How to get 1 replaytv out of 3 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-16-2010, 12:20 PM - Thread Starter
elorimer's Avatar
I have three replaytvs in various stages of inoperability:
5040, monthly, which I cancelled, soldered EEPROM, otherwise ok
5040, lifetime, ethernet port zapped by lightning, socketed EEPROM
4500, IR blaster port doesn't work, and cable requires a set top box
I'd like to get one working again without restarting the monthly subscription. I'm not up to unsoldering the EEPROM chip in the monthly and resoldering the lifetime.
I was thinking of getting a monthly 5040 on ebay, but I haven't been able to figure out how to know if any given one would have a socketed EEPROM. A montly 4500 would be easy, but they seem rare.
Advice?
elorimer is offline
post #2 of 8 Old 08-16-2010, 01:52 PM
hdonzis's Avatar
Quoted: 12 Post(s)
I would definitely contact Mikeyboy! You would have several possibilities with him. He could repair your broken 5040 lifetime, he could sell you a replacement 50xx motherboard transferred from the lifetime, and he could either fix or sell you a 45xx motherboard. If you contact him, maybe you can work something out to trade him your 5040 monthly for some of this, or maybe he could move your lifetime EEPROM to the monthly unit...
Henry
hdonzis is offline
post #3 of 8 Old 08-16-2010, 03:41 PM
dstoffa's Avatar
Quoted: 56 Post(s)
Liked: 24
Advice?
You don't need to open the case to determine if the eeprom is soldered or socketed. If you know what you are looking at, you can look at the chip through the vents on the RTV's left hand side (when facing the front panel).
You'd have to ask the seller to check.... And that is where the problem lay.
dstoffa is offline
post #4 of 8 Old 08-16-2010, 03:42 PM
dstoffa's Avatar
Quoted: 56 Post(s)
Liked: 24
Advice?
Use the modem on the lifetime unit?
dstoffa is offline
post #5 of 8 Old 08-17-2010, 01:51 PM - Thread Starter
elorimer's Avatar
Yes, exactly. I sent a question about whether one unit was monthly or lifetime, and the response I got back was "Well, it still has the warranty sticker on the back, so the lifetime subscription must be in there". Still trying to figure that one out.
elorimer is offline
post #6 of 8 Old 08-18-2010, 09:27 AM
Ed_Gein's Avatar
Oh man! I might have to make that my new signature!
Ed_Gein is offline
post #7 of 8 Old 08-19-2010, 11:19 AM
gbuskirk's Avatar
I see from this link, that the 4500 box had it's ethernet interface on a PCI card. If your 5040's also do, how about swapping the ethernet cards on the two 5040's?
The Other Glenn
gbuskirk is offline
post #8 of 8 Old 08-19-2010, 11:21 AM
dstoffa's Avatar
Quoted: 56 Post(s)
Liked: 24
5000 series and 5500 series RTV's have ethernet ports integrated with the motherboard. Hot work is required for repair.
Cheers!
-Doug
dstoffa is offline
Reply ReplayTV & Showstopper PVRs
