Looking for a Working Remote for a Replay 5000 series - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 10-20-2011, 07:46 AM - Thread Starter
raze's Avatar
Hi All,
The old remote for my 5000 series is going down for the count.
Several buttons no longer respond to being pushed.
If anyone has a remote they no longer need, please let me know.
ray
raze is offline
post #2 of 21 Old 10-20-2011, 07:15 PM
adam1991's Avatar
Quoted: 40 Post(s)
Liked: 43
https://www.replacementremotes.com/store/repairform.cfm
It's not hard to repair a remote. What's underneath gets worn down, and all it takes is some refurbishing that's fairly easy.
I bought and used this kit many years back, and it worked great:
http://www.replacementremotes.com/Ke...CR-Remote.html
adam1991 is offline
post #3 of 21 Old 10-21-2011, 07:21 AM - Thread Starter
raze's Avatar
I may look into this, thanks for the links.
r.
raze is offline
post #4 of 21 Old 10-24-2011, 05:42 PM
g501's Avatar
Originally Posted by raze View Post
Hi All,
ray
You can also try the iPhone/iPad remote.
Some free codes are here and they can be redeemed at the iTunes App stire.
MAK9FLJAYP3H
WLXRR9NPMWJ6
YHTF7PPH674N
KWX44P7XNTMR
g501 is offline
post #5 of 21 Old 10-26-2011, 06:27 PM
barmar's Avatar
Quoted: 18 Post(s)
Does Mikeyboy still sell RTV remotes?
My 1 button has been acting up lately. I have two inputs, and all the broadcast networks are on the input that's up in the 1,000's, so I type 10xx a lot, and also 1 or 1.
barmar is offline
post #6 of 21 Old 10-29-2011, 03:19 PM
gatomon's Avatar
http://www.ebay.com/itm/Lot-5-Sonic-...item1c2059324f
2974247646523704746118934872007814844268287238137130823, don't tell anyone!
"Be happy while you're living,
for you're a long time dead."
-Scottish Proverb
gatomon is offline
post #7 of 21 Old 10-29-2011, 06:19 PM
adam1991's Avatar
Quoted: 40 Post(s)
Liked: 43
Brand new, and eight bucks each shipped.
Back in the day...
adam1991 is offline
post #8 of 21 Old 10-30-2011, 04:15 PM
DavidMP's Avatar
Quoted: 23 Post(s)
MAK9FLJAYP3H
WLXRR9NPMWJ6
YHTF7PPH674N
KWX44P7XNTMR
I used that 1st code and ended up getting charged $3.19 for a $0.99 app???
Did I just fall for a scam or am I missing something?
DavidMP is online now
post #9 of 21 Old 10-31-2011, 11:41 AM
g501's Avatar
Yikes, I am very sorry and also have no idea how that could have happened. I presume you used the Apple iTunes store directly, so there is no way I could have "scammed" you. Is there any way you might have purchased a different app as well, and gotten mixed up? I suggest you contact Apple customer support since what you are reporting seems very bizarre.
If you use the code redemption box on the iTunes page you should not be charged and the worst that might happen is that the code is used up. Each code can only be used once and, based on my last try, if it is expired you will get a corresponding error message (and can then try a different code). I am tempted to just make the app free, but among other things, if it is totally free then random people download it (who don't even have a ReplayTV unit) and then just slag it as being useless.
g501 is offline
post #10 of 21 Old 10-31-2011, 05:59 PM
notyoung's Avatar
You can program a jp1 remote to control a replaytv. You should be able to get one from radioshack. I've done this and I mapped most of the functions to a radioshack remote. The only problem is that the button layout is not as nice as the replaytv remote. I also added some functions, such as a 3 minute skip button and 1 minute reverse button.
There's a steep learning curve if you are going to go this route, but you won't be stuck trying to find an old remote on the internet.
Here's some info on jp1
http://en.wikipedia.org/wiki/JP1_remote
Also you can rescue most remotes by carefully prying them open and then cleaning off that ooze from the board
notyoung is offline
post #11 of 21 Old 11-03-2011, 07:26 AM - Thread Starter
raze's Avatar
Should these remotes cost this much?
raze is offline
post #12 of 21 Old 11-03-2011, 09:11 AM
bonsai63's Avatar
It's a lot of five, which works out to just over $10 each with shipping. Assuming they are really *new*, as it says in the copy, this seems like a decent deal. But, do you need five remotes?
bonsai63 is offline
post #13 of 21 Old 11-24-2011, 08:10 AM
gring40's Avatar
The old remote for my 5000 series is going down for the count. Several buttons no longer respond to being pushed.
Don't know if it applies to the 5k series, but the SS remotes were notorious for that. Over time an oily non-conductive film would form between the polymer keypad buttons and the circuit board, making the buttons hard to use and then go bad.
The fix is to take the remote apart and clean the film from the keypad and circuit board with rubbing alcohol. I've done it many times.
gring40 is offline
post #14 of 21 Old 11-27-2011, 11:38 AM
adone36's Avatar
Liked: 37
Any universal remote I've seen from $7 up has Replay codes.
Tony
adone36 is offline
post #15 of 21 Old 11-27-2011, 12:49 PM
adam1991's Avatar
Quoted: 40 Post(s)
Liked: 43
yeah, but most of them are junky layouts.
The Replay remote is a great layout...
adam1991 is offline
post #16 of 21 Old 11-27-2011, 12:49 PM
gring40's Avatar
Agreed, as does mine. But there are no keys for skipping forward 30 sec (or back) so I have to use FF & FR, and also go thru the RTV's menu for Replay Guide or Zones.
gring40 is offline
post #17 of 21 Old 11-27-2011, 09:09 PM
adone36's Avatar
Liked: 37
I programmed other buttons for all of those and more.
Tony
adone36 is offline
post #18 of 21 Old 11-28-2011, 06:54 AM
gring40's Avatar
Ordinary universal remote? With mine (came with TV) you find a code for the RTV that works, & then get whatever functionality there is. How do you 'program other buttons' ?
gring40 is offline
post #19 of 21 Old 11-28-2011, 07:16 AM
adone36's Avatar
Liked: 37
Almost all remotes nowdays have prog. buttons
Tony
adone36 is offline
post #20 of 21 Old 12-20-2011, 01:15 PM
jwc553911's Avatar
You still need an original remote? You looking for the silver one or the black one?
Jeff
00004-54831-47079 jwc553911
00004-54831-35256 jwc5539112
00004-54831-77286 jwc5539113
00004-02044-20375 jwc5539115 (DVA)
00004-54832-09854 jwcAtlanta (DAD)
jwc553911 is offline
post #21 of 21 Old 12-21-2011, 06:33 AM
pshovest's Avatar
No need to wrestle with programming or universal remotes that don't offer QuickSkip, Guide, Zones or Replay keys, brand new factory ReplayTV remotes are once again on ebay. I just bought (5) for $35 delivered. These are 50xx remotes w/ CA button.
Paul S
pshovest is offline
Reply ReplayTV & Showstopper PVRs
