Activation failure on lifetime activated 5040 - AVS Forum | Home Theater Discussions And Reviews
Old 12-24-2011, 12:38 PM - Thread Starter
timg11's Avatar
I have a 5040 Lifetime activated unit that lost its ability to record anything (#1). Something in the input converters apparently - it won't record from RF, composite, or S-video.
Recently I received another lifetime activated 5040 from a family member (#2). It's hard drive was dead. I took the hard drive out of mine and put it in the the #2 unit.
The #2 unit boots up fine, but goes to the Service Activation screen when I try to do anything. I am able get to setup, and Ethernet is correctly connected with a valid IP address. Under System Information /Unit Info it says "Service: Activated (one-time fee paid)
What options are available to return this unit to operation again?
By the way, I don't use it to do any off the air or off cable recording, so program guides, etc are irrelevant. I just want it for manual recording of directly connected NTSC video sources to digitize and download the MPEG2 video that I can edit.
timg11 is offline
Old 12-24-2011, 01:50 PM - Thread Starter
timg11's Avatar
I found these alternate DNS addresses:
Originally Posted by truckie36
I also found that these DNS servers worked to get the software update:
208.67.222.222
208.67.220.220
I entered them, and re-verified the network connection. Then it went back to the activation screen, but this time it counted up to 100%, and then said "your replayTV is activated.
Then it rebooted and got stuck at a black screen. After powering off, it came up and appears to work correctly.
Thanks truckie36 - that seems to have fixed it!
timg11 is offline
