GeForce 8200 - 8 Channel LPCM Output Fully Supported!! - Page 73 - AVS Forum | Home Theater Discussions And Reviews
Old 12-27-2008, 02:05 PM
Mikl1984's Avatar
Originally Posted by clamrade View Post
If I may trouble you a bit more... how hot does your northbridge get? Does Speedfan work (read temperatures & control fans) on your M3N78-EM?
Speedfan work well in comparison crazy 780G temperature
During BD play no more than 55C in my Chieftec case http://www.chieftec.eu/index.php?opt...18&Itemid=584#
Mikl1984 is offline
Old 12-27-2008, 03:52 PM
clamrade's Avatar
Excellent! I think I found my board at long last. I was torn between M3N78-EM and GA-MA78GPM-DS2H. Does the lack of DTS connect or Dolby Home Theater bother you at all? Any other peeves that you could share?
Thank you for your help. I tend to maintain a platform close to a decade, so choosing the right system is a big deal for me. In fact, I'm typing on a Win2k system put together in 2001, and it's time for me to upgrade.
clamrade is offline
Old 12-28-2008, 08:21 AM
Mikl1984's Avatar
Honestly it doesn't matter for me.
ATI works better with multi-monitor.
Idiots from Nvidia blocked most popular resolution 1280x1024 32bit in such mode with my Full HD TV. Only 16 bit.
Less possible resolutions for this TV in second monitor configuration. It doesn't correspond fully with EDID list.
ATI has less CPU usage than Nvidia in BD Play. Better to use more powerful CPU than my 4850e
But Nvidia rules due to better support 24p. And of course 7.1 LPCM.
Mikl1984 is offline
Old 12-28-2008, 11:22 AM
clamrade's Avatar
Thanks again for your generous help. I'm gonna have to get one and try it out.
Do you use ac3filter? Does it work well on this board? I am currently limited to SPDIF, so real-time encoding to DD is important when I encounter a source w/o a DD or DTS audio track.
Do you know if it'll do 1680x1050 (VGA) and 1280x720 (HDMI projector) simultaneously? Couldn't you define a custom resolution even if it won't read EDID properly?
clamrade is offline
Old 01-01-2009, 03:50 PM
Vindii's Avatar
Ok I searched around quite a bit for this.
Just got done installing ASUS 8300 on XP. Everything works great but it seems to only be outputting 2 channel audio from the HDMI port. I tried all different kind of settings and updated the HDMI driver to .23.
If I set the speaker settings to 7.1 or 7.1 wide or 5.1 I get sound but the voices in the center channel are very light. It looks like it is unconverted to PL2 by the reciever.
If I set the speaker settings to surround sound I get 2 channel sound that my receiver (denon 3806) up converts to PL2. Voices do sound better this way.
No matter what I do I can't get it to send PMC to the reciever. I am using madflac audio decoder with .MKV files that I ripped to .flac audio.
This seems like it should be something simple but I don't know what to do from here.
Can anyone help?
Vindii is offline
Old 01-02-2009, 11:45 AM
Vindii's Avatar
Can anyone help?
No advice for this?
Vindii is offline
Old 01-06-2009, 03:08 PM
shoulderlean's Avatar
Guys, i have an asus M3n78-vm and using vga out to my sony tv. Powerstrip has given nothing but troubles and i cannot get a 1:1 pixel mapping.
Is there another program i can use that will allow me to adjust the res so that i can acheive 1:1 pixel mapping??
I went to the nvidia website and chose the option to update my driver, when the website detected my 8200 it let me download a version (cant remember right now)
Once i installed it and reboot my computer, windows xp pro wouldnt load up and i get a blue screen, then the comp restarts itself and i have to revert to last known good config...
any ideas?
shoulderlean is offline
Old 01-11-2009, 04:01 PM
stoked's Avatar
For those of you using XP and were not able to correct the over/underscan, the latest 181.20 drivers FINALLY now work. I can use the resizer tool to fit my desktop. It also seems to have separate vertical and horizontal adjustment.
http://www.nvidia.com/object/winxp_181.20_whql.html
stoked is offline
Old 01-14-2009, 08:26 AM
mkbnh's Avatar
OK, so has anyone tried this setup? Will HDMI audio still work over the HDMI cable? I've tried with a 8500GT but had terrible screen tearing (never really got Hybrid SLI to work)...don't mind spending some sweat equity/fiddling around with hardware trying to get better quality video, but I MUST still get LPCM over HDMI (I use Onkyo 606 hooked up to a Samsung LN-S4695D).
BTW, I bought and installed a Powercolor 4830 into my HTPC...just to compare/contrast with my M3N78 Pro GeForce 8300...here's my basic feedback:
- The card is cheap, quiet and fast! (I paid $80 shipped from the egg...after rebate)
- The sound quality blows away the 8300 - you have options for 5.1 (what I have) and 7.1...ZERO issues in installing drivers. I simply could not believe how much better the sound was...and literally ZERO issues. I use Multichannel and to get comparable to 8300 sound stage and volume, I turned my sound down from 52 to 30 ... and even at 30 the ATI 4830 had much better sound stage for both music and movies.
- Now the bad...the video quality of the 4830 stinks! in comparison to the 8300...it makes zero sense why it would, but it does. I suspect I know why...the Nvidia scaling is perfect when I set my TV to "Just Scan"...crisp, clear! The ATI card boots up with underscaning, when I set under/over scan to zero, and my TV to just scan, the picture is just simply not as sharp...with identical TV settings the SD content just plain stinks (e.g. playing DVD's); the Blu Ray content is about as good as 8300's SD content.
I am not bias toward one solution or another...I'm only married to best video/audio quality ... so I'm going back to Nvidia ... and want to see if I can pop in a 9800 GTX+ (I have one...my son's PC...he's looking for an upgrade)...and get better quality video but still retain 7.1 LPCM audio over HDMI.
/mkbnh.
mkbnh is offline
Old 01-14-2009, 09:00 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Yes, HDMI audio from the onboard HDMI works perfectly in either mode, "Save Power" (9800 GPU is completely shutdown) and "Boost Performance" (only 9800 GPU is used [8300 HD audio controller still works]).
renethx is offline
Old 01-14-2009, 05:31 PM
Kyrt's Avatar
I'm looking at getting a M3N78-EM but am concerned by talk of high power consumption. I'm happy if it matches 780G levels but renethx's comparison showing 20W higher seems a lot. I notice on the Asus website the 0418 BIOS release (24th October 2008) apparently "enables C1E". Now I was under the impression this was a power saving feature, so I wonder if this could explain the big difference?
http://support.asus.com/download/dow...Language=en-us
I'm also looking for a little piece of mind that the 8300 will be OK paired with a 5050e (2.6GHz X2). Max use case is watching HD material (not BD, but potentially VC-1 or H.264 upto 1080p or deinterlacing 1080i) in VMC whilst running an extender. CnQ would be on. Commercial detection at the same time would be a bonus but I don't hold out much hope.
If I'd have known ATI hated my TV I'd have gone for Intel/9300 or a more powerful CPU but that's life - gotta go with an nvidia solution and really want to avoid a discrete GPU.
Kyrt is offline
Old 01-14-2009, 05:36 PM
Kyrt's Avatar
By the way just FYI Asus posted a new BIOS on 12th Jan:
"0503 BIOS for M3N78-EM
Fix system may hang when shutdown system during programming the HDCP. "
Kyrt is offline
Old 01-17-2009, 10:15 PM
aibo99's Avatar
Has anyone tried to use KMPlayer or MPC-HC to output LPCM 7.1 over HDMI ??
aibo99 is offline
Old 01-17-2009, 10:34 PM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
You can always get 7.1 LPCM over HDMI with MPC-HC and an audio codec appropriate for the source.
renethx is offline
Old 01-17-2009, 11:39 PM
aibo99's Avatar
Which audio decoder do you use to decode TrueHD and DTS-HD MA into LPCM ?
aibo99 is offline
Old 01-18-2009, 12:06 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
TrueHD: ffdshow Audio Decoder
DTS-HD MA: ?, at least you can get DTS core.
renethx is offline
Old 01-18-2009, 12:47 AM
aibo99's Avatar
Hi, renethx,
Q1. Which model of Athlon did you use before you changed to Phenom ?
Q2. Can Cyberlink audio decoder decode DTS-HD MA completely ?
aibo99 is offline
Old 01-18-2009, 12:55 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Hi, renethx,
I think 4200+ and 4850e.
Yes (but only within PowerDVD, I think).
renethx is offline
Old 01-18-2009, 01:07 AM
aibo99's Avatar
For the 4200+ and 4850e, if you turned on the PureVideo HA, did they smoothly decode the 1080p video (H.264 or VC-1) ???
I am thinking to use Sempron 2100+ in the GeForce 8200 mobo for 1080p decoding. What do you think ?
aibo99 is offline
Old 01-18-2009, 01:16 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Yes. (But I don't recommend them for interlaced contents.)
Sempron X2 2100 is OK, but if you are going to buy a new processor, you'd better choose a better one.
renethx is offline
Old 01-18-2009, 01:22 AM
aibo99's Avatar
May I know why you changed to Phenom ??
(4850e can give you smooth 1080p playback)
Sempron 2100+ is really cheap and cost effective, since my new PC is just for HD video playback, I don't want to buy expensive parts for it. Also my video contents are all 720p and 1080p, de-interlacing is not my concern
aibo99 is offline
Old 01-18-2009, 01:38 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
I am just recommending an AM2+ processor (Phenom or Athlon x2 7750) to those who want better post-processing. If you don't need it, you can choose an AM2 processor.
renethx is offline
Old 01-18-2009, 05:20 AM
aibo99's Avatar
Got it.
Then I will buy a Sempron 2100+ & GeForce 8200 mobo for my new HTPC.
How about Athlon X2 3250e ??
renethx, thanks a lot for your advice.
aibo99 is offline
Old 01-18-2009, 06:08 AM - Thread Starter
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Got it.
This 22W 1.5GHz processor may be good for a mini-ITX system. BTW where do you find Sempron X2 2100 1.8GHz cheap? ebay? The lowest price I found is $57, the much better Athlon X2 4850e 2.5GHz is only $56.
renethx is offline
Old 01-18-2009, 07:09 AM
aibo99's Avatar
I am in Hong Kong, and the Sempron 2100+ is only selling around US$ 30. Amazing
If you want one, perhaps I could help.
aibo99 is offline
Old 01-18-2009, 07:28 PM
aibo99's Avatar
Is anyone using the Biostar TF8200 A2+ ??
I am going to buy it, appreciate it if you could give me some comments about this mobo.
aibo99 is offline
Old 01-18-2009, 09:35 PM
CFC
CFC's Avatar
I use it... It works great.
If you do get it, be sure to set the jumpers for USB power during stand-by so that you can use a remote to return it from sleep.
No complaints on the board.
CFC
Signature goes here
CFC is offline
Old 01-18-2009, 09:41 PM
aibo99's Avatar
CFC
Which jumpers ? Would you please provide more details ?
aibo99 is offline
Old 01-19-2009, 07:57 AM
CFC
CFC's Avatar
Jumpers JUSBV1 & JUSBV2
You can get the board manual here: http://www.biostar.com.tw/app/en-us/...t.php?S_ID=353
CFC
Signature goes here
CFC is offline
Old 01-19-2009, 10:21 AM
aibo99's Avatar
My final choices are:
1) Asus M3N78-VM
2) Gigabyte GA-M78SM-S2H
Is there any defects with these two boards ??
Are the users happy with them ??
aibo99 is offline
