Connecting ReplayTV With Wireless Internet and No Cable/DSL Modem - AVS Forum | Home Theater Discussions And Reviews
Old 06-04-2008, 02:45 PM - Thread Starter
apocalypse_yao's Avatar
Hey everyone, I couldn't find my question in the ReplayTV FAQ. My apartment building has wireless internet installed, so I don't get my internet via phone modem, cable or DSL. Is there a way for my ReplayTV to connect to the Replay network by using an ethernet cable to connect with my computer? I'm not sure how else the ReplayTV can access the wireless internet connection. Thanks!
apocalypse_yao is offline
Old 06-04-2008, 03:04 PM
dstoffa's Avatar
Quoted: 56 Post(s)
Liked: 24
1. You'll have to leave the laptop / computer on.
2. You'll need a Cross-over Ethernet Cable.
3. You'll need to assign an IP Address to your PC (for the Ethernet LAN Card Only).
4. You'll have to configure your wireless adapter on your laptop / computer to share its Internet Connection.
I leave it to others how to configure the RTV. At a minimum, you'd have to put it on the same subnet as your PC's Ethernet Card. I also guess that you'd have to manually configure the RTV to use your PC as its gateway. Not really sure how hard or difficult it is.
I leave that to others.
In a nutshell, it's possible.
Cheers!
-Doug
dstoffa is offline
Old 06-04-2008, 05:00 PM
elorimer's Avatar
Wouldn't it be simpler to use a gaming adapter or wireless bridge?
elorimer is offline
