NYC Local channels on DirecTV - AVS Forum | Home Theater Discussions And Reviews
Old 02-11-2010, 07:35 AM - Thread Starter
Tirebiter's Avatar
I know this is a Zap2It issue, and I emailed them last night (no reply yet).
Sometime yesterday, they removed the first 5 channels in the New York local station lineup (channels 880 thru 884) which happens to include all 4 major networks. I saw this in DVArchive and on my live ReplayTVs. I went to the Zap2It online listings and it is the same there too.
I can still manually enter the numbers in live TV and see the channels, but I don't have a program guide for them. Any recording has to be done with the "Manual" option.
I'm guessing that any electronic TV guide that uses Zap2It is affected and not only RTV. I hope they fix it soon.
Tirebiter is offline
Old 02-11-2010, 07:54 AM - Thread Starter
Tirebiter's Avatar
I did a Net Connect and the good news is that there are listings for channels 880-884 again.
The bad news is they aren't the right channels. They are listings for Irish and Italian music (DirecTV pipes in the XM radio music stations). When I select the channels, I still see the original TV networks, so still no luck in seeing what's on or scheduling recordings via the Channel Guide.
Maybe a blitz of emails to Zap2It will get this fixed quickly.
Old 02-11-2010, 08:51 AM - Thread Starter
Tirebiter's Avatar
Hmm, the 4 major networks are duplicated in the 380 to 388 channel range so the situation isn't as "dire" as I thought. The fifth missing channel isn't important to me. I don't watch anything on it. But it is still inconvenient to have these channels separated from the rest of the local channels in the on-screen guide.
Hopefully the zap2it drones are devising a solution and order will be restored to the multiverse.
Old 06-21-2012, 10:06 AM
MichaelLAX's Avatar
Quoted: 18 Post(s)
Liked: 29
Enter the applicable zip codes toward the bottom of this page:
DirecTV Local Channels
MichaelLAX is offline
Old 06-21-2012, 10:52 PM
ClearToLand's Avatar
Quoted: 26 Post(s)
Liked: 31
SUBTITLE: WiRNS is *GREAT* For Re-Arranging Your Channel Guide! smile.gif
Originally Posted by Tirebiter View Post
Hmm, the 4 major networks are duplicated in the 380 to 388 channel range so the situation isn't as "dire" as I thought. The fifth missing channel isn't important to me. I don't watch anything on it. But it is still inconvenient to have these channels separated from the rest of the local channels in the on-screen guide...
Do you use WiRNS?
If yes, you can create up to three CUSTOM lineups for one ReplayTV, gathering your 'Missing Guide Data'. Then, you can REMAP those channels to be wherever you want them - i.e. back in the 800s, or even down in the single digits like the original NYC channels from the 50s:
  • CBS: 2
  • NBC: 4
  • FOX: 5
  • ABC: 7
  • WOR: 9
  • PIX: 11
  • NET: 13
Code:
#Created by WiRNS Configuration
#IMPORTANT - the ReplayTV will automatically remap channels in the 8000-9000 range and may with others as well.
#FORMAT old_channel,old_callsign,new_channel,new_callsign,include_channel,provider
I resisted using WiRNS for several years because, for me, it's always been temperamental, where DVArchive has been pretty much 'Rock Solid'. But, with ~600+ channels in the cable lineup - the MAJORITY of which I either don't subscribe to or don't watch, I needed a way to trim that number down to something manageable. WiRNS was the ticket.
Unfortunately, now that *ALL* of my ReplayTVs are using WiRNS, it has decided to get moody once again - "WiRNS has unexpectedly closed. Send report?"
The DEBUG Log shows:
[2012-06-18 21:39:44] HTTPClient WebException: HTTP error connecting to 192.168.0.117
NotFound
[2012-06-18 21:39:44] HTTPClient URI: http://192.168.0.117/Device_Descr.xml
[2012-06-18 21:39:44] Refresh(): System.Exception: Error parsing device description from 192.168.0.117! ---> System.ArgumentNullException: Value cannot be null.
Parameter name: s
at System.IO.StringReader..ctor(String s)
at System.Xml.XmlDocument.LoadXml(String xml)
at WiRNS.Replay.ReplayDevice.GetDeviceDescription()
--- End of inner exception stack trace ---
at WiRNS.Replay.ReplayDevice..ctor(String ip, String Port)
at WiRNS.Replay.ReplayType..ctor(String name, String ip, Int32 type, String color, String input1, String input2, String input3, String serial, String isn, String port, String ivsNickname, String lastNetConnect, Boolean proxyGuide, Boolean doPoopli, Boolean doIVSBase, Boolean includeReceived, Boolean doJIT, Boolean IVSIntercept, Boolean RemoteReplay, Int32 quality, Int32 keep, Int64 guaranteed, String category)
at WiRNS.WiRNSMain.ForceReplayUpdate()
and entering "http://192.168.0.117/Device_Descr.xml" into a browser results in a '404 Error' until I COLD BOOT the specific ReplayTV. It worked OK for a good month, so, it's another interesting puzzle to research and discover what's wrong now. rolleyes.gifwink.gif
I changed DNS1 on the offending ReplayTV from WiRNS to my Router and now the rest of my ReplayTVs can get Guide Data - their last update was 06/16/12 and I just noticed it when I was entering the new season of USA shows into the 'Schedule'. eek.gif
Low Post Count <> Low Knowledge ergo High Post Count <> High Knowledge
ClearToLand's Picks For Best Answers to Common ReplayTV Questions
Remember, it's only TV...
ClearToLand is offline
