Dead CM 7000 - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #91 of 101 Old 04-27-2016, 07:50 PM
Whitebar's Avatar
Liked: 24
For those looking to get their CM-7000 D2A converter fixed but don't have enough posts to PM, there are two options.
1. Post here for me to send you a PM. I usage check this forum daily.
2. Send me a PM on the Planet Replay forum contact: jhagen
I will send you a PM with details on the cost, what and where to send it.
I will also answer questions if you are trying to repair it yourself.
Girl7956 likes this.
Whitebar is offline
post #92 of 101 Old 05-09-2016, 06:51 PM
srfrdan's Avatar
hard to believe 19000 rtvers' looked at this topic! even after 5 yrs. there may be many of us left.
srfrdan is offline
post #93 of 101 Old 09-04-2016, 05:22 PM
CA_Guy's Avatar
CM-7000 with RED only
I have a couple of these boxes. It's interesting that each of them lasted about 13 months before failing. Nice thread, thank you.
First I wonder if anyone has found a problem with these units OTHER than the poor quality capacitors (other than caps installed backwards). Is everyone's issue related to these capacitors? Wow.
I opened up a couple of units, disconnected the logic board from the power supply and measured voltages. I get 11.87, 5.08 and 3.351. Looks great.
Next I connected the first logic board to the supply and the voltages become 14.5, 6.1, 2.8 with E6 measuring 1.19. I connected a 2nd logic board to the same power supply and get 14.6, 6.1, 2.9 (and E6 is 1.19).
I find it interesting, for example, that the 12V supply is higher with a load.
Thank you in advance for your reply.
CA GUY
CA_Guy is offline
post #94 of 101 Old 09-07-2016, 06:11 AM
Whitebar's Avatar
Liked: 24
Also notice your 5v went to 6.1. The reason is the power supply uses only the 3.3v for feedback in the regulation. With the bad caps, the average voltage on the 3.3v drops so the regulator turns on longer to try and bring the 3.3v to the set point. This also applies more energy to the other supply voltages so they rise beyond the normal voltage.
I have only seen one unit fail besides the caps, and this happened when somebody changed caps. Not sure what he did but the turner no longer worked.
ClearToLand likes this.
Whitebar is offline
post #95 of 101 Old 09-19-2016, 09:27 AM
djr01749's Avatar
Liked: 0
Originally Posted by Whitebar View Post
Mine also quit working properly. It would cycle the power LED between orange and green at a slow rate. This has been reported by several people, including myself, on the Coupon Eligible Converter Box (CECB) CM-7000 thread here at AVS Forum.<br><br>
This is caused by failing capacitors on the power supply. I replaced mine a few months ago and have had no problems since. If you don't feel you can replace them yourself, send me a PM and maybe I can repair it for you.
Hello,
I replaced the caps in my CM7000 but still get the red light. I noticed that the F4 fuse is missing (blown?).
Would you know the value for that fuse ?
djr01749 is offline
post #96 of 101 Old 09-19-2016, 08:39 PM
Whitebar's Avatar
Liked: 24
F4 on the logic board next to EW1 cap is not stuffed.
Did you replace the two 33ufd caps on the logic board? These can also cause the red light problem.
Do you have a voltmeter and did you measure the power supply voltages at the logic board connector while connected to the logic board? What did you measure?
Did you use low ESR caps? Using standard caps can cause the red light problem.
Whitebar is offline
post #97 of 101 Old 09-21-2016, 09:29 AM
djr01749's Avatar
Liked: 0
Red Light on CM7000
Hello,
No, I did not change the 33uf caps (yet). I was hoping the missing fuse might mean
a quick and easy fix.
The voltages coming out of the PS are now 11.7, 5.1 and 3.1. The voltage at E5 is 3v but
the voltage at E6 is only around 50mv. I have some 33uf caps in my spare parts but they
measure around 25ohms which I don't believe qualify them as ESR. Looks like the next step
is to get the low ESR 33uf caps, install them and see what happens.
djr01749 is offline
post #98 of 101 Old 09-22-2016, 06:55 AM
Whitebar's Avatar
Liked: 24
Voltage at E6 should be 1.2. Replacing E5 and E6 with good low ESR caps should fix it.
Whitebar is offline
post #99 of 101 Old 10-10-2016, 12:31 PM
djr01749's Avatar
Liked: 0
Dead CM7000
Hello,
Finally got the ESR caps but ran into a problem removing the old ones. The E5 cap was no
problem but E6 was a bear. After I got it out I checked the four connections at E6 and they
are all shorted together. I put in the new cap but naturally it did not fix the red light.
It was the first time I worked with a multilayer PCB and I guess they are very delicate since
it seems the board is now toast.
djr01749 is offline
post #100 of 101 Old 02-26-2017, 09:01 PM
Girl7956's Avatar
Liked: 0
Hello, I am a newbie to the forum, although not new to Channelmaster problems.
I have the CM 7000 PAL DVR, do you work on those also?
Similar problems, after 3 years, started having problems with the unit, freezing, red light staying on, remote not responding. I opened and could see that one of the capacitors was bulging. (I am not technie enough to work on it, I had just googled what a bad capacitor looked like.)
Took it to a shop and they fixed it. Got another year out of it, and same problems started again. I opened up and could not see any bulging capacitors. Took it to shop, they said the motherboard was dead, nothing they can do. Now the red light does not even come on.
Is there any slight chance this is still fixable?
Girl7956 is offline
post #101 of 101 Old Yesterday, 08:54 PM
Whitebar's Avatar
Liked: 24
I sent you a PM
Whitebar is offline
Reply ReplayTV & Showstopper PVRs
