is my system good enough - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-25-2008, 11:42 AM - Thread Starter
wormraper's Avatar
Quoted: 336 Post(s)
Liked: 178
Ok guys, probably been asked before but here goes. I am thinking of grabbing the hd dvd add on to add to my PC as a playback device for HD DVD.
I have a
AMD 3600 + (single core) cpu
Geforce 6600 gfx card
1.5 gigs of DDR PC3200 ram
I'm sending to a panny 42 inch 720 p plasma
Will I be able to run it smoothly enough (even if I play from Hard drive) or should I just get a standalone player as a backup player instead of using the cheap hd add on??
wormraper is offline
post #2 of 4 Old 02-25-2008, 11:44 AM
mpgxsvcd's Avatar
Quoted: 2778 Post(s)
Liked: 2462
The $50 ATI 3450 video card is probably the only thing you will need! Well you will have to purchase anyDVDHD and PowerDVD as well.
mpgxsvcd is offline
post #3 of 4 Old 02-25-2008, 11:50 AM - Thread Starter
wormraper's Avatar
Quoted: 336 Post(s)
Liked: 178
that's what I though on the GFX card. I'm in need of an upgrade on that badly anyways, probably grab the 8800gts. Luckily I already have PowerDVD and AnyDVDHD (I picked that up earlier when slysoft had a good sale).
post #4 of 4 Old 02-26-2008, 01:23 AM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
no,
No system is ever good enough, always need that next upgrade.
That aside, an HDCM compliant video card should be all you need. 3450 will do the trick, but I went for the 3870 since I game a bit on the same computer.
lespurgeon is offline
Reply Home Theater Computers
