Dead CM 7000 - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
Old 09-13-2013, 08:14 PM
Whitebar's Avatar
I not sure where you measured on the logic board for the 3.04 and 1.17. All the thru hole caps on the logic board are difficult to change. The internal ground plane takes a lot of heat before getting the temp high enough to melt the solder.
Part numbers for the two 33uf E5/E6 were listed here.
After repairing 60 plus units, trust me the caps are the problem.
The issue in post #8 with the domed ET1 cap on the logic board is very rare. The reason that cap failed is because it was installed backwards. In all the units I have fixed, none have had any of the caps installed backwards.
Whitebar is offline
Old 09-22-2013, 05:49 PM
sciconf's Avatar
Thanks @Whitebar
The 3.04 and 1.17 were from E5/E6.
A friend of mine measured my power supply voltages and ripples and says that the problem is in the logic board - he feels that the ripples are not a lot (power supply). Then again, he is not an expert on CM-7000.
Which part of MI are you? I might be coming to Troy - maybe I can bring it with me then.
sciconf is offline
Old 09-23-2013, 03:58 AM
Whitebar's Avatar
While it maybe just the logic board at this time, the caps on the power supply will also fail in the future, I would replace them at the same time.
I sent you a PM.
Whitebar is offline
Old 09-27-2013, 07:30 PM
sciconf's Avatar
The two 33uf part are the ones that need to be replaced. They are in the 1.2v switching power supply circuit. The other 470/1000 are bulk capacitors and do not get stressed.
These 470/1000 are on logic board?
Which are the caps for the 5V circuit on power supply board?
I got a insignia DTV now - it works but unsure if the CM7000 received better signal.
sciconf is offline
Old 06-10-2014, 03:27 PM
Sonshine's Avatar
How do I get Whitebar's info to possibly send my CM7000 for possible repair?
Sonshine is offline
Old 06-10-2014, 04:44 PM
jweinel's Avatar
Sonshine, I suggest that you send him a Private Message.Looks like he was on AVS earlier today. Click near his name below his avatar in post #63 above and then click "Send PM".
Jim
jweinel is online now
Old 11-14-2014, 01:01 PM
cat.lady's Avatar
Liked: 0
My CM-7000 went out after several years of faithful use. I got another and that one went out within hours! If Whitebar is still doing repairs can he PM me? I tired to send him one but there is a posting quota I didn't reach yet to qualify to send PM's to members. Thanks!
cat.lady is offline
Old 11-15-2014, 12:24 AM
Ecaroh's Avatar
cat.lady, post here if interested. I have two of these that have had the caps upgraded (by me) and are working nicely. At this point I only need one, at the most. In other words, I can sell you one with reliable caps if that will fit the bill. Although if Whitebar is still doing these and liking it, I certainly don't want to take anything away from him.
Ecaroh is offline
Old 11-15-2014, 09:53 AM
cat.lady's Avatar
Liked: 0
Thanks for the offer Ecaroh. I might take you up on that, but since I have 2 units now to repair thought if Whitebar was still doing them, I can do both. Lets see if he will see these posts within the next few weeks. If you sell it in the meantime, I understand.
cat.lady is offline
Old 11-15-2014, 10:09 AM
Whitebar's Avatar
Still here and repairing them.
I sent PMs to cat.lady and wesam101 with contact info.
cat.lady likes this.
Whitebar is offline
Old 11-16-2014, 04:56 PM
cat.lady's Avatar
Liked: 0
Replied to your message Whitebar...not sure if you got it as a notice stated I have not met my quota of posts to send out PM's. Will ship end of this week but not sure how to get you the tracking number as I don't want to post it here for privacy reasons.
cat.lady is offline
Old 11-18-2014, 09:30 AM
Liked: 0
None of the caps on the power supply board are of good quality. Replacing a few will make it operational. It may fail at a later date due to the ones not replaced, but then again may not.<br><br>
From testing the caps in my unit, these are the one I would replace at a minimum:<br><br>
C12 - 1000ufd 10v<br>
C10 - 470ufd 16v<br>
C8 - 100ufd 25v<br>
C14 - 4.7ufd 50v<br>
C4 - 1ufd 50v<br><br>
There are 4 others in the supply that were not grossly bad.
Is anyone on this thread currently repairing the cm 7000-pal? I can't find anyone in my local area to repair mine. It is stuck on the loading page (red/white page with dots) and won't move past it. I believe it happened the night that daylight savings started (Nov 2/3 when clock were set back an hour). I have tried troubleshooting with no success. If someone on here repairs this unit for this problem, please respond as I'd like to fix it vs trashing it.
marci1111 is offline
Old 11-18-2014, 10:21 AM
cat.lady's Avatar
Liked: 0
Marci111 in your effort of troubleshooting did you disconnect the antenna coax so you can reset your factory defaults? There are other threads in this place that might lead you to some firmware updates if there is one.
cat.lady is offline
Old 12-26-2014, 12:14 PM
Liked: 1
Whitebar
Could you PM me as well - I just tried to send you a PM and had the same problem as Cat.lady - not enough posts to send you a PM. We changed 6 capacitors a couple months ago and ours worked for a couple weeks then died again. Thinking sending it to you to fix would be easier :-)
Gail
galenaz is offline
Old 12-26-2014, 12:57 PM
Whitebar's Avatar
Originally Posted by galenaz View Post
Whitebar
Gail
PM sent
Whitebar is offline
Old 12-28-2014, 12:48 PM
Liked: 1
PM sent
Thanks packing up to ship out. I'll email the tracking number
galenaz is offline
Old 01-05-2015, 06:55 PM
Liked: 1
If you need your box fixed whitebar is your man. Total time with me sending to him, him fixing and shipping back it was a total of seven days and LESS expensive than buying a new one. Also his communication was awesome. When he fixed it he emailed and let us know exactly what he had done.
So glad I found this forum and post.
Thanks everyone
SD_Shadow likes this.
galenaz is offline
Old 02-20-2015, 12:39 PM
2ejennings's Avatar
Liked: 0
CM 7001 dead
@Whitebar : You fixed a couple of dead CM7000s for me some time ago, and now I have a dead CM 7001. Would you be able to fix this one for me? I have lost your contact info and the forum won't let me PM you.
2ejennings is offline
Old 02-20-2015, 12:50 PM
2ejennings's Avatar
Liked: 0
Forum seems to have lost my posts
My PC hard drive crashed last year and I haven't tried to post on AVS since. Now that I need to contact a member, the forum won't let me post because I don't have 6 posts under my new registration (apparently). I really don't see the need for this rule, but it is not my forum. Hopefully, Whitebar will see my request and PM me so that I can contact him.
Old 02-20-2015, 12:52 PM
2ejennings's Avatar
Liked: 0
Whitebar, if you see this, please PM me
Please note my previous posts
Old 02-21-2015, 08:35 AM
Whitebar's Avatar
PM sent
Whitebar is offline
Old 02-21-2015, 08:51 AM
2ejennings's Avatar
Liked: 0
Newbie trying to PM
Argh! Now the forum reports that I need 15 posts to PM!! How frustrating. I have over 15 but the forum doesn't remember them because I had to re-register.
Old 03-08-2016, 07:38 AM
Liked: 0
Question Repair of CM-7000 PAl
PM sent
I would like to get my CM-7000 repaired by Whitebar. How do I get information about how to go about it? Thank you!
Baker123 is offline
Old 03-08-2016, 07:41 AM
Liked: 0
PM sent
Baker123 is offline
Old 03-08-2016, 05:32 PM
Liked: 0
Whitebar------If you see this, please send me a PM. I have a CM-7000 PAL that needs repair. I am like several others on here that do not have enough posts to be able to PM you directly. Thank you! Baker123
Baker123 is offline
Old 03-09-2016, 03:41 AM
Whitebar's Avatar
PM sent
Whitebar is offline
Old 03-13-2016, 06:11 AM
curtw's Avatar
Liked: 0
Same problem here--not enough posts to PM. Whitebar, I've got an unresponsive unit as well. Could you let me know how to get your repair?
curtw is offline
Old 03-13-2016, 11:18 AM
Whitebar's Avatar
PM sent
Whitebar is offline
Old 04-25-2016, 10:11 PM
navagator's Avatar
Whitebar - Could you send me a PM also. I don't have a enough posts to PM directly either. I have a question regarding the Channel Master CM-7000 repair.
Thank you.
Invel DVB 3612, 12ft Conifer Mesh Bud, DMX 741 LNBF, V-Box 7 Positioner, Thomson Saginaw Actuator, Primestar fixed at AMC21, LG LST-4200A.
navagator is offline
Old 04-26-2016, 03:48 AM
Whitebar's Avatar
Thank you.
PM sent
Whitebar is offline
