The Over the Air Digital-to-Analog Converter Box Compatable with ReplayTVs Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 198 Old 06-30-2008, 03:11 PM
SeeSpotRun's Avatar
Can a Replay control a DTVpal?
-SeeSpotRun
SeeSpotRun is offline
post #92 of 198 Old 07-02-2008, 08:45 AM
slprp1's Avatar
Quoted: 12 Post(s)
Liked: 49
As I mentioned in an earlier post......
I am soooo desperate for assistance with this problem!......
I have three 5040's. Due to illness and financial constraints, I have had to give up cable and rely solely on three Zenith DT-900's. I need to be able to change channels using the IR blasters (for recording purposes). However, I have limited knowledge of computers, networks, etc. I'm impressed with what I've read about adding a new code for the Zenith CECB's. I have a notebook computer which works off of a cable modem and router, which is in my neighbor's apartment downstairs (he is graciously allowing me to share his cable internet).
Is there a relatively simple method (for me......a non-geek) to download this code to my 5040 units? Bear in mind that they are being used independently in two different rooms, with no network applications whatsoever.
Can I do something temporary just to download the Zenith code and then continue using my Replay's as I always have?
Is there any potential for harming the Replay's in any way?
I'm very satisfied with the Zenith (April) boxes and don't really want to switch to other boxes (or have the extra money to do so).
Is there any chance for me to get this done easily?
(I apologize in advance for not being very computer literate).
Thank you!
slprp1 is offline
post #93 of 198 Old 07-02-2008, 08:24 PM
brehob's Avatar
Has anyone tried controlling an Apex DT250 with a ReplayTV 5K IR blaster?
After mis-reading a post I used one of my coupons on a Zenith DTT900, thinking I could control it, but no-go. With no photo partition on my ReplayTV 5516 I don't think I'll be pushing new blaster codes to it soon.
So I'm hoping somebody's tried the Apex successfully. I'm not optimistic since I've never heard of an Apex cable box, but there's a lot I haven't heard of.
brehob is offline
post #94 of 198 Old 07-03-2008, 05:41 AM
chain777's Avatar
Originally Posted by KenL View Post
<<br /> What this means is going to a big busy Circuit City and digging though all the stock in search of boxes with this on the (center) barcode sticker on the exterior cardboard box.>
Ken, can you re-upload this image. It's NA.
--Andy--
chain777 is offline
post #95 of 198 Old 07-03-2008, 05:42 PM
slprp1's Avatar
Quoted: 12 Post(s)
Liked: 49
Thank you!
......anyone......PLEASE!!......THANKS!!!!
slprp1 is offline
post #96 of 198 Old 07-03-2008, 05:46 PM
KenL's Avatar
Disregard the serial number in that image, all April 2008 (or newer) DTT900 units seem to be OK.
But get a Zenith DTT901 now if at all possible, those units are all good and use the same blaster code.
KenL is offline
post #97 of 198 Old 07-03-2008, 10:37 PM - Thread Starter
icecow's Avatar
btw, KenL, if you have a distant mild curiousity whether I got the april zeniths.. Yes, I did, 2, haven't used them yet. I only found/used 2 of the 4 cards I got my hands on.
icecow is offline
post #98 of 198 Old 07-04-2008, 02:10 AM
slprp1's Avatar
Quoted: 12 Post(s)
Liked: 49
Originally Posted by SeeSpotRun View Post
So if I understand correctly, there are 3 boxes that the a Replay 5040 can control. There is the RCA but that box has lock up issues. There is the Channel Master CM-7000 but subchannels cannot be tuned. Then there is the Zenith boxes but that one requires Wirns to make a change on the Replay's software and you need a newer box so you don't have audio issues.
Is that correct?
I used one of my coupons and bought a Zenith 900 box from Circuit City. They did not have any 901's yet but did have the April 08 boxes (which is what I got).
I hooked it up and the box works but of course there is no built in code to change channels. I am not interested in any of the subchannels and the guide data from the local cable company has the proper channels for the stations I want.
After turning off the "auto turn off" feature, I am happy with the Zenith box. So, can anyone give me a short course on what I need to do to get the IR codes loaded? I do have a photo partition on that replay.
If it is a hassle, I suppose I can always go and get the Channel Master box.
-SeeSpotRun
......Is there a risk factor in downloading this new code to the 5040?
Can it cause any harm to the unit (or create major headaches to resolve)?
Is it a complicated procedure? What other equipment does it require?
Is anyone able to provide specific (step by step) details as to how it's done?
(I've never used Wirns previously for any purpose and am somewhat of a novice but I'm very anxious to be able to use the Zenith to change channels on the 5040 and I'm willing to learn).
......Please......any (detailed) assistance would be greatly appreciated!!
THANKS!!
slprp1 is offline
post #99 of 198 Old 07-05-2008, 08:30 PM
famewolf's Avatar
-SeeSpotRun
The dtvpal was just released so I can't say for certain however the assumption is that since it's released by directv it would use the directtv codes which are supported by the replay. Even if it does not the event timer in it would allow you to configure the dtvpal to change to whatever channel you needed at whatever time you needed and not even use an ir blaster theoretically. You wouldn't even have to do manual records..just click on the show you want to record on whatever channel it shows up...let it do a line in record at the same time you have the event on the dtvpal set.
famewolf is offline
post #100 of 198 Old 07-05-2008, 09:41 PM
slprp1's Avatar
Quoted: 12 Post(s)
Liked: 49
......Actually, the "DTVpal" is a Dish Network product (not DirectTV).
Supposedly, it uses a Dish Network code.
Has anyone had any (successful) experience using a "DTVpal" with Replaytv?
BTW - If you read recent comments from users of the "DTVpal" (on this forum), you'll find that there are several reported "bugs" (some involving the much anticipated program timer), making it questionable as a reliable unit. Additionally, the EPG is reported to be reduced considerably from the (promised) 7 days (which was one of the features that set ths unit apart from the others).
This, combined with the fact that they increased the (long promised) price by $20.00 (at the last minute before the release, no less!) and are charging a shipping charge for each unit, might take this box off of many short lists (or even long lists)......a long awaited dissapointment!
slprp1 is offline
post #101 of 198 Old 07-05-2008, 10:07 PM
slprp1's Avatar
Quoted: 12 Post(s)
Liked: 49
Just a note that the DTVPal's are available for $59.99 + shipping so $20 after coupon.
Features:
Analog pass-though
Switch between digital and analog channels with the push of a button
On-screen program guide
See what’s showing on every channel with the FREE on-screen program guide
Event timer
Set a timer to turn your DTVPal on and tuned to the desired channel before your favorite show starts playing
Programming search
Search by name for the shows you want to watch
Alternative audio
Receive second audio feed in alternate language (broadcaster dependent)
Closed-captioning
Easily turn on closed captions using your DTVPal remote control
Parental controls
Block programs you deem inappropriate based on rating or channel
Stereo audio output
Enjoy enhanced sound when connected to your stereo TV
Setup Wizard
Automatic channel selection and easy setup
http://www.dtvpal.com/
slprp1 is offline
post #102 of 198 Old 07-05-2008, 11:25 PM
slprp1's Avatar
Quoted: 12 Post(s)
Liked: 49
Is that correct?
-SeeSpotRun
......please check your private messages......Thanks!
slprp1 is offline
post #103 of 198 Old 07-06-2008, 12:33 AM
slprp1's Avatar
Quoted: 12 Post(s)
Liked: 49
KenL......please check your private messages......Thank you!
slprp1 is offline
post #104 of 198 Old 07-07-2008, 11:01 PM
rpesq's Avatar
I purchased a DTVPal ("Pal"), and it does work excellent with my Showstopper. As much as I dislike DISH as a company, this is a quality product. Easily the best CECB that I have used (and I have setup 5 different models, and read ~thoroughly~ about almost every other CECB that exists).
You can use the standard DISH 0775 IR blaster code, and all functions work great. In fact, using that same code with any Universal remote (under the "Satellite" button) allows you to control the DTVpal with your universal remote.
My previous experience using a Digital Stream 9950 with my SS was less-than-satisfactory. The Pal is the opposite. Channel changes have been much faster and reliable, the Pal's tuner is MUCH better than the DS 9950, as I have gained 3 channels and the others show approx 10% stronger signal, and most importantly, I was getting semi-frequent Blue-Screens with the DS 9950 playing thru the Showstopper. None with the Pal. The DTVPal runs cooler, is smaller, and executes all of its functions much faster than the DS 9950.
Potentially, you can manually tune sub-channels with the DTVPal, as any code that starts with a "0" is attempted to be interpreted as an attempt to directly tune a subchannel. Thus, "0022" is 2.2. "22" is interpreted as 22.1.
Now, this does NOT work with the Replay programmed as having DISH service. Entering, for example, "0132" (and wanting channel 13.2) is sent as "132", and is interpreted as 53.2, which I suspect is just the DTVPal tuning the highest number OTA channel in my area, since 132 is obviously invalid entry.
The Pal's Timers function is enough to satisfy my needs to record subchannel programming, at least for now. I have read that some DTVpals have timer quirks, but I have not had any issues. I seem to have the latest shipping firmware, maybe that is a difference.
If Replay would be willing to support one or two CECB's, the DTVPal would be its best choice. The DISH IR codes are already in all of their boxes, and it does interface smoothly. If we could just get a full OTA DTV channel guide, this combination would be excellent.
rpesq is offline
post #105 of 198 Old 07-08-2008, 12:44 AM
famewolf's Avatar
I'm told the dtvpal WILL support up to 7 days of EPG but is dependent on the information being sent from your local sources so if they are only sending 24 hours of data thats all it has to work with. Very tempted to order at least one dtvpal (my other choice is a channel master since I can probably control it and my antenna rotator at same time from replay with dual ir emitter but the channel master does not do timers....
When you set up a timer does it do it by show in the epg or a specific time/date? If a show shifted an hour would the "timer" adjust if it showed in the EPG on the new time?
I have a cheap dvr recorder too....thinking the dtvpal would be the perfect accessory.
famewolf is offline
post #106 of 198 Old 07-08-2008, 08:13 PM
adfree's Avatar
My Radio Shack Digital Stream DTX 9950 pass-through model is controlled by the IR Blaster of my Replay 5040 using code 0899. I had none of the problems I experienced with the DTX9900.
adfree is offline
post #107 of 198 Old 07-08-2008, 08:15 PM
nded's Avatar
Any chance this Rat Shack box has anmorphic 16:9 on an S-Video port?
Ed Qualls - Just Add Power
nded is offline
post #108 of 198 Old 07-09-2008, 08:03 AM
BaysideBas's Avatar
Doesn't look that way:
http://www.radioshack.com/product/in...rt&tab=summary
||||||||||||||| Soylent Green is.......PEOPLE! Or is it a Status Bar? Ah, it's a dessert topping!
BaysideBas is offline
post #109 of 198 Old 07-09-2008, 12:24 PM
chain777's Avatar
I just picked up a DTX9950 from rat shack. I just hooked it up to the 5040, using code 0899 for DirectTV locals (thanks adfree), and it seems to work perfectly. I can tune all of the channels except a couple sub-channels on PBS and METV. I doesn't have S-Video, but it does do anamorphic. The picture quality is amazing compared to the analog OTA I was using.
I was going to go with the Zenith, and may still get one, but I didn't really feel like messing with Wirns. I've never used it, but may have to learn if I want all the channels mapped correctly, or if I end up with a Zenith box.
I haven't played around with it much, but I'll report back if I find anything wrong, or interesting.
--Andy--
chain777 is offline
post #110 of 198 Old 07-10-2008, 07:20 AM
jastori's Avatar
Can anyone comment about whether the DTVPal supports anamorphic output?
EDIT: Seems that it does according to a couple of other on-line references.... from CNET Review:
• Full: Fills the screen on wide-screen programs, but distorts the aspect ratio on analog 4:3 TVs. However, this mode keeps wide-screen programs in the correct aspect ratio and fills the screen on wide-screen TVs.
jastori is offline
post #111 of 198 Old 07-10-2008, 07:49 PM
SeeSpotRun's Avatar
I ordered a DTVpal last week and it should be here soon.
I look forword to finding out if it can be controlled by the replay as it. According to the manual (on-line), it should work with standard DTV codes.
-SeeSpotRun
post #112 of 198 Old 07-13-2008, 09:34 AM
SeeSpotRun's Avatar
Ok, I got the DTVpal and set it up.
The good news is that code 0775 will change channels. It looks like codes 1005, 1070, and 1071 are likely to work too because they made the light on the DTVpal blink but I haven't gone further with them. The setup is pretty slick, including a mini tv window so that while making changes, you can still watch your show. It does have analog pass through, has the ability to do timed events, has a "zoom" feature to change aspect ratios and has a much better guide than the prior Zenith box.
Now the bad news... The replay will not turn the DTVpal box on. As a result, it needs to be left on with the power save feature disabled. When you do that, you get a warning about the DTVpal not being able to do system maintainence. Also, I think that I had a stronger signal using the previous Zenith box. When the signal is too low on the DTVpal, a screen will come up offering help. The only way to get off that screen is to hit the cancel button or use chanel up or down. This a big problem because if you have to always leave the box on, and then at some point the signal gets too low, then the box will be stuck at the "signal too low" screen even if the replay issues a channel change command and you will end up with that for your entire recording.
-SeeSpotRun
post #113 of 198 Old 07-13-2008, 04:05 PM
blabber's Avatar
...Now the bad news... The replay will not turn the DTVpal box on. As a result, it needs to be left on with the power save feature disabled. ...
Same problem with my Digital Stream DTX-9900 unit. Strange, since it does turn the unit on during the testing of blaster codes during the search (code 0899 is the one), but won't do it in normal operation.
Maybe this is because there is only one blaster signal for on and off (like a toggle) and it doesn't want to switch it off by mistake?
"Manuals? What manuals? We don't need no stinkin' manuals!!"
blabber is offline
post #114 of 198 Old 07-14-2008, 10:29 AM
ewilen's Avatar
How easy is it to get the Replay to make the DTVPal tune subchannels over the IRblaster?
ewilen is offline
post #115 of 198 Old 07-14-2008, 01:03 PM
SeeSpotRun's Avatar
I am going to have to plead ignorance on the subchannels. Other than using channel up or down, I don't know how to turn to a subchannel using the remote. In my area, there is only one sub channel and it is all weather so I haven't put any effort in to it.
-SeeSpotRun
post #116 of 198 Old 07-14-2008, 02:14 PM
georgepds's Avatar
FYI, here is the list of digital converters supported by TIVO
http://www3.tivo.com/setupandsupport...ConverterBoxes
"Coupon-Eligible Digital Converter Boxes
If you aren't ready to buy a digital-ready TV, and plan to purchase a digital converter box to work with your existing TiVo setup, please review the following for coupon-eligible Digital Converter Boxes:
Supported Models
* Insignia NS-DXA1
* Venturer STB7766G
* Magnavox TB100MW9
* RCA DTA 800A
* GE 22729
* Zenith DTT900
* Channel Master CM-7000
* Lasonic LTA-260
* Philco TB100HH9
* Samsonic FT300A
* Tivax STB-T9
* Artec T3Apro
Not Supported
* Digital Stream DTX9000
Please note, a software update (available late-Summer) will be required in order to control the digital converter boxes. Affected customers will be notified by email when the release is available."
georgepds is offline
post #117 of 198 Old 07-24-2008, 09:00 AM
pakcikkayo's Avatar
Got CM7000 for my Replay and it works okay with remote on hand and changing the channel manually but schedule recordings not working since :
- the IR blaster do not turn on the CM7000 automatically - does this means CM7000 need to be on all the time?
- IR Blaster did not tune to the channel it suppose to record. It recorded whatever channel it was on before.
So are you guys having the same experience. What good is the IR Blaster if it can't automatically tuned to the channel it supposed to record and turn on the CM7000 (and off once done)?
Please advise.
Edit: spelling.
pakcikkayo is offline
post #118 of 198 Old 07-26-2008, 08:31 PM
famewolf's Avatar
Here's something I have not seen anyone mention on dtvpal's....if you are giving it a lineup that doesn't have all your locals like a cable feed where most of the channels match it won't let you set up a manual record for a channel not in the lineup....on the dtvpal lets say you have two subchannels...9-1 and 9-2....entering a record for 9 works fine...if you would like to do a record of 9-2 manually and channel 10 exists in the lineup but is not a "real" channel you can setup a manual record for channel "10"....the dtvpal drops to the next lowest channel which in this case is 9-2. This won't work if you have a 9-1, 9-2 and 9-3 as you could only get to 9-1 and 9-3 but you can also delete those "weather only" channels or dupe channels that you don't need. Hope someone finds this useful.
famewolf is offline
post #119 of 198 Old 07-27-2008, 11:40 AM
slprp1's Avatar
Quoted: 12 Post(s)
Liked: 49
Please advise.
Edit: spelling.
The Replay units were never designed to control power on/off on these devices (or any type of cable/satellite box). You must leave the converter box on.
Have you tried to use the CM-7000 to record (while leaving it on)?
Does it change channels at the time of the recording (if left on)?
slprp1 is offline
post #120 of 198 Old 07-29-2008, 03:40 PM
pakcikkayo's Avatar
Okay, got it. CM-7000 need to be on.
It recorded fine but we only watch/recording one channel (PBS). I think IR blaster change the channel as required.
Now I need to find a way to turn on the CM-7000 on recording time instead of leaving it on all the time. Such a waste of energy..it creates unnecessary heat.
Reply ReplayTV & Showstopper PVRs
