Help with FIOS & IVS? - AVS Forum
post #1 of 8 Old 08-12-2008, 04:46 PM - Thread Starter
n.phelge's Avatar
I moved recently, and we just got FIOS. But, I'm unsuccessful in setting up Internet Video Sharing. My configuration is:
- Standard Actiontec router/modem
- WGE101 wireless bridge connected to ReplayTV unit
I have no problem downloading the channel guide, but any attempts to setup port forwarding through the Actiontec fails the connection test. I've searched all over this forum and the web for suggestions, but I have been unsuccessful. If someone has any steps or recommendations, I would appreciate it.
Thanks in advance
n.phelge is offline
post #2 of 8 Old 08-12-2008, 10:16 PM
gweempose's Avatar
Quoted: 13 Post(s)
Liked: 30
Originally Posted by n.phelge View Post
I have no problem downloading the channel guide ...
With FIOS that should have taken all of three seconds.
gweempose is offline
post #3 of 8 Old 08-13-2008, 07:08 AM
BaysideBas's Avatar
Well, I've had FiOS broadband for 2 years now. I recall setting up port forwarding on the DLink router to have been a straightforward matter, maybe 15 minutes for 4 Replays. Last week I finally got FiOS TV and with it came a brand new router [private branded Verizon]. This router features a coax connection that is used by the STBs for guide data and other communications with the mother ship [a single cable to a splitter on the video line handles all STBs this side of the ONT - Optical Network Terminal].
However, setting up port forwarding was anything but straightforward, it took me over 3 hours to figure it out and make it work. If there hadn't been IVS tester on poopli, I'd still be fiddling around with the settings. The router manual was of no help, and it was strictly a matter of try this, try that, lather, rinse, repeat.
||||||||||||||| Soylent Green is.......PEOPLE! Or is it a Status Bar? Ah, it's a dessert topping!
BaysideBas is offline
post #4 of 8 Old 08-13-2008, 06:01 PM - Thread Starter
n.phelge's Avatar
That has been my process as well, but no luck yet. Could you please do me a favor and post the port forwarding rule details you have setup for your ReplayTV on the modem configuration? Setting this stuff up with DSL was a piece of cake.
Thanks in advance
n.phelge is offline
post #5 of 8 Old 08-14-2008, 05:29 AM
BaysideBas's Avatar
That probably wouldn't help you at all, all routers have their own way of setting port forwarding up. So, unless your router is a Verizon MI424WR Wireless Broadband Router, my findings not only wouldn't help, but they could actually screw up your setup.
post #6 of 8 Old 08-14-2008, 06:44 AM
rlichtefeld's Avatar
Thanks in advance
Try:
http://portforward.com/
It has instructions for many routers on how to forward ports.
Rob
Thanks: ijprest, waynethedvrguy, Remmer99, hdonzis, gduprey, LeeThompson, j.m., archdog99, FlipFlop, The Dreamer, chriv and all the other Replay Hackers out there.
rlichtefeld is offline
post #7 of 8 Old 08-14-2008, 10:25 AM
BaysideBas's Avatar
This may help you, apparently the Verizon router is the Actiontec. At least the model designations are the same and the screenshots on the web page match.
http://portforward.com/english/route...WR/default.htm
However, one point of contention is that in the dropdown protocol list there was no TCP, and I had to go a couple of screens deeper to retrieve it. That made no sense to me since TCP is the most common protocol in use.
Good luck! And thanks Rob for the pointer to portforward.com. I now know a couple of useful bits of information about my router that I didn't before.
post #8 of 8 Old 11-15-2008, 09:18 AM
rf75's Avatar
(Post removed because I figured out the port forwarding should be FROM: ANY TO: port of RTV instead of FROM: port of RTV TO: port of RTV. Duh.)
rf75 is offline
Reply ReplayTV & Showstopper PVRs
User Tag List
