAV1.3 supports XP), 1GB RAM is enough.
ASUS Xonar HDAV1.3 is a kind of bloated (full featured analog components that most users don't need). Auzentech X-Fi HomeTheater 7.1 is much slimmer (more focused on HDMI). See my post.
renethx is offline
post #1781 of 2308 Old 07-18-2008, 04:14 AM - Thread Starter
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
DigiTimes - Nvidia to launch Intel-based MCP7A IGP chipset in August (July 18, 2008)
Nvidia is planning to start mass producing its latest Intel platform IGP chipset, the GeForce 9-Series mGPU – nForce 730i MCP (MCP7A), in the middle of August with motherboards likely to appear in the market by early September, according to sources at motherboard makers.
The MCP7A will come in two versions, the MCP7A-U with a GeForce 9400 graphics core and the MCP7A-S with GeForce 9300 graphics. The two versions have the same specifications except the GeForce 9400 features a core frequency of 580MHz and shader frequency of 1500MHz, while the GeForce 9300 will be clocked at 450MHz and 1200MHz.
The MCP7A support a FSB up to 1333MHz, dual-channel DDR2 or DDR3 memory, and PCI Express 2.0. The GPU is based on Nvidia's G86 graphics core, which supports DirectX 10 and Shader Model 4.0, includes 16 built-in stream processors, and supports HDMI, dual-link DVI, DisplayPort and D-sub connections.
The MCP7A will also support Hybrid SLI, PureVideo and Cuda technologies.
FYI, Core/Shader
- GeForce 8200: 500/1200
- GeForce 8300: 500/1500
renethx is offline
post #1782 of 2308 Old 07-18-2008, 05:09 AM
Oppo Beta Group
RichB's Avatar
Liked: 873
I running a new install of Vista Ultimate 32 SP1.
I think I got it working better by going into the device manager deleting and uninstalling the Network driver.
Of course, the smart move would have been to download the latest chipset driver first, but after a while I was able to burn a CD with the drivers
After the re-install, it seems to be working much better.
- Rich
RichB is online now
post #1783 of 2308 Old 07-18-2008, 05:15 AM
madshi's Avatar
Quoted: 613 Post(s)
Liked: 594
madshi is offline
post #1784 of 2308 Old 07-18-2008, 06:16 AM
Speqtre's Avatar
Originally Posted by madshi View Post
About time!
Based on recent performance, don't hold your breath!
Speqtre is offline
post #1785 of 2308 Old 07-23-2008, 02:51 AM
tal.aloni's Avatar
Hey Guys, Does The "NVIDIA HDMI Audio Device" have equalizer software included?
(like the realtek for example)
[I have an Abit A-N78HD on order, and I need a global windows equalizer, as my TX-SR576 equalizer doesn't offer the flexibility that I need. I would gladly take recommendations as well]
Tal Aloni
Edit:
1. Equalizer software is not included.
2. All of the programs I'm working with (Including Winamp, AC3Filter, ffdshow) can be adjusted to work with ISO standard bands, so I can easily copy configurations from one to another.
tal.aloni is offline
post #1786 of 2308 Old 07-24-2008, 02:01 PM
mkbnh's Avatar
Hi Folks, I need some help to solve a minor bug...but preventing my "perfect" HTPC.
Let me start out by saying I have no issues with playback -- DVD or Blu Ray -- of any kind, neither do I have any audio issues over HDMI (I get great sound to my Onkyo...DD, DTS, and 7.1 / 5.1 LPCM).
My issue is a different one...
I have 2 different 8200 MB's (Asus and ECS). I also have the Asus 8300 MB (M3N78 Pro). And I've been playing around...
The 8300 gives me 100% smooth playback on Vista Media Center (Ultimate SP1 32 bit) when watching ripped DVD's. It also gives me stunning, 100% smooth playback on Blu Ray played using Power DVD 8 Ultra. I have Aero disabled so I don't get the annoying message when I play Blu Ray.
The problem I need help overcoming is screen tearing when I enter Vista Media Center (when I press the green button). Upon launch the screen tears and flickers fairly badly...most notable when I move around the interface but also flickers when it just sits there. My family is abusing me for this little annoyance and I just don't know how to fix it.
I am connected via HDMI to my Onkyo receiver and get fantastic sound...so no issues there.
The 8200 boards where very bad but had the problem as I'm having with the 8300.
I am using a 4850e, 4 GB GSkill DDR1000 memory, and monster cables. I have it connected to Samsung 46" 1080p LCD through my Onkyo.
I do not have this problem on the Gigabyte board with the ATI on board video but lack of 7.1. LPCM prevents me from using it in my HTPC...but at least I know it's not CPU or RAM or TV or Onkyo.
NOW --
I've put in an MSI 8500GT card and used a DVI > HDMI cable and the tearing goes away so I don't think it's a driver issue...I've also stuck in an 8600GT and again picture perfect.
I then stuck in an ATI 2600XT and also tried an HD3450...both using HDMI for audio/video and once again, picture perfect! And sound from HDMI (albeit only DD or DTS no 7.1 LPCM).
Therefore, I've eliminated everything out of the equation other than onboard 8200 or 8300, so I really need your help...how can I get rid of my screen tearing in Vista Media Center interface?
BTW, I've tried OC'ing...steady, but still tearing (no better or worse). I've tried turning off CnQ...no problem, same tearing (no better or worse). I've set all onboard processor-related settings to auto...same problem (no better or worse). I've set them all manually to correct settings (and even higher/lower just to test), and same problem (no better or worse). I've also tried with 3 different Vista installations...same problem.
So in summary, on my 8300 board (even though I had the same issue on my 8200 board) the only problem I'm left with and need you help fixing is the darn screen tearing in the VMC interface...everything else is 100% good.
I'm losing hair...so I need your help
/mkbnh
EDITED: I've tried 174.xx drivers through the current ones and all BIOS options...same tearing/flickering in VMC.
mkbnh is offline
post #1787 of 2308 Old 07-24-2008, 02:45 PM
Davinleeds's Avatar
Phenom? Any particular movies that tear? I've found tearing to be a driver issue and with Nvidia and PDVD the settting for performance or let the application decide. With TMT, my only problem with an 8200 MSI is FF4/SS, but I haven't tried that in awhile. Last disk is 10000BC no probs but it's not intensive. Basically, sounds like a PDVD/VMC clash.
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #1788 of 2308 Old 07-25-2008, 10:02 PM
CFC
CFC's Avatar
Quoted: 27 Post(s)
I'd previously mentioned my problems using the Biostar TF8200 A2+ and my PCI based tuner cards skipping and stuttering here.
After an upgrade to driver version 177.70 found here, all my problems have gone away. My PCI tuners work flawlessly, to go along with my PCI-e tuner now.
I'm in HTPC bliss ... until I get around to "tweaking" again
I don't yet have a Blu-Ray drive, so I can't comment on its performance, but I get absolutely silky smooth accelerated playback on properly encoded 720p and 1080p h264 and VC1 files. I typically get CPU usage below 10% (using cyberlink codec), and thanks to the video level fix, I no longer have to deal with black crush issues.
Can't test HDMI either, but that'll be coming soon enough, along with a BD drive.
Thanks Nvidia... took you guys long enough
Board: Biostar TF8200 A2+
CPU: Athlon X2 4850e
Memory: Gskill - 2 GB (1066 running at 800)
OS: Vista 32-bit
Hope everyone is having good luck with their rig.
CFC
Signature goes here
CFC is offline
post #1789 of 2308 Old 07-28-2008, 04:07 AM
lakaw's Avatar
BIOS version 12 is out for the abit A-N78HD. It fixed my S3 problems.
lakaw is offline
post #1790 of 2308 Old 07-28-2008, 10:55 AM
tys90's Avatar
I'm going to try that out later tonight. I also had problems with S3...as in it didn't work at all. I also have a problem with S1 and vista only outputting 2 channel audio after it comes out of sleep, not sure if it's a driver problem or a problem with my Onkyo receiver. As a result I haven't been able to use any sort of power management.
EDIT: I don't see it on their website? Nevermind, found it, their USA site is trash.
tys90 is offline
post #1791 of 2308 Old 07-28-2008, 11:01 AM
stoked's Avatar
I noticed Giga-byte posted an updated Realtek HD Audio driver R1.97 on their site. I also noticed Asus' version is 5.10.0.5532 from January. I checked Realtek's website and a R1.99 driver is posted there and according to the Readme.txt is file version 5.10.0.5667. Anyone running the Realtek website audio drivers? The readme.txt states that there was a DRM fix between the Asus website driver and the current Realtek website driver.
UPDATE: Tried the R1.99 driver and my Nvidia HDMI Audio device and Realktek HD Audio device disappeared. Uninstalled and installed the R1.97 driver from the Gigabyte site. Realtek HD audio device came back but no Nvidia HDMI Audio, had to reinstall Nvidia display drivers to get that back.
The R1.99 drivers are half the size of the R1.97 drivers, maybe it was missing the MS UAA stuff? Not sure.
stoked is offline
post #1792 of 2308 Old 07-28-2008, 01:27 PM
RedTee's Avatar
FYI, Core/Shader
Renethx, do you feel this Intel based board will work the same or better than the the 8200 for a future HTPC?
If the same, are all the 8200 boards capable of 8 Channel LPCM through 1 HDMI cable?
You have had success with ABit, and someone else with an Asus. Would a Gigabyte brand work?
http://www.avsforum.com/avs-vb/showt...2#post13931082
One last question, will this setup work in XP?
Thanks for everyone's advice so far.
RedTee is offline
post #1793 of 2308 Old 07-28-2008, 02:28 PM - Thread Starter
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
9300/9400 should be better than 8200/8300.
Yes, every 8200 mb is capable of that unless the mb manufacturer did something wrong.
I don't know the GIGABYTE board.
renethx is offline
post #1794 of 2308 Old 07-28-2008, 02:32 PM - Thread Starter
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Tomorrow the brand new ASUS M3N78-EM (GeForce 8300) will arrive at my home. I will report how it works.
renethx is offline
post #1795 of 2308 Old 07-29-2008, 01:17 AM
bokis's Avatar
After the Hdmi soundproblems with Ati/Amd and recievers I hope this Mb will turne out allright, looking forward to your review
bokis is offline
post #1796 of 2308 Old 07-29-2008, 08:58 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
Craig
It does, and it will output up to 24/192khz 8 channel.
But.... you have no idea what cyberlink and TMT are dumping into the windows mixer, and no diagnostic way to check or test.
What we've been lead to believe is that bluray playback apps are dumping 16/48khz 8 channel into the windows mixer, wich for alot of movies is full resolution, so depending on the information on the disc you may actually be getting lossless.
A final note is there is not currently a PaP solution available. We don't know how the TMT or PDVD PaP implementation will work. It could be that solution will be very much software based so it may be that more than just the xonar and azuntech card end up doing PAP, but as of this instant those are the only two confirmed products.
sotti is offline
post #1797 of 2308 Old 07-30-2008, 03:18 PM
Davinleeds's Avatar
Installed a 5200 on MSI 8200 and O/C to 2.889 and my problem disk FF4/SS no longer stutters. DTS HD MSTR audio with 1650x1050 display. For dual core close to 3.0 seems grail. Decided 5200 as it's $77 w/shipping @Egg and Phenom $125+shipping@Egg. I think HotHardware had difficulty O/C'ng the Phenom. All with TMT. Happy now.
post #1798 of 2308 Old 07-30-2008, 04:20 PM
redtyler1's Avatar
So, I'm using an Onkyo 606 and have an Asus 780G. I'm looking to getting 8ch LPCM over HDMI and wasn't sure what brand I should get. Is there a consensus since these boards have been out as to which one has performed the best given BIOS and driver updates?
Thanks ya'll.
Alex
redtyler1 is offline
post #1799 of 2308 Old 07-30-2008, 08:34 PM
tys90's Avatar
I'm happy with the Abit A-N78HD board. No problems for me.
tys90 is offline
post #1800 of 2308 Old 07-30-2008, 09:37 PM
carrera1's Avatar
Thanks ya'll.
Alex
I have built two Abit A-N78HD based systems and both have smooth 1080P playback and great sound... Make sure you get a Phenom. Seems that most of issues come from people using underpowered CPUs.
carrera1 is offline
Reply Home Theater Computers
