Component - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 04-12-2011, 02:12 PM - Thread Starter
cwpl's Avatar
I enabled the component output (5000) but still nothing, I have another one to see if they don't work. Are they known to go out?
cwpl is offline
post #2 of 11 Old 04-12-2011, 05:08 PM - Thread Starter
cwpl's Avatar
Oddly when I disabled it (back to none) then it tried to work but was black and white and picture all squirrely??
cwpl is offline
post #3 of 11 Old 04-12-2011, 05:10 PM
hdonzis's Avatar
Quoted: 12 Post(s)
You know that it's 480PROGESSIVE versus Interlaced, don't you?
Henry
hdonzis is offline
post #4 of 11 Old 04-12-2011, 05:21 PM - Thread Starter
cwpl's Avatar
Henry
Not exactly sure what your asking but sounds like your wondering if it's a HD TV if so no SD Sony.
cwpl is offline
post #5 of 11 Old 04-12-2011, 07:28 PM - Thread Starter
cwpl's Avatar
Henry
That might be it from my manual " YPaPa Inputs--provides component video inputs for superior picture quality (480i only) " looks like replay only uses p kinda screws my plans up.
cwpl is offline
post #6 of 11 Old 04-14-2011, 12:12 PM - Thread Starter
cwpl's Avatar
Starting to look like Sony is only one that uses interlaced.
cwpl is offline
post #7 of 11 Old 04-14-2011, 12:42 PM
hdonzis's Avatar
Quoted: 12 Post(s)
Almost all SD TV's use interlaced component! I have several around my house, and they're all that way. That's why DVD players have an Interlaced/Progressive configuration on their component output, which is factory set to interlaced...
Henry
hdonzis is offline
post #8 of 11 Old 04-14-2011, 01:01 PM - Thread Starter
cwpl's Avatar
Henry
Then seems odd choice for replay not too. If I remember right I had the replay hooked to component on my JVC so it must be P. My Panasonic DVD players are hooked to it too so I must have set them to P again odd replay did not just have both.
cwpl is offline
post #9 of 11 Old 04-14-2011, 01:11 PM
hdonzis's Avatar
Quoted: 12 Post(s)
I suspect that the SD Digital TV's probably supported progressive inputs. Since they would have to support progressive transmissions, they might also support progressive on the component input. My SD TVs are all analog. Maybe your JVC has a digital tuner and your Sony is only an analog tuner?
Henry
hdonzis is offline
post #10 of 11 Old 04-14-2011, 09:42 PM
hdonzis's Avatar
Quoted: 12 Post(s)
Well, I just checked my in-law's Toshiba SD digital tuner TV, and its component input only supports 480i. So, I don't know what type of SD TV would support 480p, nor what was available at the time that the 5000 came out which would encourage ReplayTV to offer 480p...
Henry
hdonzis is offline
post #11 of 11 Old 04-15-2011, 11:01 AM - Thread Starter
cwpl's Avatar
At least if they wanted the progressive for what ever reason have both like any mid level and up DVD player.
cwpl is offline
Reply ReplayTV & Showstopper PVRs
