How do I reset parental control pin? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-21-2012, 09:14 AM - Thread Starter
Darkside's Avatar
I thought there would be threads regarding this, but I tried searching "reset" and "reset pin," but nothing came up.
The only way I know is to wipe out the drive using rtvpatch.
Darkside is offline
post #2 of 4 Old 02-21-2012, 06:01 PM
mlloyd's Avatar
Quoted: 33 Post(s)
If you're using WiRNS, you can put this in the 'shellcmds' file:
regedit delete Software/Apps/ParentalControl
After a network connect from that Replay, all the parental controls will be reset.
mlloyd is offline
post #3 of 4 Old 02-22-2012, 01:07 AM - Thread Starter
Darkside's Avatar
Thanks Mark. It worked. For some reason, it also deleted the guide. I forced another net connect and the guide came back.
Now I can record shows for myself without worrying the kids watching them
Darkside is offline
post #4 of 4 Old 02-22-2012, 07:37 AM
mlloyd's Avatar
Quoted: 33 Post(s)
I use that and it's never deleted the guide. That's proof I don't know everything :-)
mlloyd is offline
Reply ReplayTV & Showstopper PVRs
