The Official Gigabyte GA-MA78GM-S2H RS780 mATX Thread - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 4430 Old 02-22-2008, 10:55 AM
magnoman's Avatar
Originally Posted by zenoicus View Post
I notice 8.45rc2 is still on the Gigabyte website, but no rc4. I'm trying to find 8.47rc1, which apparently is the first version to support Hybrid Crossfire (I've got a 3470 sitting here). I wish AMD was congenial like nVidia in making beta drivers available. But then, the lack of mature driver support is AMD's stated reason for delaying the RS780 launch everywhere except in China (meaning they're using the Chinese as beta testers...or just figuring user demands there aren't as great?).
Here is a source of recent ATI drivers from Chinese motherboard manufacturer Onda so use at your own risk...
ftp://ftp.onda.cn/download/driver/mb/ati/
Notable files include:
02/01/2008 02:13PM 253,798,356 onda_ati_8.452_rc2_xp.exe
01/17/2008 11:20PM 111,488,519 onda_ati_8.45_rc4_vista.exe
01/18/2008 12:00AM 145,194,942 onda_ati_8.45_rc4_xp.exe
02/21/2008 06:44PM 111,137,287 onda_ati_8.47_rc1_vista.exe
magnoman is offline
post #122 of 4430 Old 02-22-2008, 10:59 AM
fphredd's Avatar
The Enzotech won't have height issues inside many of the HTPC cases...might contact them or the vendor to see if they have any ideas on the ability to mount it to the new boards.
"When the going gets weird, the weird turn pro." - HS Thompson
fphredd is offline
post #123 of 4430 Old 02-22-2008, 11:00 AM
zenoicus's Avatar
Outstanding! Thanks, magnoman!
zenoicus is offline
post #124 of 4430 Old 02-22-2008, 11:21 AM
youneeq's Avatar
Yes, awesome. D/l'ing now. It's slow of course. I'll try and put it up on a faster host later today.
Got my board from ClubIT. Sadly I have to wait till tues for eveything else to come in. Ordered the 5000+ BE with Corsair XMS2 2GB DDR 800 combo at newegg plus $40 MIR and got the OCZ Vendetta hsf. And I couldn't pass up the $0.99 500W PSU.
youneeq is offline
post #125 of 4430 Old 02-22-2008, 12:16 PM
youneeq's Avatar
Mirrored for faster d/l here.
youneeq is offline
post #126 of 4430 Old 02-22-2008, 01:46 PM
binetree's Avatar
I ordered the same 5000+ BE with Corsair XMS2 2GB DDR 800 combo from Newegg, as well as this case:
APEVIA X-QPACK-NW-BK/420 Black Aluminum 1.0 w/ ABS plastic front panel MicroATX Desktop Computer Case 420W Power Supply
I also need a hsf but I am not familiar with that, could anybody recommend a small one that will fit the case?
By the way, my board has been shipped from ClubIT today
binetree is offline
post #127 of 4430 Old 02-22-2008, 02:18 PM
youneeq's Avatar
Yeah, the 5000+BE/Corsair combo seems to be pretty popular.
I think the popular small HTPC hsf is the Scythe Ninja Mini. It's not too expensive either. I got the OCZ Vendetta bcz of price, efficiency, PWM, and it just needed to be under 6" in height. Good luck.
youneeq is offline
post #128 of 4430 Old 02-22-2008, 02:23 PM
zenoicus's Avatar
I would have recommended the Scythe Ninja Mini. I've got one in an Antec Fusion case, and it fits with about an 1/8" to spare. But that Apevia will take a heatsink no taller than 76mm (see Addendum on last page), so you're going to have to filter your prospects on the basis of that spec, and then let reviews and price steer you toward a decision. You'll also have to consider lateral clearance of the motherboard itself. But this Gigabyte board is pretty forgiving in that respect (as long as you don't intend to stick high-profile DIMMS like OCZ Reaper, Patriot Viper, or Corsair Dominator in the first memory slots).
zenoicus is offline
post #129 of 4430 Old 02-22-2008, 03:02 PM
binetree's Avatar
I was looking at the Ninja Mini and I did notice that it exceeds the height limit... should I consider another case? According to the reviews the APEVIA X-QPACK is not bad (at $60), is a Antec Fusion or similar worth 140 extra bucks?
binetree is offline
post #130 of 4430 Old 02-22-2008, 03:10 PM
Java Jack's Avatar
I still think the best cooler I have ever seen for this space is the Silentflux Media cooler...
http://www.noiselimit.com/index2.asp?id=15
Boasts a superior noise/performance ratio of 24 dB(A) at 100W. Under most working conditions, for example, movie recording and DVD viewing, this noise level is only a few dB(A) above ambient noise and therefore perceived as noiseless
Has no movable parts, giving excellent reliability
Weighs only 300 grams (including the fan), which means reduced shipping costs and less risk of damage under handling and transportation
Is only 6 cm high - including the fan
Only uses environmentally correct materials
Is RoHS compliant
Cools surrounding components
For a list of relative noise levels...
http://www.maglevpa.com/eis/april03pub/noise_2.pdf
Directron carries their ATX version...
http://www.directron.com/noiselimitamd.html
I am pretty sure they carry the media version as well, but I don't see it listed.
Regards.
Java
There are 10 types of people in the world, those that understand binary, and those that don't.
AMD@Home Blog: http://links.amd.com/Home
Twitter: http://twitter.com/Java_Jack
Java Jack is offline
post #131 of 4430 Old 02-22-2008, 05:11 PM
Ronin_R6's Avatar
Check zipzoomfly.com for a better price on the antec fusion. It is a very nice case, and it has 2 120mm side fans for quiet and cool operation.
Still trying to decide between this and the geForce 8200 boards. Hopefully CeBit will paint a clearer picture. I am leaning toward the nvidia though because of the multichannel PCM over HDMI.
Ronin_R6 is offline
post #132 of 4430 Old 02-22-2008, 05:28 PM - Thread Starter
ChrisMorley's Avatar
Anyone having any heat issues @ 1080p Blu-ray using HDMI?
ChrisMorley is offline
post #133 of 4430 Old 02-22-2008, 06:52 PM
binetree's Avatar
Direction does not seem to carry the media version, can't find it elsewhere either.
binetree is offline
post #134 of 4430 Old 02-22-2008, 09:35 PM
elee532's Avatar
Quoted: 92 Post(s)
Pardon my ignorance. Can someone claify whether this is supposed to be an upgraded board over the Gigabyte GA-MA69GM-S2H?
elee532 is offline
post #135 of 4430 Old 02-22-2008, 09:56 PM - Thread Starter
Massively so.
post #136 of 4430 Old 02-22-2008, 10:29 PM
zenoicus's Avatar
binetree, you might also check out the Fusion's lesser sibling, the NSK2480. It's the same size as the Fusion, but lacks: 1) a flourescent display with built-in IR sensor (in its place is a second optical drive bay). 2) hinged optical drive doors (if you get a silver NSK2480, you might want harder-to-find silver-bezeled drives, since those drives will never be hidden), 3) a solid brushed aluminum front face plate (the NSK2480's front is painted plastic), 4) a 430w psu (the NSK2480 has a 380w), 5) a volume knob.
Those are the major differences I'm aware of, there could be a few others. Some people even prefer the NSK2480 over the Fusion, due to a few known problems with the Fusion's flourescent display and IR sensor.
I got my Fusion case for $132 shipped from Buy.com (after a $30 rebate). Sometimes places like ZipZoomFly and Frys have the NSK2480 for as low as $50 after rebate.
______
OPEN QUESTION: I haven't done much posting here at AVS, but vaguely recall seeing somewhere that "price talk" is frowned upon. True?
zenoicus is offline
post #137 of 4430 Old 02-23-2008, 02:49 AM
gumble's Avatar
Massively so.
sorry, who has upgraded which Board?
@ audio via HDMI: the MA78GM-S2H is supposed to support HDMI 1.3b:
h t t p ://62.109.81.232/cgi-bin/sbb/sbb.cgi?&forum=2&show=2516&a=show&start=105#108
edit:. I'm not allowed to post URLs until 3 posts? should i spam to reach them?!
gumble is offline
post #138 of 4430 Old 02-23-2008, 04:48 AM
gazebo's Avatar
Quoted: 14 Post(s)
Question: The NB heatsink on the GA-MA69GM-S2H gets very hot even when the system is idle. Does it get hot also when idle on this new 780G board?
gazebo is offline
post #139 of 4430 Old 02-23-2008, 06:30 AM
elee532's Avatar
Quoted: 92 Post(s)
I am definitely interested in maximizing my audio capabilities. The ability to do some of the new HD audio formats over HDMI would be important. I understand that the MA69GM-S2H can do them over analog outputs. However, the analog inputs on my pre-amp are already being used by my SACD/DVD-A player. Given that, am I correct in understanding that the new MA78GM-S2H would fit the bill better for me?
elee532 is offline
post #140 of 4430 Old 02-23-2008, 07:11 AM
magnoman's Avatar
Yes, it gets quite warm even when idle.
I loaded up AMD OverDrive last night and I noticed a couple of things...
It appears that my 780G northbridge GPU runs about 81 degrees Celcius when idle in a completely open case (almost nervous to close it!). Under load (playing a Blu-ray) I've seen it as high as 87 degrees so far. Also, when idle the northbridge clocks down to 200 Mhz and then increases to 500 Mhz when under any kind of load.
magnoman is offline
post #141 of 4430 Old 02-23-2008, 07:22 AM
magnoman's Avatar
No, not at this time. The 780G chipset only supports 2 channel LPCM and I think regular Dolby Digital and DTS via HDMI but I haven't tried to get regular surround working yet over HDMI. The 2 channel LPCM seems to work fine though. The board does support sending Dolby Digital and DTS via the optical S/PDIF and converting from the HD audio formats to its 8 channel analog outs.
You may be more pleased with an upcoming Geforce 8200 based motherboard if you are concerned about HD audio formats over HDMI. The Geforce 8200 is reported to support 8 channel LPCM but even it doesn't support passing the HD formats in bitstream to an external decoder.
magnoman is offline
post #142 of 4430 Old 02-23-2008, 07:24 AM - Thread Starter
I've seen that 81c temp too - but I have put an 80mm fan directly on it to the point where it's cool to the touch and that number doesn't dip any lower, I'm wondering if AMD OD doesn't fully support 780G yet?
post #143 of 4430 Old 02-23-2008, 08:05 AM
magnoman's Avatar
Wouldn't surprise me. I just tried the same thing and mine came down to 80c and it also became cooler to the touch. Given the temp change of the heatsink I would have expected much more of a change in the sensor reading so who knows how truthful its being. Does yours also go up quite a bit during movie play-back? You eluded to a heat issue in an earlier post. Is it affecting play-back? I haven't seen it get too hot to play properly but then again I haven't tried closing the case yet.
magnoman is offline
post #144 of 4430 Old 02-23-2008, 08:13 AM - Thread Starter
Yes, I have two Rev 1.0 boards with the F3c BIOS (sorry, I can't send this out). During POTC: At World's End @ 1080p, if I do not actively cool the NB very quickly I start to get white pixel artifacts and then snowy bars - then the screen goes to snow and then black. It's unrecoverable. If I catch it quickly enough and put a fan back on it, the artifacts go away and I can watch the full movie. Acts the same on both boards. Funny thing is if I go out VGA I do not have this issue. I have even removed the NBs, cleaned the thermal gunk off, and applied Arctic Silver 5. As these boards were acquired through ClubIT from China and sold prior to the US launch, I am hesitant to make too much of it. There is no telling how ClubIT acquired these boards. Oh, and this is all open air, not in a chassis. So if some of you are not having this issue then I bet it is something that proper US retail product won't have. And I am working very closely with several people on this.
post #145 of 4430 Old 02-23-2008, 08:39 AM
magnoman's Avatar
Yes... ...During POTC: At World's End @ 1080p, if I do not actively cool the NB very quickly I start to get white pixel artifacts and then snowy bars - then the screen goes to snow and then black...
Just a thought but you might want to try to underclock it. Maybe try 400 Mhz?
I had initially heard that 400 Mhz was going to be the stock speed anyway... Maybe they decided to increase it to better compete with the GF8200.
Heck, for that matter, these Chinese Rev 1.0 boards could actually be 400 Mhz parts factory overclocked to 500 Mhz.
magnoman is offline
post #146 of 4430 Old 02-23-2008, 08:49 AM - Thread Starter
Great idea, I will try that immediately.
post #147 of 4430 Old 02-23-2008, 09:00 AM
binetree's Avatar
______
Thanks for the information.
Is a 380W psu enough for the 5000+ BE and GA-MA78GM-S2H combo? I will put in 2 HDD and an optical diver.
binetree is offline
post #148 of 4430 Old 02-23-2008, 09:13 AM
binetree's Avatar
I don't like the ATI drive either -- please let us know when you finish your study
binetree is offline
post #149 of 4430 Old 02-23-2008, 09:18 AM - Thread Starter
Dude, FANTASTIC call - @ 400MHz the issue took MUCH longer to pop up, but it's still there.
post #150 of 4430 Old 02-23-2008, 09:27 AM - Thread Starter
Reply Home Theater Computers
