setup problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-09-2012, 02:05 AM - Thread Starter
twopits's Avatar
I just bought a Replay TV 5000 unit. I have changed from cable to antenna.
1. I've gone through the entire setup and keep getting the blue drop down screen that says No video available. I get video and audio when Replay is off, but when blue light is on [Replay on] I get no video screen rather than TV channels.
2. When I get the Channels Available listing - all I get are 4 channels[which are not ones in my area]. While watching just TV I get at least 34 channels [w/o Replay]. The four channels are not channels that I even get in my zip code while watching TV.
twopits is offline
post #2 of 4 Old 01-09-2012, 03:46 AM
Whitebar's Avatar
Quoted: 13 Post(s)
Liked: 24
Welcome to ReplayTV.
First the ReplayTV tuner is not ATSC, you will need an external ATSC converter box if you are in the US or Canada.
Second, the guide data provided by the standard replay service does not include the ATSC channel data. For that you will need to setup something to provide the data such as WiRNS on a PC. WiRNS can obtain the data by using Schedules Direct or data from a scraper program.
Whitebar is offline
post #3 of 4 Old 01-09-2012, 06:51 AM
gring40's Avatar
Another route would be to go back to cable, depending on your area. Here, Comcast is still compatible with the Replay, and they offer a cheap Basic package with the same local channels you'd get on an antenna, but not HD, of course. Your Replay doesn't do that anyway.
gring40 is offline
post #4 of 4 Old 01-09-2012, 11:17 AM
mlloyd's Avatar
Quoted: 34 Post(s)
I have done this, and it wasn't too difficult. It works if one of the Replay codes will control your ATSC converter. Mine is a RCA DTA800B1L.
BTW, I wish there was something like this for clear QAM.
mlloyd is offline
Reply ReplayTV & Showstopper PVRs
