SwapDV available - Replay TV client, server and guide editor - Page 19 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #541 of 550 Old 06-10-2002, 11:53 AM
ocraven's Avatar
Originally posted by jotter
Hi,
The SwapDV application allows you to manage your own digital video library, based on content backed up from from your replay TV. It combines the functionality of a replay client (Yet Another Replay Client), a replay server (Yet Another Replay Server) and a replay guide editor :)
The application is for all platforms.
A small feature list:
* connect to a replay TV and browse its contents
* download mpegs (raw/modified)
* save and edit guides (raw/header stripped)
* import digital video into your local server, either from your replay TV or from your disk
* edit, add, remove shows and channels
* emulate a replayTV box on your local network
* "real" replay TVs can play back videos from your server
SwapDV 0.5 and source code released. Go to http://swapdv.sourceforge.net to download the new version and/or sources
Aha! This could be what I'm looking for. I wasn't looking for your nifty opportunity to transfer shows between RTV and PC, though I may try that eventually. What I need is something much simpler, which may be a minor feature of your creation, the guide editor.
ReplayTV doesn't subscribe to the Canadian TV listings (even though their supplier, Tribune, does have them available. But if I could somehow reassign the Buffalo or Niagara Falls cable stations to the channels they are received on for the Toronto cable system, I'd have all but a few stray channels accessible with up-to-date program guides! So what I'm hoping to be able to do is regularly download a neighbor-town's listings, edit the guide to reassign the channel numbers as they occur locally in Canada, and then send the edited guide back to the ReplayTV. Would I be able to use SwapDV to do that? I know it's not your primary goal, but if it works as a side effect you can make many people happy!
ocraven is offline
post #542 of 550 Old 06-10-2002, 03:21 PM
jimre's Avatar
Nope. You're talking about the CHANNEL GUIDE listings. I'm not aware of any way to edit those. SwapDV allows you to edit your PC's REPLAY GUIDE listing. This is the list of recorded shows stored on your PC. Not the kind of "guide editor" you're asking for...
jimre is offline
post #543 of 550 Old 06-11-2002, 08:13 AM
ocraven's Avatar
Ah, yes, I see. Thanks.
So that means this particular application allowsRePlay Guide editting (on the PC) and not Channel Guide editting. For those who have played around with these issues, though, does it at least seem like Channel Guide editting might be do-able?
ocraven is offline
post #544 of 550 Old 06-12-2002, 11:20 AM - Thread Starter
jotter's Avatar
No. There is very little accessible information on the replay (accept for the shows and replay guide) and no easy way (short of taking the HDD out?) of getting at the channel listings stored in the replay. Even if you could remotely access the listings, work out how it was structured (no trivial task), work out how to edit it correctly with new information, there doesn't appear to be any way of putting the channel guide back.
I'd ask ReplayTV (or rather Sonic Blue) for some support with your problem.
Cheers
Jonathan
jotter is offline
post #545 of 550 Old 06-12-2002, 01:03 PM
Robbo's Avatar
Originally posted by dkan24
I had the same problem once. I fixed it by creating another channel in swapdv. Then I moved evrything into that channel. Then deleted the old channel.
That fixed the problem. Thanks.
XBL Gamertag: Robbo67
Robbo is offline
post #546 of 550 Old 09-05-2002, 08:51 PM
TomBowman's Avatar
When I click on the link to download SwapDV, it goes to SourceForge.net with nothing in the window to download.
I look at the SourceForge site for information about SwapDV and see alot of talk, but again, no downloadable files.
Has support for this product been removed?
TB
TomBowman is offline
post #547 of 550 Old 09-05-2002, 08:57 PM
jgourd's Avatar
SwapDV has been replaced by DVArchive
jgourd is offline
post #548 of 550 Old 09-05-2002, 09:02 PM
TomBowman's Avatar
When I download the zip and the expand it using Winzip, I get about 8 files with "0" bytes in each.
Downloaded twice with same results. Downloaded the Compatible version and it exploded fine.
What ups?
post #549 of 550 Old 09-05-2002, 09:51 PM
TomBowman's Avatar
I tried it on another PC and worked fine. Found out the version of WinZip I was using was 6.1. Downloaded version 8 and it work fine.
Sorry for the bad case of the Dummas#$%^&.
post #550 of 550 Old 01-01-2003, 02:10 AM
Branxx's Avatar
Old versions of SwapDV can be found here.
Branxx is offline
Closed Thread ReplayTV & Showstopper PVRs
