Replay Remote Malfunction - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-30-2008, 11:54 AM - Thread Starter
cuuplate's Avatar
I have the original remote that came with my RTV5040 and it has stopped working. When I press any button, the red LED blinks once fast, then a pause, then two slower blinks. I've tried taking out the batteries, leaving the batteries out for days, but it doesn't help. Is there anything I can do to get this to work normally again?
cuuplate is offline
post #2 of 10 Old 03-30-2008, 06:31 PM
rcroft's Avatar
Buy a new remote. OneForAll has a variety of remotes that work with Replays. Look around before you buy. They have a variety of configurations, some have better button layouts than others. You'll want the skip forward and backward buttons to be in easy to press locations.
You should be able to find one fairly cheap. Like $10 or so. Certainly less than $20.
rcroft is offline
post #3 of 10 Old 03-30-2008, 09:34 PM - Thread Starter
cuuplate's Avatar
I have a replacement remote, but it doesn't have the zones button. It is a learning remote, so if I could get my original remote to work, I could teach it the zones button and all would be well. Does this really mean the remote is dead? It really seems like it is in some programming mode or something. Has this happened to anyone else?
cuuplate is offline
post #4 of 10 Old 03-30-2008, 11:38 PM
MrFussy's Avatar
Harmony remotes. I have the 550 and it is programmable to have every button I need from the original. THe PM-DV8 is a good, cheap, learning remote that has all the replay buttons.
3RTV over ethernet + DVA show server over buffalo wireless
MrFussy is offline
post #5 of 10 Old 03-30-2008, 11:51 PM
hdonzis's Avatar
Quoted: 12 Post(s)
The Panasonic PMDVR8 has all of the Replay buttons on it, including the Zones button (commercial advance, instant replay, etc.)...
The Panasonic PMDVD6 also has most of the Replay buttons on it. As a learning remote, I programmed the eject key to be the Zones button for the Replay...
Henry
hdonzis is offline
post #6 of 10 Old 03-31-2008, 07:17 PM
rcroft's Avatar
I've been happy with my OneForAll 6131 that I've had for several years. It has a button labeled "PVR Menu" that is the Replay Guide button, but it doesn't have a Replay Zones button.
Fortunately, I don't care about the Replay Zones very much, and when I do, I can get to it through the menu button. Replay Zones is one of the choices in the Replay Menu.
rcroft is offline
post #7 of 10 Old 03-31-2008, 10:55 PM
Ace987's Avatar
The biggest problem is that without the "Replay Zones" button, you can't get into the sometimes useful hidden menus like "2-4-3 Zones" or "4-1-1 Zone" when you need to do troubleshooting. Fortunately, those with 5k and newer models don't need 243 to force updates. I don't believe it's in the 4k models and I know it's not in the 3k, Showstopper and previous models.
Like you said, you don't use it much, but the zones button is very handy for troubleshooting.
PostCount++;
ReplayTV 5080 - 00004-54831-79633
Ace987 is offline
post #8 of 10 Old 04-01-2008, 12:04 AM
ram1220's Avatar
I've seen this problem a few times with my 5504 remote. A fresh set of batteries has always solved the problem for me.
Bob
ram1220 is offline
post #9 of 10 Old 04-02-2008, 01:53 PM
robkwil61's Avatar
This post may help.
http://www.avsforum.com/avs-vb/showthread.php?t=935887
Official Netgear Beta Tester
Chicago Illinois, United States
robkwil61 is offline
post #10 of 10 Old 04-02-2008, 02:38 PM
rm -rf *.*'s Avatar
That sounds a lot like the low battery blink code.
Have you tried new batteries?
Still no news from New Zealand.
If we ever get any, we'll be sure to let you know.
rm -rf *.* is offline
Reply ReplayTV & Showstopper PVRs
