Eset NOD32 AntiVirus and DVArchive - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-26-2012, 10:55 PM - Thread Starter
Mike Cornwell's Avatar
Perhaps this can help someone in the future.
After upgrading my desktops antivirus from NOD32 version 4 to version 5, my Replay's stopped showing up in DVArchive. Trying to manually add them resulted in locking up DVA on most occasions.
The DVA log would show messages like this:
ERROR: Error processing served request from DVR 192.168.10.104 -- For input string: "400 Bad Request"
After searching NOD32'd settings, I finally fixed it by going into Advanced Setup --> Web and Email --> Protocol Filtering --> Excluded IP addresses, where I entered the range of my (3) Replay's.
Mike Cornwell is offline
post #2 of 3 Old 01-31-2012, 09:22 AM
MrPlastic's Avatar
I had given up on DVA, because I couldn't get it to work. Every time I tried to connect to my RTV, DVA would hang, or time out with an error message like yours above.
I saw your post, adjusted NOD32 as you suggested, and VOILA! Now I'm happily recording movies and pulling them in to drop on the home server.
This has rejuvenated my RTV use! Thanks a million!
Indecision is the basis of flexibility.
MrPlastic is offline
post #3 of 3 Old 09-19-2014, 02:48 PM
AlanMFriedman's Avatar
Add me to your fan club. I've spent weeks trying to figure out why my DVArchive running on Windows 7 all of sudden refused to connect to any Replays and vice versa. Among other things I tried reducing and then removing the firewall, changing the Java security level, changing the IP addresses of WiRNS and IVSMagic, changing the port forwarding in my router. Nothing worked. I just happened upon this thread and made the same changes to NOD32, which I have installed and all works beautifully now. Thank you.
AlanMFriedman is offline
Reply ReplayTV & Showstopper PVRs
